Schumacher Corner
This is just a starting point.
Regional Moderator
I was just concerned that the front seemed so wide. But if its not an issue, I won't worry about it.
thanks Adrian
One of foam's dirty little secrets is that few races tech car width. As far as I know only ROAR races do this. I have measured the cars of a few pro racers that were friends of mine at racers like the IIC and Snowbirds and most of their cars were over 190mm by as much as 2mm.
because the castor blocks are more fore than aft in the arm, the front pin blocks will contribute to the track width more than the rear (of the front ). 2.5 and 1.5 averages to 2, but you will probably have to go with 2 and 1 if you're keeping the arm sweep. if you are finding your spacing to be much off from this, then there's something else going on.
fyi - i don't like to wedge the car with track width unless it's getting late, and my setup is still severely devoid of steering or stability. there's nothing fundamentally wrong with it, i just choose other ways of tuning first.
- gary redmond -
I've been running 2mm spacers at the bulkheads and 1mm spacers at the rear hex only. This is a good starting point for rubber tire. I've found that it give alittle bit more steering all-around and quickens the steering response.
On 26th Aug,One of the local race UTP (University Technology Petronas)RC Madness race.
I was TQ in Modify class and won the race.
This is the first win by Mi3 in Malaysia.i was using 7 turn motor.i even overlap the 2nd place driver by a lap!thanks schumacher for this great car!
I'm setting my Mi3 up to run foam tire carpet. Put the lowered front and rear shock towers. My shocks are set at 60.50mm. Shock is to where the shaft starts to push out on the ball cup. My tires are 56.80mm. The front ride height lowest is 6.5 with the collars turn the whole way up. Rear is 4mm with collars all the way up. Is anyone else having problems getting 4.5mm ride height with lowered shock towers?
I was also looking at that....
You could lower your arms on the blocks and adjust your roll center at the turnbuckles to compinsate.
the towers were designed to be able to slam the body, so they had to be low. in addition to neglecting track width, most foam races (even some national races) won't tech body height. infact, i have taken a file across the top of the tower and flattened off the ears, where all that extra material is. i'm not sure why they decided to make the rears 1-2mm higher. maybe just so you don't have to do those mods to both ends...
anyway, makes the car look two tenths faster, if nothing else.
Hi Guys
I have a New Mi3 has been only raced twice and it has alot of on power oversteer any ideas on how to fix???
We need a lot more details like do you run on asphalt or carpet, rubber or foam tires, spool, diff or one way, what base setup are you using? Do you have the setup on your car exactly as on the setup sheet? If you miss one detail the whole setup will be off and the car could behave oddly.
you need some drop down spring perches from associated (the standard ones for their tc's). after that, the schumacher springs should be a decent fit, but if you're still having problems, or are running longer springs, hack a millimeter off of the ball cup. i have seen plenty of room with xray springs (26mm) and 58mm tires after removing that 1mm from the ball cup.
wow had my first race meeting with Mi3 What a fantastic car I had braken all my personal Records...
Thanx to everyone worked on that cars development...]
Also Thanx to Adrian All his Help And support to All Schumacher Drivers...
