Schumacher Corner
thanks dude!
Support . . .# 1 reason I love Schumacher!
Nick Case's Modified Schumacher Fusion 21 with a brushless motor and lipo battery won this years Fastest R/C car contest with a 127mph run!
Jon Kerr, Just wanted to say thanks for the excellent setup from reedy. Only ended up changing two things after running it, went with a little bit harder tire for stock class and ran the next step up harder spring on the front. After that it was dead on. Thanks Again
Anytime. Glad to hear it's working out well.
R/C Tech Elite Member
Kerr definately had a dialed car at the RROC..
Regional Moderator
Just as a re-cap to what I think I've been seeing around here. To get ready for carpet season, this is the good stuff to pick up.
-2.5mm chassis
-front diff
-6 deg C-hubs
Already got the heavy springs and stuff covered, just wondering about the specific Mi3 stuff.
-2.5mm chassis
-front diff
-6 deg C-hubs
I tries some stuff this last weekend on a really high bite asphault track car was dialed i ran the
-2.5 carpet top deck (new one)
-gold sway bar
-light front blue spring but with rear white
-silver rear sway
-and 1 mm kick up-
-and the aluminum 1 degree rear hubs
the gold sway and kick up helped in the hight spead
and the hubs helpd to let the car rotate through the corner to help steering
-gold sway bar
-silver rear sway
-and 1 mm kick up-
-2.5mm chassis
-front diff
-6 deg C-hubs
-2.5mm chassis
-front diff
-6 deg C-hubs
I think the stiff/wide/carpet top deck is needed more than the thicker chassis. Tracks these days are not producing the amount of grip we experienced a few years ago (except for CEFX Raceway).
Goetz can probably give better advice as he is the carpet specialist for this car, but save yourself a couple of bucks and try the stiff top deck first.
-2.5mm chassis
-front diff
-6 deg C-hubs
-2.5mm chassis
-front diff
-6 deg C-hubs
has anyone run the new jaco rubber tyre yet?
thanks jimmy
thanks jimmy
so greens will be a tad softer do you have a picture of the profile?
thanks jimmy
thanks jimmy
where is the best place to get some from that will ship to the uk so i can start testing?
jimmy
jimmy
