Schumacher Corner
R/C Tech Elite Member
If you can, just unsolder them from the poles placing them vertical and re-solder them down horizontal. Most all high end ESC's are able to do this..
Use some Rit clothes dye, boil it in water and dunk the parts in for a few minutes until you get the color you want.
ok cheers what are the best ball cups? mine are pretty sloppy so was gonna redo the whole car?
cheers,
cheers,
Stephen,
Yeah you better believe it, I thinks it's Cleveland for me this year.
My cousin is getting married in AZ and eating up most of the vacation time. LOL
Have been running outside right now.. very impressed How do you like your car so far?
James
James
I looked online and on the manual and was unable to find a part number for the 96t 64p spur gear. Does anyone have it handy?
Trader Rating: 102 (100%+)
Andrew
the 96 hasn't been posted in the US or UK site.
you might have to call Schui USA.
i ordered a few on Thurs and forgot to write the part number down.
sorry dude.
June UK Schui news letter:
http://www.racing-cars.com/images/pdf/schumacher_june_newsletter_l.pdf"]http://www.racing-cars.com/images/pdf/schumacher_june_newsletter_l.pdf"]http://www.racing-cars.com/images/pdf/schumacher_june_newsletter_l.pdf
page 3 ...also has the pic of the new stiff and flex top decks
sorry dude.
Super Moderator
randy you have pm
Advice from Master Schumacher Mi3 driver, Adrian Martinez, to use a plastic bag and place it on the ballstud, and then press the ballcup into the ballstud, and the it cuts a perfect cutout of the plastic bag and removes the slop. The Schumacher ballcups are exremely durable and very tough...better than RPM ballcups...if you have play, all you need to do is follow AdrianM's advice and you'll easily fix the "problem".
Very true, I guess I plain forgot about that trick, havent done it in 5 or 6 years..
On another note, finally got to run the car today and Weylin's set-up worked pretty good as my base set-up but with several progressive changes I made, the car is coming along nicely PW expect a phone call Monday , those blasted CVD pins got the best of my day 3 of 'em! It's all good though, Schumacher to the rescue
Final verdict- Awesome piece of toy car!
Yep sure does. I tried it and the 'trick' should be patented
Toe in
Hi
How does one get less toe in on the Mi2-EC Foam spec kit, i am needing to get between 0 and 1 degree of rear toe in.
