Old 06-01-2006, 10:54 AM   #14956
Sanabria's Avatar
Originally Posted by ground-round
A few pages ago, you guys were talking about taking the spacers out from underneath the diffs and running flat on the chassis. Any feedback from that experiment?
Jeff, I'm going to experiment with this at Fast Track on Saturday. I'm thinking of taking out the riser plates for the arm mounts also to keep the geometry the same and not have to slot the front tower. I know it will be a little different, but worth a try. I only made a few changes to the kit setup at the Reedy race and the car was really good.
BTW, congrats on your win at the State Race.
Sanabria is offline   Reply With Quote
Old 06-01-2006, 10:55 AM   #14957
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Bob Barry
Jon was that with Carpet towers or regular towers? Also was that with the camber mod on the rear if you did use carpet towers?
I you have the last version of the BMI towers from the regular MI2 the camber links should be about right.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 06-01-2006, 10:56 AM   #14958
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Regular towers.
Jon Kerr is offline   Reply With Quote
Old 06-01-2006, 11:00 AM   #14959
Super Moderator
Cool, thanks.
Tekno | BLOK | JConcepts | RaceReadyProducts | BOOMrc
Bob Barry is offline   Reply With Quote
Old 06-01-2006, 01:18 PM   #14960
Jon is right about corner speed. What a difference it made in the car. I didn't touch the rear camber links and had the front camber links in the lower of the carpet tower. I put .5mm of kickup in the front and WOW it added alot of sweeper speed. Then I wanted to over shoot the turn at the end of the sweeper.
The Mi2 is so much better on asphalt than my FK05. The only problem I have is bending CVD's and breaking the pins inside of them. What is the part number for the Ti ones? Or even steel ones if made.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 06-01-2006, 01:33 PM   #14961
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Originally Posted by Jon Kerr
Most of us did that at the Reedy race. I liked it a lot. It seemed to give the car a lot more corner speed. You'll need to run the high camber link location on the rear shock tower and slot the front tower up 2mm higher than the stock high link location. But it's worth it. It worked really well.
Jon or anyone else for that matter...Any chance we can get a run down of what you guys were running at the Reedy race?
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 06-01-2006, 01:38 PM   #14962
Super Moderator
Steve did you glue a 1.6 mm shim to the back of the steering knuckle? it will act as a mechanical stop and prevent alot of damage.
Old 06-01-2006, 01:53 PM   #14963
No I didn't do that.
Steve Walter
Old 06-01-2006, 01:58 PM   #14964
Sanabria's Avatar
Front:
35wt oil
camber link in up position
1.5 deg camber
0 deg toe
4 deg caster
2mm shims on steering knuckles
arms in short position
shocks in kit position
15 lb spring (Xray Teal)
silver sway bar
5mm ride height
Droop, 2mm above rh
Locked diff
Rear:
35wt oil
camber link in lower position
1.5 deg camber
2 deg toe (std)
arms in stock position
15 lb springs (Xray Teal)
silver sway bar
5mm ride height
Droop, 3mm above rh
116 spur, 37 pinion.
Old 06-01-2006, 02:02 PM   #14965
Kevin K's Avatar
Thanks....what about spacers under the diffs and suspension mounts? I saw that Jon said that they took the spacers out from under the diff but what about the suspension mounts.
Old 06-01-2006, 02:05 PM   #14966
Sanabria's Avatar
My car had all the spacers. It was still good for 13.9 to low 14 laps.
Old 06-01-2006, 02:07 PM   #14967
STLNLST's Avatar
I ran the stock riser plates with an additional 1mm spacer under the pivot blocks front and rear. I believe that most of the team were running their cars this way.
I took all the spacer from under the diffs.
Old 06-01-2006, 02:11 PM   #14968
Jon Kerr's Avatar
Lets see if this works. This is the setup I ended up with.
Old 06-01-2006, 02:14 PM   #14969
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
So thats the backflip setup?
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 06-01-2006, 02:21 PM   #14970
Kevin K's Avatar
Thanks for the sheet Jon....were you using 2 hole pistons in the shocks Im not sure if Im reading that sheet right or not.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
