Schumacher Corner
Originally Posted by David Alford
I would normally run sorex 36s with the xenon gray insert, but I can't find anyone that has them in stock. And since I'm racing this weekend I'm kinda in a hurry. I already had traction stuff 2 day aired to me
If you can get someome to answer the phone.......
Good Luck
Originally Posted by Sanabria
I ended up trying the Fanton 322s and XXXs, didn't notice any significant difference in performance, except not having to change brushes with the XXX.
LOL...yea that was a scary sight opening that door
Good luck at the Nats.
Stock?
I ordered some Hara and some yok inserts. So we'll see.
AusJD2703, take out rear droop first to tighten up the rear of the car and help prevent corner entry oversteer.
Dont reduce castor to 2 deg, it will make the turn in oversteer problem worse.
Less castor, more turn in - initial steering, unstable in a straight line.
More castor more stable around steering centre, more mid corner steering.
Originally Posted by DavidAlford
Stock?
Originally Posted by STLNLST
Yes....STOCK!!!! Man I can't get any love
That's OK, I bit the bullet and signed up for 19 turn and stock foam for Vegas. Running foams for the first time, I didn't think modified would be too smart of a move.
Hey guys, nice job out at the Reedy race. I know you all put in a ton of work for it and it shows. Good luck to all who are heading back out to Cali for the Nat's.
Jon 19 Turn foam is like mod rubber....It's crazy fast. We did it at Horsham this past winter and it was awesome.
thanks king g,
hey how do u tune with inserts?
what does air gap do?
whats does firmnes do?
also i use sorex medium b's what could i uses to get temps up quicker?
when do u change tire compounds and how can i choose the right tire as our weather has changed drastically and every one is strugglying to find the right tyre, last week we went from sorex 36's to 32's and were still lacking traction.
out temps have went from a cool 22 to about 15'c so we have no clue also the sun is setting earlyier (winter in aus) so track temp is constantly dropping as we qualify and drops as we run the finals any suggestions?
I plan on doing the best I can at the nats. Schumacher needs a face up in the A-main at the nats in the stock class
hey jon,
what do you use to mount your shocks?
ie the kit ball and spacer or some thing else??
Big Thanks to WYD for the setup help on my Mi2 EC. This is the best car I have ever bought. I have never been so consistant. What a great combo Schumacher Mi2 EC, Full Throttle motors and batteries.
Originally Posted by Matt Howard
So I take it RacerX is racing stock at the nats? I know you wouldn't run stock, that's even worse than running the "kiss your sister" class (19T)
Tech Legend
Trader Rating: 51 (100%+)
Another is drawn over to the dark side
