Old 05-19-2006, 03:32 PM   #14761
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
Originally Posted by PW
Actually he did get the day off to go racing, but he didn't tell me it was his B-Day
Well I guess it worked out.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 05-19-2006, 08:12 PM   #14762
STLNLST's Avatar
Trader Rating: 17 (100%+)
Happy 43rd Adrian.....
I get to go to the Reedy for my Birthday
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 05-19-2006, 08:35 PM   #14763
wyd
Tech Legend
wyd's Avatar
Just finished putting on the carpet tower on the front of my car and lowered the front diff. Will see what happens tommorrow and work from their. I didn't put the gray front belt on but I do have the longer front black belt on. Drivetrain is very smooth. I will put the gray belt on when I put my new ceramic bearings in in a couple of weeks. Change it right before my big race in June.
Old 05-19-2006, 08:44 PM   #14764
Super Moderator
Tony Rivas's Avatar
Trader Rating: 53 (100%+)
what!!! no way 43 no i can't believe it happy birthday Adrian
The "Dominican Assassin"
Sorry for the Spelling but you know what I mean.
Tony Rivas is offline   Reply With Quote
Old 05-19-2006, 09:27 PM   #14765
STLNLST's Avatar
Old 05-19-2006, 09:42 PM   #14766
Trader Rating: 6 (88%+)
dam im older then him i turned 43 in jan and i still feel like a toyrus
kid
comming soon MOTORHEAD RC MOTORSPORTS...........
BILL.D is offline   Reply With Quote
Old 05-19-2006, 09:47 PM   #14767
paul ygm
Old 05-19-2006, 09:50 PM   #14768
RayWarner's Avatar
Send a message via AIM to RayWarner
kid
Your the little kid kicking and screaming inside of Toys R Us!
RayWarner is offline   Reply With Quote
Old 05-19-2006, 10:37 PM   #14769
hey guys my car has been pulling to one side on power and then straight of power and ive tried to trim it out but it seems as thought u either wander on or off power so im trying to get rid of all the tweak all my shocks are 62.2mm from tip to tip using digital callipers droop is the same and im going to put the car on shock towers and undo all upper and lower deck screws and retighten,
im checking the sway bars also and my shock springs are the samelegnth the ony other thing i can think of is shock oil ie rebound and dampening not being that same left to right, so how do u guys set it??
heavy who is on hear told me that he sets his shock with no rebound?? this take rebound out of the equation which make sense so im gonna try it but does any one else have suggestions on how to saught this out??also how do u tweak the actuall chassis?? and can it be undone i thought about getting to plates of glass and sand whiching the chassis between with a 20kg weight on top? i just want it to drive straight lol
thanks in advance
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 05-20-2006, 02:24 PM   #14770
mi2 or mi2ec
take a mi2ec or stik whith my mi2 carbon?
what is the difrence in the ride and setup?
ynze is offline   Reply With Quote
Old 05-20-2006, 02:35 PM   #14771
mini-dub's Avatar
Trader Rating: 16 (100%+)
thanks in advance
Are you running a oneway? I had a similar problem and it was because one of the oneway bearings was broken and you could rotate the wheel alone backwards. Also check all your droop settings front and rear to make sure they're even left to right.
ynze - The Mi2 is still a good car, but the EC will be easier to dial in since that's what all the team drivers are using so getting setup advice should be easier and more up to date. When testing the new drive chain on the Mi2 such as the one on the EC and comparing it to the old drive chain. The new belt layout with both belts running from the layshaft made the car easier to drive and feel more balanced. If you have the money to pick up an EC kit I would recommend it. The car is dialed out of the box on asphalt. Also the EC kit builds super square and without any tweaking just by tightening the screws. Where as with my Mi2 I had to push on the shock towers on setup blocks to keep the chassis square and untweaked.
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 05-20-2006, 06:15 PM   #14772
IslandBwoy's Avatar
I had the same problem today not to say that this is exactly what your facing. But, your car will do that if you've managed to snap one of the cvd pins on the car. Usually this is easy to spot as one of your wheels will most likely spin freely or bind depending on which pin broke. Thus you may want to check your cvd's.
thanks in advance
IslandBwoy is offline   Reply With Quote
Old 05-21-2006, 01:20 AM   #14773
hey guy checked cvd pins checked shocks changed to zero rebound all same length
put on a f;at surface rocked it and then tighteneded the bottom deck and top deck what next cause it is still tweaked of something it just wont steer straight on and off power it one or the other.
please help as it making it hard to do quick laps
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 05-21-2006, 09:40 AM   #14774
WYD had his Mi2 really dailed yesterday at The "C" in Frederick, MD. What a great choice Paul Wynn for making him part of your Team. I can't wait to get my Mi2 and get it on the track.
Latif had his Schumacher really dailed yesterday also. He is another great racer to have on your Team.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 05-21-2006, 05:08 PM   #14775
mini-dub's Avatar
You never said if your running a oneway or not and if it's damaged or not. If you are, check both sides to make sure the bearing aren't rotating both directions. Also check all the diffs (if you running a front one... I don't know) and make sure they're not slipping. Hold one tire and the spur gear with that thumb and turn the other tire. You don't want it to rotate easily if at all for some classes of racing. Having a problem on throttle in a straight line isn't going to be caused most the time by a tweaked car. When your car is tweaked most the time it will make it spin out one way and push the other... MOST the time. There are exceptions . So check your front and rear diffs.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
