Old 05-18-2006, 09:33 PM   #14746
The problem with the rubber bands (or o-rings for that matter) is that it really doesn't get rid of the slop, it just makes you think it does. The forces and stresses that our cars produce is more than enough to over come the strength of the rubber bands. The car will feel better (less sloppy) on the bench, but you will still have slop while running. That is not to say there is no benefit, as I would expect the car to center better in a straight line (providing you have a good servo), and maybe be more sensitive off center.
I used to use teflon plumbers tape. Just cut a square (maybe 1cm x 1cm) then ball it up, put it in your ball cup, and press it on. It is remarkable how much you can compress this material inside th cup. The down side is that it will eventually work its way out of the cup (usually 3-4 runs). -Jeff
Jay Dub is offline   Reply With Quote
Old 05-19-2006, 12:01 AM   #14747
mini-dub's Avatar
Trader Rating: 16 (100%+)
Body bags are nice and thin so they work well for taking the play out of ball cups. Just make sure when you're removing play from your car that you don't add any binding at all. The car will handle much worse if there is a slight amount of binding compared to a little amount of play. I actually think that the cars work better with a little amount of play, theory being that the adjustments on them no matter how carefully done, theyre never perfect, because anything in rc is never perfect, and a little amount of play covers up those inperfections. So if something is a little sloppy, don't worry about replacing it or trying to make it zero play, a lot of how a car is going to handle can be mental too. If you think a change is going to make it way better than you probably will think it's faster and vice versa. That's why when I make changes I try to drive the car with a "lets see how this worked " kind of mentality .
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 05-19-2006, 05:27 AM   #14748
Moderator
Trader Rating: 76 (100%+)
I've been doing some reading and is it safe to say that the mi2 likes to run with close or the same springs in the front and rear?
roadrashracing is offline   Reply With Quote
Old 05-19-2006, 06:40 AM   #14749
Schumacher sell rose joints (Pt number U728 )
I've replaced the middle bell crank link and the connection between the servo and the steering arm - these joints have zero slop!
You'll need a couple of different screws but I'm sure we've all got tons of these hanging around in our pit boxes!
Cost about 4 ($7) and works a treat
exint2 is offline   Reply With Quote
Old 05-19-2006, 07:19 AM   #14750
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
The rubber band trick has worked foe me. Yes the forces will overcome the bands in turns but mine was mainly for the straights and it has made the car track perfect down the straights. I don't mind the slop as the car from the first run has gone straight so to me as long as it continues that way I don't care how much slop I get. The car runs very consistant so the little slop I have isn't affecting its performance. I will say I have my bands on pretty tight and takes a good amount of effort to move them. I have really short ones folded around twice.
I have heard of the plastic bag trick many of times but never actually tried it but from others posting on here and other threads I know it works.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 05-19-2006, 07:35 AM   #14751
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I agree with Weylin. The little bit of slop that's inherent in our cars makes them much more drivable. To me, tightening everything up too much, beside the potential for binding, could make the cars more twitchy and sensitive to imperfections in the track. That little bit of slop should make the car more forgiving.
Jon Kerr is offline   Reply With Quote
Old 05-19-2006, 07:40 AM   #14752
wyd
Tech Legend
wyd's Avatar
100% true. Even with the rubber band setup or using the wrapper trick some slop is always needed to make the car track straight.
I remember years ago racing oval I shimmed a car to have zero slop anywhere on the car. Man I practiced twice and the car was absolutely horrible. I took a shim or two out and had a little slop back in the car and it was perfect. From then on I learned that some slop is needed in a car to make it track straight and work properly.
Old 05-19-2006, 09:02 AM   #14753
Super Moderator
Wow I forgot, you are old aren't ya
Tekno | JConcepts | ProTek RC | RaceReadyProducts | BOOMrc
Bob Barry is offline   Reply With Quote
Old 05-19-2006, 10:49 AM   #14754
John Tag's Avatar
Trader Rating: 42 (100%+)
Yooo Adrian... Happy Birthday...
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 05-19-2006, 10:51 AM   #14755
Jon Kerr's Avatar
Happy B-day ya old man.
Old 05-19-2006, 12:21 PM   #14756
wyd
Tech Legend
wyd's Avatar
I'm creeping up their.
Oh snap didn't know it was Adrians birthday. Well have a good one. Hope PW gave you the day off!!!!!!!!!!!!!!!!!!
Old 05-19-2006, 12:49 PM   #14757
Super Moderator
Happy Birthday Adrian.
Old 05-19-2006, 01:25 PM   #14758
PW
PW's Avatar
Send a message via AIM to PW
Actually he did get the day off to go racing, but he didn't tell me it was his B-Day
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 05-19-2006, 01:45 PM   #14759
IslandBwoy's Avatar
HBD
IslandBwoy is offline   Reply With Quote
Old 05-19-2006, 02:22 PM   #14760
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
I want a day off to go play golf and a day off to go play poker. Wonder if they would believe its my birthday twice in a week....
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
