Old 05-17-2006, 01:34 PM   #14731
John_S's Avatar
ok kool im on a low grip outdoor unpreped track racing rubber tyre 19t
John_S is offline   Reply With Quote
Old 05-17-2006, 03:00 PM   #14732
PW
PW's Avatar
Send a message via AIM to PW
I normally stand my shocks up a little more on low-bite tracks. You may also want a longer rear link (outside on hub). Try 1 thing at a time though
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 05-17-2006, 09:26 PM   #14733
IslandBwoy's Avatar
Hey all,
Do any of you guys have a quick fix for allowing the stearing arm of the MI2 to clear the top of the servo? This doesnt seem to be a problem on my EC but with my MI2 the arm is rubbing. Why is that? I dont know if this makes a difference but my EC is running a Futaba servo while my MI2 is sporting an airtronics.
Thanks,
MI JEDI
IslandBwoy is offline   Reply With Quote
Old 05-17-2006, 09:34 PM   #14734
cornerspeed's Avatar
Make sure that servo is all the way down on the chassis. If it is, you can shim up the steering lever a little in between the bell crank arm and the mount on the chassis. Make sure you do both sides, so the steering is even/equal. Try that.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 05-18-2006, 09:43 AM   #14735
brownpants's Avatar
Originally Posted by IslandBwoy
Hey all,
Thanks,
MI JEDI
I just filed the arm down a bit until it did'nt rub any more.
Darren
brownpants is offline   Reply With Quote
Old 05-18-2006, 10:04 AM   #14736
IslandBwoy's Avatar
Kewl. I seem to have sorted it out. I never realized this before but it seems like the horn never completly clears the server until you replace the spring and nut combo. I was looking at it without.
On another note though, the c hubs; has anyone ever tried drilling a hole in the c-hub and using a set screw to take some of the play out of that joint? Much of the front end play on my car comes from this area. I know Paul uses a beed of clue to make it tighter but after trying that i found that this 'procedure' wasn not a one time fix. Thus, I was thinking if i drilled a small hole through the side or bottom of the hub and using a set screw to rest against hinge pin, this should work well if I line it up just right. What do you guys think?
Old 05-18-2006, 04:32 PM   #14737
King-G's Avatar
Send a message via ICQ to King-G
This is a possible solution, although I'd be weary as it may weaken the hub.
I use very thin shims either side of the castor block, careful not to overdo it as it will bind up the suspension if tight.
I agree most of the slop is in this joint, Ive also been keen to find a good way of removing the slop on the right side bellcrank, as its a combination of the slop in the trackrod ball cups, and the right side steering links cups.
One method I use to date is to snap some plastic from a parts bag over the ballstud then pop the ballcup on over the plastic, tearing away the excess it leaves a little plastic in there to pad out the extra space without binding it up.
King-G is offline   Reply With Quote
Old 05-18-2006, 05:53 PM   #14738
in2deep's Avatar
Default r 12
have r12 for sale or trade
in2deep is offline   Reply With Quote
Old 05-18-2006, 06:19 PM   #14739
IslandBwoy's Avatar
That makes sense. The shims definately works well but its so f'n difficult to get them in place. Even worst if your rushing. But what your saying about weakening the c-hub could be a real problem like you said so i'll keep an eye on em.
Thanks.
Old 05-18-2006, 07:45 PM   #14740
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
what is the best way to get some of the slop out of the front steering, ball cups are still good.
Owning a lot of RC vehicles doesn't always mean a lot of knowledge.
roadrashracing is offline   Reply With Quote
Old 05-18-2006, 07:47 PM   #14741
Super Moderator
Trader Rating: 17 (100%+)
rubber bands work.
Tekno | BLOK | JConcepts | RaceReadyProducts | BOOMrc
Bob Barry is offline   Reply With Quote
Old 05-18-2006, 08:28 PM   #14742
Moderator
how will the hpi mod work for rubber and what would be a good setup for mid-high bite rubber, carpet.
Old 05-18-2006, 08:32 PM   #14743
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
Originally Posted by Bob Barry
rubber bands work.
I use them on my car and it does work.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 05-18-2006, 08:43 PM   #14744
Super Moderator
From what I was told the only reason that guys were doing the HPI mod was for durability. It does move the ball stud up 1mm though so you would have to compensate for that in your setup.
Old 05-18-2006, 08:58 PM   #14745
nf_ekt's Avatar
Trader Rating: 113 (100%+)
I did this after hearing of another mi2 racer doing it.... Get a plastic bag (like what spare parts come in) one that is alittle thick, pull the cup of the ball, place the plastic over the ball, then snap the cup back down. It will sandwich the plastic between the ball and cup and take up some slop. I did this for the entire front steering and its a bit tighter. Maybe there's a better technique likethe rubber bands (have'nt tried) but this did work for me, at least so far...
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
