Old 05-14-2006, 08:58 PM   #14686
Super Moderator
Trader Rating: 17 (100%+)
When PW was telling me the stuff that some of the other guys were doing I was sitting there like " there is NO WAY that will work" He agreed that it was completely backwards from what were doing....totally wierd LOL
Tekno | JConcepts | ProTek RC | RaceReadyProducts | BOOMrc
Bob Barry is offline   Reply With Quote
Old 05-14-2006, 09:44 PM   #14687
AdrianM's Avatar
Originally Posted by RKeasler
Adrian was it mostly because his braking and acceleration points were different or what?
Rod
He drives tighter....everywhere. He lets off sooner and brakes earlier than I do and this reduction in speed makes him not blow wide in the corners...like I do.
Adrian Martinez
Old 05-14-2006, 09:46 PM   #14688
mini-dub's Avatar
Trader Rating: 16 (100%+)
I hear he also goes straight down the back straight .
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 05-15-2006, 06:16 AM   #14689
AdrianM's Avatar
Hey now! I got that kink out of my system months ago!
Adrian Martinez
Old 05-15-2006, 06:50 AM   #14690
Scho's Avatar
Send a message via MSN to Scho
http://www.racing-cars.com/products....&pagewidth=550
Scho is offline   Reply With Quote
Old 05-15-2006, 07:04 AM   #14691
brownpants's Avatar
Originally Posted by aus jd 2703
hey whats a good shock length so that i can get droop and ride hight at about 9mm combine?? (4mm droop 5mm ride hight?)
also can u run the same all round??
thanks in advance
I run with 62.5mm shock length all round and using a droop gauge I set it to 2 on the rear and 4 on the front. Not really sure what that converts into mm's?
I am using the low shock towers and TRF shocks. And although I have not tried it, I can run the same droop setting all the way round.
HTH
Darren
brownpants is offline   Reply With Quote
Old 05-15-2006, 10:50 AM   #14692
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Matt Howard
still looking for that first win at SWR?
Made Goss go home cause I held the TQ from round 2 on. Made a slight change for the main and paid the price. It's all testing for the nats. Speedworld is built on top of old slavery grounds or something because I can't catch a break there
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 05-15-2006, 11:02 AM   #14693
STLNLST's Avatar
WOW....and he's been racing how long
Old 05-15-2006, 11:03 AM   #14694
Matt Howard's Avatar
yeah but I received a PM from an "anonymous source" you said this was for the STOCK class Man up and run some mod you cherrypicker
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 05-15-2006, 11:16 AM   #14695
STLNLST's Avatar
I'm running mod at the Reedy.....isn't that enough???? Where's the love
Old 05-15-2006, 04:30 PM   #14696
King-G's Avatar
Send a message via ICQ to King-G
I finally converted to brushless on the weekend!
Nosram 4 star, better than I had expected, but took a few runs to get used to but once dialled in I felt it was equal to a decent 7. but without having to true and change brushes every run it was heavenly!
No going back for me now, more time to wrench on the car and talk shit in the pits.
King-G is offline   Reply With Quote
Old 05-15-2006, 04:31 PM   #14697
heavy's Avatar
Trader Rating: 20 (100%+)
Hi Guys
Currently running a EC (rubber version) with very standard settings, on tarmac using rubbers and very happy wit it and teh setup we have.
This weekend we are racing somewhere different again tarmac but we may have to use foams. What changes would I have to make for foams. Presume less camber and maybe one stiffer spring - anything else?
Honorary Life Member Logan RCCC -Mi6EVO and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6EVO
Boondall. SuperShot, XX, SVR,Schumacher Storm BigWig
heavy is offline   Reply With Quote
Old 05-15-2006, 04:33 PM   #14698
Hey Matt,
Did your "Anonymous Source" tell you that he has shaved his head? I think he lost a bet to somebody......was it you?
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 05-15-2006, 06:09 PM   #14699
King-G's Avatar
Hi Heavy, I would recommend removing the suspension riser plates both front and rear, with the front arm blocks either flat on the chassis or raised just 1mm or so, with the rear arms blocks equal in height or 1mm higher.
Springs is dependant on grip level of track and surface (bumps etc) but 1-2 rates harder than kit would be a good starting point. and possibly the removal of sway bars.
These have been some general findings of mine running foams on the previous Mi2, I havent as yet run foams on the E.C.
perhaps some of the U.S team who have more experience with the foam car can comment, on their general setup changes from rubber to foam.
Old 05-15-2006, 07:33 PM   #14700
STLNLST's Avatar
Originally Posted by Advil
Hey Matt,
The ladies love
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
