Old 02-22-2002, 07:36 PM   #1456
Originally posted by seaball
hey neas,
mcmaster carr has all kinds of bulk screws for our uses. i happen to live 20 min from the warehouse so i can just to a will call and pick them up. they have stainless and aluminum. metric and std thread socket cap screws in flat, button, and std heads. it's awesome. you'll drop a few bucks on the stainless, but it's way nice.
at least check it out at
www.mcmaster.com
all kinds of stuff. they are an industrial supplier. in fact they have lathe bits for like 3.50 in carbide. they also can provide raw materials like delrin, c/f, and fiberglass for machining your custom car parts. well, hope that helps. oh, and schumacher may have some too. what?
For anyone who hasn't checked this site out and are wanting to replace stock screws SHOULD!!! I ordered a box of 100 of each 3x8 and 3x10 phillips in 18-8 stainless. Cost me 5 BUCKS SHIPPED and was to my door in SC in 2 day. They have a distributer on the East Coast in Atlanta also. I couldn't be any happier. They fit PERFECT the heads of the screws seem to me are a tad smaller or atleast the same size as stock screw and fit is beautiful. I would defiantely say besides threaded bodies and alloy cartridges this IS the best "hop-up" I have made. True phillips head and I thought for SURE I had stripped one and NOPE it looked new I thought for sure I messed it up. Anyhow check it out and I PROMISE you won't be disapointed. Plus have ALOT of spares too
wilson10 is offline   Reply With Quote
Old 02-22-2002, 08:15 PM   #1457
Hey Guys guess what????????????????????
I GOT MY MISSION TODAY!!!!!!!!!!!!!!!!!!!!!!!!!!!
hehheheeheheehehehehehehehehehehhehehehehehehehehe hehehehehehehhehehehehehehehehehhehehehehehehehehe hehhehehehehehehe now I just gotta order me hop-ups and I will build it.
Later
IKE
FoamDonuts is offline   Reply With Quote
Old 02-22-2002, 08:39 PM   #1458
Tractionroll's Avatar
What is the part number for the heavy anti roll bar that people are using?
Tractionroll is offline   Reply With Quote
Old 02-22-2002, 08:41 PM   #1459
Trips's Avatar
Trader Rating: 16 (100%+)
Tractionroll,
Did the car get there today?
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 02-22-2002, 08:53 PM   #1460
Yes I received it today, looks good. Thanks
Old 02-22-2002, 10:14 PM   #1461
Oasis2001's Avatar
Send a message via ICQ to Oasis2001
AdrianM - A while back I was admiring a pic of your car from this board and I was wondering if you could send me the pic again please? I have been stupid and deleted it by mistake
Oasis2001 is offline   Reply With Quote
Old 02-22-2002, 10:27 PM   #1462
Mopar's Avatar
Hey Tractionroll, had to search back to my Axis manual, but I found the number you want. U2245P Competition Roll Bar Set - SST. That is straight from the book, but drop the "P" when you order it. As per the discription the part goes back to the origanal 2000 car. Hope this helps.
Schumacher KF2se, Associated B5m CE (sold), Hot Bodies D413, Associated T5m, Axial Exo Terra, Schumacher Mi5, CRC 1/12, 3Racing FGX full suspension, Associated 18r
Mopar is offline   Reply With Quote
Old 02-23-2002, 01:08 AM   #1463
Oasis here are the pics of Adrians Mission.
IKE
Old 02-23-2002, 01:08 AM   #1464
oops I guess that was someone elses oh well gives you an idea.
IKE
Old 02-23-2002, 05:14 AM   #1465
Ok, how do I get the competition anti roll bar set. Schumacher does not list the 2245 as a part number. Anybody know where I can order it from?
Old 02-23-2002, 05:25 AM   #1466
Call Adrian or Paul at Schumacher and ASK them for the competition kit and they will hook you up!! Simple as that!
Old 02-23-2002, 08:08 AM   #1467
AZ_Ron's Avatar
Default WANTED:
Hey guys...I spent a couple of hours last night tearing my Axis2 apart and rebuilding the diffs and TOTALLY changing the seyup on it to one that Adrian recommended. I've got a regular diff in the front now, but in all the tons of spare parts I have for the car, I don't have a standard layshaft...just the ABS one...anyone have a standard layshaft taking up space in their box they'd be willing to part with??
Drop me a line, and let me know what you're asking for it...
Thanks!
Ron
AZ_Ron is offline   Reply With Quote
Old 02-23-2002, 08:15 AM   #1468
Send a message via ICQ to SirSpeedy Send a message via AIM to SirSpeedy Send a message via Yahoo to SirSpeedy
If you have the ABS system, why not just tighten the nut down and lock it up?
Tim Davis
SirSpeedy is offline   Reply With Quote
Old 02-23-2002, 08:33 AM   #1469
AZ_Ron's Avatar
Default I was wondering about that
Hey Sir Speedy....I wondered if that was possible, but since I'm pretty new to the Schuie stuff, so I'll do that...
Thanks!
Another thing I was wondering about...I got a TON of spare parts with this car, and the upper suspension mounts I have (about 10 of them) are two different kinds...one is set up for hole position 1, and one is setup for hole position 2...none of them have the 1 & 2 holes on the same mount like it seems the new ones have...Are these just older mounts? Not a big deal, but if that's the case, I'll order a couple of the new ones when I make an order to Speedtech or Adrian, and get them...as it is now, if I want to change the upper arm mounting position, I have to change the mounting plates and move the shock towers over to whichever plate I use...
Thanks guys!
I LOVE this forum!!
Ron
Old 02-23-2002, 08:56 AM   #1470
big al's Avatar
Hey Az, You probably have a set of the original Axis Upper mounts and a set of '98 upper mounts. Many schuie guys put on the '98 upper mounts to get a little cornering speed. I never really saw any orginal Axis that used the original upper mount. Hope that helps--Al
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
