Old 05-14-2006, 12:51 PM   #14656
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally Posted by Bob Barry
Have any of you tried going to the outside hole on the rear hub? I know it was talked about on carpet....not sure if anyone has tried it yet on rubbers
If you try that at Frederick you will never get your car to turn!!!!!!!!!! It makes alot more side bite. I did this along on offroad and it makes a huge differance in the side traction in the rear.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
wyd is online now   Reply With Quote
Old 05-14-2006, 12:55 PM   #14657
Super Moderator
Trader Rating: 17 (100%+)
yeah kinda what I figured. never hurts to ask though. On my buggy's we used to move the link out...keep it the same length but slide it out one hole. Hard to describe what it did but it was always faster.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 05-14-2006, 01:50 PM   #14658
wyd
Tech Legend
wyd's Avatar
Well if you ever to go a place that is really loose then just move the rear ball stud out on the rear hub and you will have some extra traction.
Old 05-14-2006, 02:00 PM   #14659
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Thats great, since my biggest problem yesterday was sliding the rear of the car.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 05-14-2006, 02:14 PM   #14660
Jon Kerr's Avatar
Bob- I ran the outside hole a few times at SoCal. It makes the back end really lazy. Makes it easy to drive if you're having trouble with the back end being too twitchy, but I don't think it's a fix, more of a band-aid.
David- Glad you liked the car. It'll just get better.
I had a good night at SoCal. The setup Donny and I came up with using some of his experience there with the original Mission worked really well. We've got a few more things to work with but I was really happy with it.
Jon Kerr is offline   Reply With Quote
Old 05-14-2006, 02:22 PM   #14661
hey whats a good shock length so that i can get droop and ride hight at about 9mm combine?? (4mm droop 5mm ride hight?)
also can u run the same all round??
last but not least how do u get the rebound and dampening the same all round so the car isnt tweaked
this is on an old mi2 with carpet/low towers and running cut down stock shocks??
thanks in advance
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 05-14-2006, 03:04 PM   #14662
justin lessard's Avatar
Send a message via AIM to justin lessard
actually,that is what i run,but I have NO problem with getting the car to turn
justin lessard is offline   Reply With Quote
Old 05-14-2006, 06:23 PM   #14663
wyd
Tech Legend
wyd's Avatar
I think your overall setup is more than likely alot more aggressive than what Bob would normally run.
Dave when I first ran my car it was loose int he rear. I simply shortened the rear wheel base some and that helped a ton. The rear arms have 4 different postions so try the mid/short setup before you try moving the rear ball stud out on the hub.
Old 05-14-2006, 07:37 PM   #14664
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
Anybody who races stock or 19T should at least give Justin's set-up a try. His car was decent at the beginning of the day, but I gave him a few suggestions to try, and his car is really fast now. It has also been fast at a few other tracks as well, so I would definately try it.
Team Associated~Reedy~Werks Racing~Pro-Line~Competition Suspension Inc.~Schelle Racing Innovations
Brandon Melton is offline   Reply With Quote
Old 05-14-2006, 07:39 PM   #14665
Super Moderator
Im just running a pretty vanilla setup. only had 5 packs through the car. Not really enough to start making all kinds of changes yet. I made that mistake with the carpet car. I went out and tried a different setup every single run and I couldn't get a feel for how I liked the car. This time I am going to be more patient. I already showed that with no power and no experience with the car, I could run respectable times. The lap times will be there. I just have to keep on doing what I am doing.
Old 05-14-2006, 07:49 PM   #14666
mini-dub's Avatar
Trader Rating: 16 (100%+)
The outside hole on the rear hub will give you a longer rear link , but I'm not done yet . A long link should make the rear end really stable and lazy, if the rear end does break loose the slide should be much more controllable and predictable. But a long link doesn't always give you more rear traction, it's just a lot more stable. I've felt that a short link actually gives you more traction initially, but it will roll over very fast which transfers weight very fast causing the rear end to get loose quickly and the slide will be more unpredictable. A short link should make the car transition better because it transfers weight faster but it's not as good generally in hard tight corners, such as 180s.
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 05-14-2006, 07:50 PM   #14667
nf_ekt's Avatar
Trader Rating: 113 (100%+)
The only problem I have with the AE's is the inconsistancy. They tend to differ alot from spring to spring. Might sound wierd but we always issue tweaking the car on scales for carpet, switched to Xray and it was right on the money just about every time.
I still plan on trying them though....
Is there a simple way to test each spring? I dont doubt what your saying I know AE quality suffers in some areas. fortunantly the springs are real cheap I'd pick up a few sets and take the most equally-matched ones if there was a way to compare them.
As for know, I will say the car is good with the silvers. Maybe I will give the xrays a run (what color is closest?)
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Old 05-14-2006, 07:53 PM   #14668
mini-dub's Avatar
Xtreme did an article on the consistancy of each companies springs a while ago, Xray, Schumacher, and I believe HPI were the most consistant of the companies tested.
Xray yellows are 14lbs, but I think they have a blue-green or something that is 15lbs too. Those 2 springs would be the closest to an AE silver or Schue white.
Old 05-14-2006, 07:54 PM   #14669
Super Moderator
I guess you could get one of those spring dyno thingys but I dont have the time or patients for that. Xray Yellows are 14LB springs, same as Shuie Whites. Xray Whites are 17.5 I would just get those two sets and call it a day.
Old 05-14-2006, 07:55 PM   #14670
Super Moderator
Hey Weylin whats up? Getting ready for the Reedy?
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
