Old 05-10-2006, 01:23 AM   #14611
hey guys can i have a base line set up for an mi2 with the lower shock towers?
ive been running 20lbs springs and no sway bars
the grip is medium/high but its getting cold track temp was bout 15'celcius so i will try sorex 28r next i was running 36'r but it was like ice for 6 laps slidding and looped a few times
any way this is the track lay out it 198m long so i thinkk the back straight must be about 30m long and it has boral top coat on it (it's like a grip paint works well)
http://www.lcrccc.com/track/MeakinLayout.JPG
any suggestions would be great or old set ups would be nice.
thanks all
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 05-10-2006, 01:43 AM   #14612
scott_g's Avatar
Send a message via MSN to scott_g Send a message via Skype™ to scott_g
Originally Posted by DavidAlford
Whats the best setup to start with for indoor concrete low-medium bite?
David, I haven't run indoors, but have run outdoors on concrete. Car was very good, basically working around softening it up for more roll and hence more grip, plus a few other minor changes.
Go here for the setup (track is called Bayside)
Cheers
Scott
schumacher, speedpassion and more plus race blog at www.actionrc.com.au
twittering @ scottyg_rc
scott_g is offline   Reply With Quote
Old 05-10-2006, 04:38 AM   #14613
Hey Dave, start with the stock EC set-up at Enid, let me know if you need a car to try.
Monte Hess is offline   Reply With Quote
Old 05-10-2006, 06:53 AM   #14614
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Its ok, I got my own to run lol
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 05-10-2006, 08:31 AM   #14615
This car comes with tape, how pimp is that
Old 05-10-2006, 08:38 AM   #14616
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Nice big roll of strapping tape.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 05-10-2006, 08:59 AM   #14617
Super Moderator
Trader Rating: 17 (100%+)
I am running Pdub's Speedline setup and it's dialed
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 05-10-2006, 09:44 AM   #14618
Jon Kerr's Avatar
Originally Posted by nf_ekt
I've come to trust the M6 on asphalt, but now I want to try the parma alpha. I see the parma wing as small and too flexible, but maybe with a protoform wing it would hook well on aspalt. Anyone thats given it a shot lmk, or I'll just try it any ways
Like Weylin said, the Parma is more for Foams on carpet. Low down force. It may make the car slide around a lot. Stratus 3.0AP is a high down force body and should really plant the car. If you want to try something different, try one of the Ride bodies.
Originally Posted by piorc
Hey guys, just a question.
in the lap time, which is the difference between a mazda 6 body and a bad body( like one of tamiyas populars for example)
tks
There's really no way of telling how much time you'll loose on a lap, but in most cases, you won't be competitive depending on what "scale" body you choose.
John Kerr- I like the aluminum rear hubs, spaced fully forward on the rear arms at 3 (1 deg insert) degrees the car was very stable and on track. Might try the 0 deg insert to get sharper rotation on tighter tracks.
What about the HPI R hubs? doe they work well? Thanks as always.
Do you have the alloy rear pivot blocks on the car? If so, I'd suggest trying the 0 inserts in the rear hubs and moving them to the center. It should help the rear end rotate well.
The HPI hubs have a different offset than the alloy hubs. We used them on the chassis we had for Vegas that was kind of the predecessor to the EC chassis. The pivot block mounts are wider on that chassis moving the arms out. We used the HPI hubs to pull the wheels in more to make the car legal.
Jon Kerr is offline   Reply With Quote
Old 05-10-2006, 10:00 AM   #14619
Sanabria's Avatar
What are these inserts for the rear hubs? Are these Schumacher parts?
TIA
Sanabria is offline   Reply With Quote
Old 05-10-2006, 11:11 AM   #14620
PW
PW's Avatar
Send a message via AIM to PW
TIA
They are the option hubs for last years Mi2; wont work on the Mi2EC
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 05-10-2006, 11:29 AM   #14621
Sanabria's Avatar
Ah, ok. Thanks Paul, see ya Saturday at Speedline.
Old 05-10-2006, 02:14 PM   #14622
hey guys can i have a base line set up for medium to medium high traction prepared aphsalt/tarmac??
its a non ec mi2 please my car was very hard to drive last time and im not sure it was all tire choice.
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 05-10-2006, 02:33 PM   #14623
AdrianM's Avatar
Mini Dub (Weylin Rose) had the best all around Mi2 setup.
Adrian Martinez
Old 05-11-2006, 04:40 AM   #14624
wyd
Tech Legend
wyd's Avatar
Here is a pic of me at the ORL2 race. I'm the guy in the center pic with the Schumacher shirt!!!!!!!!!!!!! Sorry to scare you guys like that.
Here is the website with the ORL2 info if you want to check it out. The series is sponsored by Schumacher. www.outlawracingleague.com/orl2main.html
Old 05-11-2006, 04:44 AM   #14625
John Tag's Avatar
Trader Rating: 42 (100%+)
Brian.. Looks like you wife is cooking good for you... Congrats for that great run...
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
