Old 02-21-2002, 09:46 PM   #1441
Trips's Avatar
Trader Rating: 16 (100%+)
Tractionroll,
Try it the way I sent it to you first, that setup won the A in stock its first and only day out... TRC Purple rears and Plaid fronts and you should be close. IF anything you might want to make the car a bit more aggressive for a high traction carpet track, Bruckner (the track I raced at) is medium grip at best.
If you want it more aggressive try hooking up the rear swaybar or reducing the rear toe-in a bit. The car should be pretty nice as it is though.
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 02-21-2002, 09:51 PM   #1442
Sigearhead's Avatar
Trader Rating: 68 (100%+)
Default tractionroll
tractionroll:
look back a few pages and use PW's cleveland setup. It is a great starting point. From there you can tweak it further to your track and your driving style. Good setup!!
Sigearhead is offline   Reply With Quote
Old 02-21-2002, 09:58 PM   #1443
Tractionroll's Avatar
Trips
I never received a set up from you.
Tractionroll is offline   Reply With Quote
Old 02-21-2002, 10:07 PM   #1444
Trips's Avatar
I sent the car to you set up the way I ran it... I didn't change anything except to replace the chassis and I installed the titanium lower hingepins.
Unless you're running on a very grippy carpet track I think you'll like the way the car drives as it is now. If you're on a very grippy track you'll probably want it to be more aggressive.
Trips
MARSHAL!!
Old 02-21-2002, 10:11 PM   #1445
Trips's Avatar
Tractionroll,
Before I forget to ask... are you satisfied with the deal?
Trips
MARSHAL!!
Old 02-21-2002, 10:14 PM   #1446
Dont know, have not received it yet. I already have one.
Old 02-21-2002, 11:14 PM   #1447
Trips's Avatar
Oops, my mistake... I thought it would have gotten there today. You should have it tomorrow.
Trips
MARSHAL!!
Old 02-22-2002, 01:43 AM   #1448
Send a message via ICQ to JesseT
Cornerspeed:
It's a genuine JRP product (Jesse's Racing Products ;-)
My Sanwa-ERG-XS servo was too small to fit to the standard servo posts, so I had to make one. I've always liked the one-piece design anyway. I had a similar on my Axis too.
JesseT is offline   Reply With Quote
Old 02-22-2002, 01:48 AM   #1449
And some other parts that make the car turn 0,0s faster laptimes...
Old 02-22-2002, 02:00 AM   #1450
That servo strap is cool lookin'. How'd you make it?
Stika525 is offline   Reply With Quote
Old 02-22-2002, 04:37 AM   #1451
We have a table-top drill at work, with a feeding table. That is not far from a milling machine practically is you just purchase some milling bits for it. After machining I always anodize the parts to make them stronger, especially the threads. Anodizing is quite simple and fun to try at home if you're interested. Here's a good link.
If someone plans to make a similar servomount, you have to be carefull because there is not much room for it. If you look at my Mission (the picture was posted somewhere earlier) the part needs to be really thin in a coulpe of places, especially over the servo. You also need to be carefull with the copyright laws ;-)
http://www.focuser.com/atm/anodize/anodize.html
Old 02-22-2002, 05:15 AM   #1452
Send a message via ICQ to MattW
Just got the new upper deck, feels like it may well make the car quite a bit stiffer and so help on high bite tracks. I shall hopefully get the chance to try it out this weekend.
MattW is offline   Reply With Quote
Old 02-22-2002, 06:22 AM   #1453
Yes, when the traction comes up, a stiffer chassis makes the car more nimble. The car also carries it's speed better through the corner and even help prevent traction rolling. You can not achieve the same with harder springs/roll-bars.
Old 02-22-2002, 07:36 AM   #1454
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
I got my new upper deck on and I am going to try it this weekend also. I hope it helps with the traction roll problem since I run on a very high bite track.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 02-22-2002, 07:50 AM   #1455
Default Hey Dave!
Have you looked at the droop on your car? I have found that the amount of droop will affect how much a car can roll thru a corner. A car that rolls to much will eventually traction roll. Reduce the amount of droop both front and rear and Think you will see the problem go away. Just food for thought.
SWG
simulatedwood is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
