Old 05-02-2006, 08:23 AM   #14491
Super Moderator
Trader Rating: 17 (100%+)
I guess what you can do is check the temp on your motor after 5 min. With a fan on it you should be able to run around 160 deg before feeling a fade in power.
Tekno | JConcepts | RRP | LutzRC | BOOM RC
Bob Barry is offline   Reply With Quote
Old 05-02-2006, 10:41 AM   #14492
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Jon are you running the carpet car or the rubber tire car? Is the carpet car alright on asphalt?
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 05-02-2006, 11:01 AM   #14493
Jon Kerr's Avatar
Both. I'm running the rubber car outdoors and the carpet car at SoCal. SoCal has massive grip (maybe not as much as carpet but more than any outdoor track I've ever seen or heard of.) So the stiffer chassis seems to really help there. I have modified the top deck on the SoCal car though by cutting most of the center braces to get a little more flex. But no where near what the outdoor car has. I'm sure the carpet car will work outdoors with a few modifications. If you're not going back and forth too often from carpet to asphalt, you can simply change the chassis, top deck, shock towers and add the risers under the bulkheads and you've got an outdoor car.
Jon Kerr is offline   Reply With Quote
Old 05-02-2006, 11:10 AM   #14494
Both cars come with a front spool?
Old 05-02-2006, 11:12 AM   #14495
Jon Kerr's Avatar
Rubber kit comes with a spool, foam kit comes with a front diff.
Old 05-02-2006, 11:14 AM   #14496
I really should read up on this stuff lol
Old 05-02-2006, 11:18 AM   #14497
Jon Kerr's Avatar
Yeah you slacker! Really though, let me know if you need anything. I'm going to be out that way in August for the weekend. If I can get away, I'll see if I can come check out a race. I can't remember the exact date off the top of my head.
Old 05-02-2006, 01:09 PM   #14498
Skiddins's Avatar
Originally Posted by RAL
eh Mates,
I have a buddy of mine who will let me run his old Mission. The first mission. What do you guys think about it? Do you still think it can be competitive? I'm a decent driver and just don't have the cash to buy one of the newer TC's
Thanks a million!
Although not the latest car, it is still a good car to run and setup, and you should still be able to get closer to the fast guys than you think. I did
Skiddins
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-02-2006, 01:45 PM   #14499
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
This is a really dumb question, but what is the difference between a spool and a diff? Is a spool like a one way?
Owning a lot of RC vehicles doesn't always mean a lot of knowledge.
roadrashracing is offline   Reply With Quote
Old 05-02-2006, 01:47 PM   #14500
A spool is a locked diff. So its like a oneway but you can use breaks. Lots of punch out of the corner. Takes awhile to get use to using one though.
Old 05-02-2006, 01:56 PM   #14501
Moderator
Ok, my car had a lock diff in it and was very hard to drive, so I put a reg. diff in. Thanks for the answer, I guess I should learn my rc defintions.
Old 05-02-2006, 01:59 PM   #14502
Super Moderator
What I want to know is does anyone make any one way bearings for the idler pully....I would love to try the one way spool setup.
Old 05-02-2006, 08:30 PM   #14503
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Hi guys, on my mi2 ive got a teemu 3700 bottom deck, and for some reason my 3700 and 3800batts still come out .
I saw on pro4's on the side of the battery slots they have 2 little plastic holder thingo's. Will they fit on my mi2?
Thats the way i was thinking of fixing my batts from coming rite out
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIGE BEARINGS*
A Ilievski is offline   Reply With Quote
Old 05-02-2006, 08:42 PM   #14504
mini-dub's Avatar
Trader Rating: 16 (100%+)
The battery probably is able to come out because of insuffecient pressure or fitting of the battery strap, if you have shims under the battery bar posts try taking them out or putting in thinner ones. Make sure you don't make the posts too low or you will have to flex the bar and then it will tweak the chassis. The other reason that could cause the pack to eject is the chassis isn't filed enough so the cells are sitting too high in the slots so the sides of the slots can't keep the pack in. You want to have the cells sit flush or slightly above the bottom of the chassis. Put a pack in and look underneath to see how low they are, then file the slots till the pack sits at the proper level. One more thing, using strapping tape to hold your batteries in is a better way, it wont tweak the chassis like a strap can and it holds the pack better, it all depends how much you hate tape .
Rain City Raceway's online store has a bunch of Schue part for clearance on their website. Go to www.raincityraceway.com/store to find them. I believe everything is 30% off street price, there isn't a huge amount of parts but there could be just what your looking for .
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 05-02-2006, 09:17 PM   #14505
nf_ekt's Avatar
Trader Rating: 113 (100%+)
Hard to drive? Hmmm. I dunno on that,I will say that the spool lets me drive the car as agressive as I want, and out of the corners it goes where I point it. Learn to feather the throttle a bit in wide, sweeping corners and it wont seem so hard-go in hot and let all the way of your goin wide. Spool is it on alot of asphalt tracks it equals RIP!!!!!!!!!!!!!
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
