Old 05-01-2006, 02:27 PM   #14476
John_S's Avatar
hey guys i had my first outing with ec on sunday and won but had a bit of a handling niggle that i would like to get sorted before the scottish gp in june. The back of the car is over rotating when i put the power down exiting some of the slower corners and just goin sideways i was wondering if anyone had any thaughts on how to solve this cheers, if theres anything you cant read on the setup sheet just ask
John_S is offline   Reply With Quote
Old 05-01-2006, 02:44 PM   #14477
AdrianM's Avatar
Give Chris Ashton a call at Schu UK tomorrow: (0) 1604 790770. He races under similar condition to you and would give you the most accurate setup suggestions.
In the mean time I would say you need 3 hole pistons, less static camber, more front and rear droop, the rear hinge pins could be lowered 1mm and the shocks could be stood up one hole all around.
Adrian Martinez
Old 05-01-2006, 02:46 PM   #14478
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Try standing the rear shocks up one position or raising the rear inner camber link to the high location.
Jon Kerr is offline   Reply With Quote
Old 05-01-2006, 08:34 PM   #14479
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
What should I be running for a spur gear on a fast carpet track with rubber tires. I am running a 120 right now and almost 2 secs. off the pace. Would like 128 give me a little more speed?
Owning a lot of RC vehicles doesn't always mean a lot of knowledge.
roadrashracing is offline   Reply With Quote
Old 05-01-2006, 08:44 PM   #14480
Jon Kerr's Avatar
The size of the spur doesn't really matter. It's the gear ratio. Also what motor are you running and what pinion are you running right now. 2 seconds off a 5 minute run or 2 seconds off per lap?
Old 05-01-2006, 08:48 PM   #14481
Moderator
I'm running a stock monster with a 30 tooth pinion. Between 1.5-2 seconds a lap. Most people are running the c027. Does that motor make a big difference?
Old 05-01-2006, 08:50 PM   #14482
Moderator
I know my driving is a little bit to do with it but I would like to be up there.
Old 05-01-2006, 09:14 PM   #14483
Jon Kerr's Avatar
Your gearing is just about right. You're at a 7.2 FDR and that's right about where stock motors need to be I believe. [(Spur/Pinion)*1.8= FDR] You're at least in the ball park. Not 2 seconds a lap off. So I don't think lack of speed is the problem. Just practice driving clean lines and staying off the dots and you'll be surprised how quick your lap times fall. More speed isn't usually the answer. Every time you run a car width wide in a corner, that's 1-2 tenths. Go way off line, there's .5 sec. Do that 2-3 times a lap, there's your 1.5-2 seconds. Keep those lines nice and tight and smooth, you'll pick up considerably. Then you can go for more rip.
Old 05-01-2006, 09:17 PM   #14484
Moderator
thanks for the advice. I guess 2 seconds is not bad ether for having the car out for the first time.
Old 05-01-2006, 09:19 PM   #14485
Super Moderator
once you clean your line up some you can gear the CO27 around 5.5 or so, just use a fan on the brush hood. The CO27's run cooler and have more tourque I think I was running a 30mm rollout at Horsham.
Tekno | JConcepts | RRP | LutzRC | BOOM RC
Bob Barry is offline   Reply With Quote
Old 05-01-2006, 09:21 PM   #14486
Jon Kerr's Avatar
Oh that's right, all you rug rats deal in roll out, not "normal" gearing.
Old 05-01-2006, 09:24 PM   #14487
Moderator
How do you figure rollout on the ec? I have a book for the mi2 and really don't understand.
Old 05-01-2006, 10:30 PM   #14488
A Ilievski's Avatar
Trader Rating: 39 (100%+)
go to www.gearchart.com
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIGE BEARINGS*
A Ilievski is offline   Reply With Quote
Old 05-02-2006, 12:39 AM   #14489
ottoman's Avatar
R/C Tech Charter Subscriber
5.5 RoadRash runs on a small to medium size indoor carpet track... We all ran in the 7.1 - 7.4 range this weekend at the Rubber Tire Nats at Trackside with CO27's. I think a 7.2 at Victory would be way too high for a Monster and probably too high for a CO27.
Roadrash.. we might make the trip to Victory this weekend... stop over and I will let you know what FDR we are running
ottoman is offline   Reply With Quote
Old 05-02-2006, 08:21 AM   #14490
Super Moderator
Oohh ok didnt relize he was on a small track. How big is trackside? I never thought of Horsham being that big but maybe it is....I think its like 55x95 but don't quote me
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
