Old 04-25-2006, 09:04 PM   #14416
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Yes they will. They just need to be shimmed different.
Jon Kerr is offline   Reply With Quote
Old 04-25-2006, 10:22 PM   #14417
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Advil
Things slow at Popeye's today STLNLST? LOL
Hope you're feeling better.....
I'm feeling better and better with every remark you make. I just want to get out and run my car I still gotta get my first win at Speedworld this year.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 04-26-2006, 05:52 AM   #14418
HarshGuy's Avatar
...dude I'm setting my goals even lower ...I just want to run a main at SWR this year!! ...I hope this wierda$$ weather means we're just skipping spring and straight into summer, otherwise we're gonna be really good friends with tire warmers on RP36's for the nats
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 04-26-2006, 06:16 AM   #14419
STLNLST's Avatar
I have some on standby just incase the weather warms up this weekend. Other than that I'll be running RP30's.
Old 04-26-2006, 06:44 AM   #14420
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
What 64 pitch spur size are most of you going with on your EC's? I have a buddy thats building one and don't have computer access right now.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 04-26-2006, 06:50 AM   #14421
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
118t = 89t
115/116t = 86t
112t = 83t
The above are basic conversions from the standard EC spurs to aftermarket 64dp.
Personally, I use either 118t (mod) and 116t (19t). And mainly RW spurs.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 04-26-2006, 06:54 AM   #14422
Originally Posted by Jon Kerr
I've only liked the oneway indoors at SoCal. Outdoors it's always been too twitchy and hard to drive. I've got a really good setup I think for SoCal that you can try outdoors. It's never been tested there but it may be worth a shot. The first thing I'd do to it to run outdoors is go one rate lower on the springs. Drop me an Email (jkerr0043@cox.net) and I'll send it to you. It's on an Excel setup sheet I have.
Hi Jon, Thanks for providing your setup. Have tried it and some slight mods for it and I must say that at this stage I prefer to go back to a spool (just safer to drive in the 'heat of battle'.... cleanly - IMO). But I will be working on a modified oneway setup durning testing and practice over the coming months to see if I can get the lap times down and also keep the consistency the same.
Old 04-26-2006, 07:01 AM   #14423
wyd
Tech Legend
wyd's Avatar
Originally Posted by DirtyDog3375
118t = 89t
115/116t = 86t
112t = 83t
Thanks. I will pass that info on.
Old 04-26-2006, 04:02 PM   #14424
nemisis's Avatar
heyi was wondering if anyone can hel-p me i had a bit of a problem tonite my driveshatf had a tendency to keep locking up on the hub carrier i was wondering if anyone could help me
i was wondering if it could be a faulty shaft coz i have only had the car for two weeks it did have a good nites racing tonite but the drive shaft was the only problem
thnaks in advance
nemisis is offline   Reply With Quote
Old 04-26-2006, 04:11 PM   #14425
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
thnaks in advance
Has the pin come loose and is the pin locking up on the hub or is there something else going on? If its just the pin then loosen the set screw and push the pin back into place and tighten the set screw back down.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 04-26-2006, 04:35 PM   #14426
P-DUB's Avatar
thnaks in advance
There was a problem with the stock CVDs (pins breaking or coming out), contact Schumacher direct for a warranty replacement
Larry Pryor
P-DUB is offline   Reply With Quote
Old 04-26-2006, 07:16 PM   #14427
Nemisis, If the pin isn't broken, could you pull the drive shaft out of the car and post a picture of it? This might be very usefull.-Jeff
Jay Dub is offline   Reply With Quote
Old 04-26-2006, 07:17 PM   #14428
A Ilievski's Avatar
Trader Rating: 39 (100%+)
HELP ME PLEASE.
I was racing my mi2 and one of the bottom king pins on my front alloy knuckles came off and i coudnt find it. Is it possible to buy them or do i have to buy 2 new alloy knuckles again?????
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIG BEARINGS*
A Ilievski is offline   Reply With Quote
Old 04-26-2006, 09:05 PM   #14429
heavy's Avatar
Trader Rating: 20 (100%+)
Originally Posted by kid TT-01
HELP ME PLEASE.
part number U2776 contains teh bits you want 2- upper and 2 lower and 2 grub screws. All up about $12 in Australia.
Honorary Life Member Logan RCCC -Mi6EVO and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6EVO
Boondall. SuperShot, XX, SVR,Schumacher Storm BigWig
heavy is offline   Reply With Quote
Old 04-26-2006, 10:35 PM   #14430
nf_ekt's Avatar
Trader Rating: 113 (100%+)
HELP ME PLEASE.
I can guarantee you this... use threadlock on the grub screws or it WILL happen again. I had this happen to me twice before using some blue tl. after that no worries.
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
