Old 04-23-2006, 09:04 PM   #14401
mini-dub's Avatar
Trader Rating: 16 (100%+)
A center oneway allows for the front belt layshaft pulley and everything forward of that to freespin (oneway) off throttle. So in a sense it wouldn't make much of a difference with a front oneway too, but you could run a spool in the front and have locked front wheels that freespin off throttle or a diff in the front for a oneway differential action. But I've never seen any car run better with it which is why we've never developed one, like Jon said it isn't necessary.
Schue white springs (14lb) all the way around seem to work great on tons of surfaces, I've run that on indoor asphalt, outdoor asphalt, and carpet with rubber tires. I put a schue blue (16lb) on the front of my car right now because on a tight carpet track the whites were too lazy and not responsive enough. I always run a lighter oil on rubber tires (25-35wt) with generally a 5wt split, running a thinner front oil. Right now I'm running 25wt front and 30wt rear because it made the car much more responsive. And btw Jon the green spring is rated at 18lbs
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 04-23-2006, 09:10 PM   #14402
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Yeah but looking at my chart that I got from the spring dyno tests in XRC, they're actual rate is 17.4#
Jon Kerr is offline   Reply With Quote
Old 04-23-2006, 09:33 PM   #14403
hey what oil in non ec shocks ie old shocks with the vari click pistons??
ok ill try and pick some new springs up but i can only run what i got next practice as the guymay not be there
Heavy how much for schumacher pro springs??
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 04-24-2006, 02:07 AM   #14404
heavy's Avatar
Trader Rating: 20 (100%+)
The set (6 pairs) is $30 (in stock)
Individual pairs (not in stock at the moment) are $6 pair.
I will be tehre tomorrow night at this stage.
Honorary Life Member Logan RCCC -Mi6EVO and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6EVO
Boondall. SuperShot, XX, SVR,Schumacher Storm BigWig
heavy is offline   Reply With Quote
Old 04-24-2006, 02:46 AM   #14405
thanks mate did you have that 39t pinion just thought save a fone call
thanks for letting me know illsee if dad will get me a pack i just bought anovak smart tray so money is a little thin but seya there
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 04-24-2006, 06:22 AM   #14406
STLNLST's Avatar
Trader Rating: 19 (100%+)
going back to old days we most of us Norcal racers ran a yokomo the front oneway was fast but sort of twitchy and when we installed a center oneway along with the the front it seemed to calm things down and made the car a little smoother. The spool is fast with brakes but I still feel that there are sometimes that a oneway is faster.
The current layout at speedworld right now seems like it can be oneway friendly in stock and 19 turn. If we didn't have the Reedy race coming up I'd run a oneway on this layout. We'll see how things pan out next weekend if we get some good weather
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 04-24-2006, 02:42 PM   #14407
heavy's Avatar
yep - 39t ok.
Old 04-24-2006, 04:32 PM   #14408
Super Moderator
Yeah the old tc4 days I loved running a center oneway with a front diff really tight.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is online now   Reply With Quote
Old 04-24-2006, 05:49 PM   #14409
brownpants's Avatar
Originally Posted by nemisis
i have just browsed through the schumacher website (uk) and the new ceramic bearings are available to buy didnt see any of the diff mount bearings though
Here you go Nemisis
http://www.racing-cars.com/products.asp?recnumber=3651
brownpants is offline   Reply With Quote
Old 04-25-2006, 07:34 AM   #14410
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Hey not that old!!!!!!!!!!
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 04-25-2006, 11:57 AM   #14411
Jon Kerr's Avatar
You guys ran a center oneway on a shaft car? Is it like the one on the Kyosho 4wd buggy?
Old 04-25-2006, 12:07 PM   #14412
Korey Harbke's Avatar
Yeah, it was like a one way input shaft.
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 04-25-2006, 03:52 PM   #14413
STLNLST's Avatar
when I use to run the TC3....Jeff Witman made me a cool one off center shaft oneway that was hands down better than anything else on the market. When you lock Jeff in a room for a long period of time he will usually come up with some very cool stuff
Old 04-25-2006, 04:06 PM   #14414
Things slow at Popeye's today STLNLST? LOL
Hope you're feeling better.....
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 04-25-2006, 06:52 PM   #14415
Beeen's Avatar
i need some info on the mi2ec: will the front ball diff and 1-way from the mi2 fit the new chassis?
Ben Coleman
G's R/C: offroad in southcentral PA
BS Racing -- I'm full of it!
Beeen is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
