Old 04-20-2006, 07:34 PM   #14371
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Originally Posted by Jon Kerr
There's only one thing I can think of. Are you using the top screws in the motor plate? We were running without them for a while so that we'd get uniform flex across the top deck on the old car and noticed that we were going through spur gears like nothing. The motor plate and lay-shaft mounts being separate pieces, if the motor plate is not screwed into the top deck, the chassis flex will make it move independently from the lay-shaft, changing the gear mesh. I had a 64 pitch RW gear strip going through a high speed sweeper at SoCal once because of this. Even if the screws are not good and tight, the flex can cause this to happen.
As for what brand of spur gears, I like the RW gears and the PRS gears. If you're using anything other than the stock gear, make sure you notch the pulley where the screws go so that you can mount the screws in the inner holes on the adapter.
Thanks for replying Jon. I have checked that and they are all tight and sqyare. Plus the spur is spinning out of round when on the bench!!! It is soooo frustrating!!!
By the way, do you guys use the 64dp gears or do you stick with 48dp gears???
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 04-20-2006, 08:02 PM   #14372
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Clint- hehe, that's where I had some Rit Dye drip off some parts on the towel.
Dirtydog- if the spur is spinning out of round, the only other thing I can think of is that the alloy adapter is bent if your layshaft is straight. I prefer 64p gears. My cars are so quiet running 64 pitch and you have a much finer control over your gearing.
Jon Kerr is offline   Reply With Quote
Old 04-20-2006, 10:42 PM   #14373
brownpants's Avatar
Just thought I'd post up a pic of my cars as they are.
The one on the left is my SoCal car. EC Foam Spec with the new EA Motorsports KD19 turn motor ready for the Jimmy Babcock points series opener.
The car on the right is my outdoor car. Pretty much a bone stock EC Rubber Spec. This will probably be the car I'll run at the Reedy race.
What are the main differences between the two car setups (foam vs rubber)?
Foam tyres on tourers are'nt so popular in the UK.
Darren
brownpants is offline   Reply With Quote
Old 04-20-2006, 11:01 PM   #14374
nf_ekt's Avatar
Trader Rating: 113 (100%+)
Originally Posted by roadrashracing
I have a bmi bottom deck and I installed a battery strap and trying to install 3800s and they are to wide. Has anyone been able to do this?
just an idea on my part.. if the 3800's simply wont fit, try using a dremel to slightly enlarge the slots. I took my time and got them to fit an older bmi chassis. I also took a different route than the strap: since I still use a variety of batteries(3300, 3700,3800), I found that cutting a length of velcro tape has made it easy to use different batteries. It comes in a roll and you just cut the lenghth you need. Pull it tight over the batteries, then slide it so it is angled in the slots of the bmi (just as the stock strap has a slight angle). So far it has worked without issues. Ofcourse strapping tape works well, and like the velcro wont give any tweeking issues.
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Old 04-21-2006, 06:50 AM   #14375
Jon Kerr's Avatar
Darren
My setup up on my Foam spec car isn't for foam tires. I run that car at SoCal (indoor asphalt with rubber tires) because it's really high grip and the stiffer chassis seems to work better and be much more responsive. There are quite a few differences between the two cars. Thicker chassis and stiffer, thicker top deck, lower roll centers, no riser plates under the diffs, different shock towers with different shock and camber link locations, different rear toe, etc...
Foam tire cars usually are very stiff. Stiff chassis and suspension. The cars usually have so much grip that they usually are trying to take grip away to get the car to flow through the corners.
Old 04-21-2006, 11:52 AM   #14376
Moderator
Trader Rating: 76 (100%+)
aus: RW makes a very good spur gear and they're about as thin as I would want to go.
roadrash: The original BMI chassis was cut for 3300's. Also there are different battery straps from the 3300 era to the larger cells. How old are your chassis and strap?
I'm not sure, they fit with straping tape. I am just going to run my 3300s.
roadrashracing is offline   Reply With Quote
Old 04-21-2006, 12:11 PM   #14377
Jon Kerr's Avatar
Is the pack hitting the posts? That'll happen no matter what chassis or strap you have. Take a dremal and put a small notch in the post where the cells touch. This will allow them to sit nicely in there.
Old 04-21-2006, 01:15 PM   #14378
IslandBwoy's Avatar
Hey guys,
Where are the latest setups al la Paul?
IslandBwoy is offline   Reply With Quote
Old 04-21-2006, 02:09 PM   #14379
AdrianM's Avatar
Originally Posted by IslandBwoy
Hey guys,
PW is at Superior testing for the state race right now. Check in with us early tomorrow. There are a few very small changes that you could do in 10 min to get your EC dialed for Corally Land.
Adrian Martinez
Old 04-21-2006, 02:31 PM   #14380
Jon Kerr's Avatar
Is Superior infested with Corally's like SoCal is? Well, Corally's and T2's.
Old 04-21-2006, 02:31 PM   #14381
nemisis's Avatar
silly question here but i cant remeber wat type of bearings the ec runs on are they ceramic
nemisis is offline   Reply With Quote
Old 04-21-2006, 02:36 PM   #14382
Jon Kerr's Avatar
The kit bearings aren't ceramic but they're a new design over the old blue seal ones. Much smoother and much tighter tolerance so they don't build up slop so fast. Ceramics are or will be (not sure if they have them yet) available for the EC through Schumacher though.
Old 04-21-2006, 02:40 PM   #14383
AdrianM's Avatar
Nemesis - The kit bearings are high grade stainless. We have full EC ceramic kits and individual ceramic pairs of bearings in all necessary sizes.
Jon - Superior Hobbies is the home of Specialized R/C the Corally USA importer. Its all good though. We are all really good friends since we have been racing together for over 10 years.
Its going to be a good race. Tosso is there and so is Jared Scott from Xray.
Adrian Martinez
Old 04-21-2006, 02:45 PM   #14384
Jon Kerr's Avatar
Ah. I see. The Corally guys around here are all pretty cool too. I was trying some different stuff at SoCal last week and Edgar Fialos helped me out a bunch to get things working right.
Old 04-21-2006, 03:12 PM   #14385
nemisis's Avatar
i have just browsed through the schumacher website (uk) and the new ceramic bearings are available to buy didnt see any of the diff mount bearings though
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
