Old 04-20-2006, 02:50 PM   #14356
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally Posted by nemisis
Fantom team stock edition 27 turn
You're running an 8.89 gear with a stock motor. No wonder the car feels slow. You're about 5 teeth under geared. I run that kind of gearing with a 7 turn. Go up to a 23 tooth pinion. This will take you to a 6.97. That should get you in the ball park.
Jon Kerr is offline   Reply With Quote
Old 04-20-2006, 02:54 PM   #14357
nemisis's Avatar
the thingi si thought its not particuarly a big track and it tyends to bring out quick lap times as it is i just seems alittle slow on getting away
nemisis is offline   Reply With Quote
Old 04-20-2006, 02:57 PM   #14358
Jon Kerr's Avatar
That's just way too low of a gear for a stock motor. It's probably getting up to it's full RPM less than halfway down the straight. Give me an idea of the size of the track. 100 foot back straight? 60 foot?What motor is that Fantom based off (Monster, CO27, etc...) Try going up 3 teeth at least. I think you'll be surprised.
Old 04-20-2006, 03:00 PM   #14359
nemisis's Avatar
16 x 8 meters its not particuarly big which i why im so low and its based of the monster yeah
Old 04-20-2006, 03:17 PM   #14360
Jon Kerr's Avatar
Not much smaller than SoCal and the stock guys run 7.0 gear there. I really think you'll be surprised if you try gearing up a little. Also, how are you maintaining the motor. Does it need a cut and re-brush? I'm not sure how many runs guys are getting on brushes in stock now.
Old 04-20-2006, 03:20 PM   #14361
nemisis's Avatar
i have just added new brushes i tend to find that skimmin it tends to not make a diiference sometimes may be it it needs a skim but if i did got up wat pinion size would you sugest
Old 04-20-2006, 03:28 PM   #14362
Jon Kerr's Avatar
I'd cut the motor, put new brushes on it, and go up to at least a 21 tooth pinion. You should notice a significant increase in power.
Old 04-20-2006, 03:30 PM   #14363
nemisis's Avatar
cheers i will give it a try that will ahve to wait till next week thnaks for you tips.
Old 04-20-2006, 03:31 PM   #14364
Jon Kerr's Avatar
Any time.
Old 04-20-2006, 04:52 PM   #14365
hey what brand were those thinner spur gears i think im running rw i think the black and as wide as the kit spur??
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 04-20-2006, 05:12 PM   #14366
brownpants's Avatar
I think they're Trick Bits. But not 100% as it came with the car 2nd hand.
Darren
brownpants is offline   Reply With Quote
Old 04-20-2006, 06:02 PM   #14367
Moderator
Trader Rating: 76 (100%+)
I have a bmi bottom deck and I installed a battery strap and trying to install 3800s and they are to wide. Has anyone been able to do this?
roadrashracing is offline   Reply With Quote
Old 04-20-2006, 06:23 PM   #14368
Jon Kerr's Avatar
aus: RW makes a very good spur gear and they're about as thin as I would want to go.
roadrash: The original BMI chassis was cut for 3300's. Also there are different battery straps from the 3300 era to the larger cells. How old are your chassis and strap?
Old 04-20-2006, 06:50 PM   #14369
Jon Kerr's Avatar
Just thought I'd post up a pic of my cars as they are.
The one on the left is my SoCal car. EC Foam Spec with the new EA Motorsports KD19 turn motor ready for the Jimmy Babcock points series opener.
The car on the right is my outdoor car. Pretty much a bone stock EC Rubber Spec. This will probably be the car I'll run at the Reedy race.
Old 04-20-2006, 07:30 PM   #14370
STLNLST's Avatar
Trader Rating: 19 (100%+)
are those little blood drops to the left of our cars??? Looks like some CSItype stuff.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
