Old 04-18-2006, 11:10 PM   #14326
Send a message via ICQ to MattW
Yes. When you move the wheelbase spacers the big change is that you are actually moving the weight closer to one of the axles. i.e if you move the front wishbones back, you are putting more weight over the front axle.
As far as using the notches go, you need to use 2 allen drivers to support the towers. One from teh front, and one from the rear. Hope that makes some sense.
MattW is offline   Reply With Quote
Old 04-18-2006, 11:54 PM   #14327
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally Posted by IslandBwoy
Next question: Is there any difference in how the car would drive if you shortened the wheelbase by spacing the front end back by 1 mil vs. spacing the rear forward by 1 mil???
The car will rotate more. It'll gain steering and the rear will rotate around better.
Jon Kerr is offline   Reply With Quote
Old 04-19-2006, 03:47 AM   #14328
hey
whats a good shock length for the lower towers?
i have 65mm is that all right?
also will i still be able to use schumacher springs??
thanks all oh i went to screw a nut on the shock shafts cause i was going to shorte them and it wouldnt thread on it was 3mm so i tried 2 other 3mm nuts and none would screw on any of the shock shafts? i know it stupid but it stops the shaft from buring after being cut also am i better to use a dremel with cutting disk or hacksaw??
thanks all
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 04-19-2006, 03:10 PM   #14329
nemisis's Avatar
hey guys thanks for the tips they really helped out tonite i was moire competitive tonite. i think im slacking a little speed though i dnt know it may just be that i need to get used to drivin the car a bit more i dnt know i admit it is a little differnt to the standard mi2
nemisis is offline   Reply With Quote
Old 04-19-2006, 03:48 PM   #14330
Hey guy's I'm curious what a good roll out for both 19 turn and stock.
the motors are
co 27
and soon to arrive the Komodo dragon 19turn
cyrrus is offline   Reply With Quote
Old 04-20-2006, 03:55 AM   #14331
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default Superior
PW put the hammer down on Tossolini @ FSEARA Race 3!!!!!!!!!!!!!
Good Luck Bro..................
OH are you going to be running the Sphere or are you going back to your trusty Reedy Ti's
Regards,
Eric
RED-LINE M03 is offline   Reply With Quote
Old 04-20-2006, 04:34 AM   #14332
hey guys have u had problems with the front belt rubbing the spur gear?
my belt is about half a mm from the spur are there such things as thin spur gears??
just worried its gona eat my new r12 belt up?
any idea i moved a front shim so its 2 on left 1 on right but i left the rear so it doesnt move the rear belt.
anything else i should do??
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 04-20-2006, 07:47 AM   #14333
Jon Kerr's Avatar
If all the shims are in the right position, there will be no problem with it rubbing.
Old 04-20-2006, 09:01 AM   #14334
nemisis's Avatar
can any body give me any other good tips for the mi2 ec it was going really well yster day once i had tried out a few things
Old 04-20-2006, 09:13 AM   #14335
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Default HELP!!!
Just wondering if any of you guys are having any problems with 'chewing up' spur gears??? For some reason, I cannot workout why my spur gears (regardless of the brand, RW, Kimbrough, Precison, Robinson Racing) are not spinning true when mounted in the car?
I have made sure that the layshaft is not bent, checked the layshaft assembly with housings by itself (no spur attached) and everytime it spins true and correct. As soon as I attach a spur no matter of type, it spins in an elipitcal fashion.
I dont have a standard EC spur to try. But the only things I can think of that could be causing an issue, would be the spur gear adapter (mounting holes) or the centre pulley (as I have cut out the necessary clearance grooves for the aftermarket spurs).
Can anyone help me out??? I have spent way too many hours trying to get my spurs to spin true and correct!!!
Also, I was wondering what you guys ran as far as spurs were concerned?? (original Ec spurs or aftermarket ones)
Thanks in advance,
Leonard.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 04-20-2006, 09:17 AM   #14336
nemisis's Avatar
well at the moment i am currently runnin rw spurs i havent stripped one as yet it seems strange that is strippin spurs left trie and center how long have you had the car
Old 04-20-2006, 09:20 AM   #14337
Jon Kerr's Avatar
We kind of need to know what you want it do. What's the car doing that you don't want it to do or vise varsa?
Old 04-20-2006, 09:24 AM   #14338
nemisis's Avatar
i dunno really it mite just ned a bit more speed i handles well round the corners better than it di last week the back end still wants to over take the front a touch but not so much it makes it impossible to drive other than that and gettin a bit of speed may be evry thing else is fine
Old 04-20-2006, 09:28 AM   #14339
Jon Kerr's Avatar
By speed do mean straight line speed or corner speed?
Old 04-20-2006, 09:29 AM   #14340
nemisis's Avatar
may be a bit of both it mite just need a bit more a kick round the corners by that i mean a bit more accerlration
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
