Old 04-15-2006, 11:53 AM   #14266
brownpants's Avatar
Originally Posted by bhambrent
I'm thinking about getting a mi2ec, but no LHS carrys any parts were I live.
What a good online hooby shope to get parts for mi2ec? And what hopups and extra parts are must have?
thx guys,
You can order direct from the Schumacher web site www.racing-cars.com
HTH Darren
brownpants is offline   Reply With Quote
Old 04-15-2006, 01:59 PM   #14267
nemisis's Avatar
i need help if i lower the camber link on the rear end will it give me les grip or more grip i have never quite got the jist fo the roll center thanks
nemisis is offline   Reply With Quote
Old 04-15-2006, 03:07 PM   #14268
PW
PW's Avatar
Send a message via AIM to PW
Lowering the inner link will allow the car to rotate more. This will also give more camber gain so you don't need to run as much static camber.
The way I look at is:
More camber gain (more angled link) gives the car a controlled slide.
Less camber gain (less angled link) gives less slide, but will break traction more suddenly.
I try and run the least amount of camber gain without the sudden loss of traction
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 04-15-2006, 04:02 PM   #14269
nemisis's Avatar
so your saying if i take the camber link down and let the car rotate more it will give me more grip
Old 04-15-2006, 05:25 PM   #14270
PW
PW's Avatar
Less grip; the car rotates more due to less grip.
Paul Wynn
Old 04-15-2006, 05:35 PM   #14271
justin lessard's Avatar
Send a message via AIM to justin lessard
my car was sooooooooooooo!!! lose today.but it was pushing too!!!,I had nothing to work with It was insane.
justin lessard is offline   Reply With Quote
Old 04-15-2006, 07:18 PM   #14272
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Can anyone please tell me if I need to get anything extra, if I was to buy the HD front one-way diff (U2753)???
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 04-15-2006, 07:23 PM   #14273
Send a message via AIM to rcguy2477
Post your setup. Also, check to make sure that none of the suspension components are cracked anywhere as that can cause some abnormal handling.
1989 Mazda Rx7
greddy t04b, megasquirt ecu, PlX wideband, 12x28x3 fmic, 50mm hks clone wg, ssqv bov, Safc, ss oil lines, walbro fuel pump, tubo intake manifolds, ssac exhaust manifold, 3" dp, 550cc primary/720cc secondary injectors, etc.
rcguy2477 is offline   Reply With Quote
Old 04-15-2006, 07:27 PM   #14274
mini-dub's Avatar
Trader Rating: 16 (100%+)
No if you get the oneway all you'll have to do is probably change some things on your setup, but oneways are usually faster. The tradeoff is theyre just harder to drive most the time.
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 04-15-2006, 07:31 PM   #14275
mini-dub's Avatar
If it was that bad there's probably something wrong with it. Such as worn out tires, binding/broken suspension, bent hinge pins, ect... But if its loose and pushing I'm going to take a stab at the tires being worn out or the wrong compound.
Old 04-15-2006, 09:45 PM   #14276
Jimmy Morris's Avatar
Or maybe a tweaked chassi.
www.superiorhobbies.com
Jimmy Morris is offline   Reply With Quote
Old 04-16-2006, 04:00 AM   #14277
nemisis's Avatar
well in that case can if i change the position of the shocks which way should i go at the moment i have the shocks on the rear end at kit setting
Old 04-16-2006, 04:09 AM   #14278
brownpants's Avatar
Using the hole nearest to the center of the car on the shock towers will give more grip and vice versa. I would leave them at kit settings though and move the camber link up or down, up giving more grip and down less.
Darren
Old 04-16-2006, 04:18 AM   #14279
hey got some questions lol weird ones
what is the free'est running belts i can put on my mi2 stock not ec?
ive noticed that all the other tourers run 3mm belts schui's are 5mm can i buy or get thinner ones made??
also ive cleaned my bearings but what else can i do to make the drive train less resistive?
lastly which is better on aphsalt foams or rubbers?? i have heard foams are faster hands down?
also how do you mount the rear alloy camber mounts? letters down and both r's on right and both l's on left?
please help me out i was about 1 second of the pace and i want my car to be perfect so then i can perfect my driving style.
thanks all.
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 04-16-2006, 04:49 AM   #14280
scott_g's Avatar
Send a message via MSN to scott_g Send a message via Skype™ to scott_g
thanks all.
1. There is a narrow rear belt for the mi2 - but only suitable if you are running stock/540. You can run the R12 front belt if you want something a little free-er for the front.
2. If bearings are clean, check and make sure diffs are all shimmed correctly - so not rubbing on diff housings etc. Get belts right, get belt tensioner settings right (basically no tension on either front or rear in stock class)
3. There is no "right" answer. Some tracks are faster with foam, others with rubber. Some clubs allow foam, others only allow rubber. At Beaudesert rubber is faster. At logan probably foam. At bayside rubber, at hobbystation, probably foam. Some race series in SEQ have rules about what tyres you can use.
4. not sure, someone else can answer
5. by far the best thing for you to do is to practice. changing all this stuff on your car will not make the slightest difference if your driving is inconsistent. spend all your $$ on getting to the track to practice, practice, practice. Practice on any track you can get too. Don't change too many things and don't listen to too many people. Put a fairly standard setup on your car and drive, drive, drive, drive. That's what you need to do more than anything.
Cheers
schumacher, speedpassion and more plus race blog at www.actionrc.com.au
twittering @ scottyg_rc
scott_g is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
