Old 04-13-2006, 05:34 PM   #14251
cornerspeed's Avatar
STLNLST-What are you gearing your DC 19T's(Integy based motor)? Need to have an idea incase I need to run 19.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 04-14-2006, 06:33 AM   #14252
STLNLST's Avatar
Trader Rating: 19 (100%+)
They seem to like a lot of gear and on the rug I geared them the same as the Orion based 19 turns so I will do the same for asphalt. I geared the orions at 5.5 so that's where I'm starting the Integy based motors at. 5.5-5.8 is about where I plan on keeping these motors. They also don't run as hot as the Orion cans probably due to the extra large vent holes. We'll see what happens this weekend if we are allowed to race.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 04-14-2006, 07:51 AM   #14253
Super Moderator
Trader Rating: 17 (100%+)
The New Atlas based 19T can run in the 34-37 range for rollout with a fan on it. The older Blue based 19T can run even higher. I typically run my Atlas motors about 2-4 teeth higher than my C2's. You have to have a fan on there though or you will fade hard. My motors will typically come off around 175-190. Without the fans I have been 230-240.
Tekno | JConcepts | ProTek RC | RaceReadyProducts | BOOMrc
Bob Barry is offline   Reply With Quote
Old 04-14-2006, 02:44 PM   #14254
Jon Kerr's Avatar
Reedy Race list is up!
http://www.tamiyausa.com/articles/fe...=182#confirmed
Jon Kerr is offline   Reply With Quote
Old 04-14-2006, 03:24 PM   #14255
Sanabria's Avatar
Originally Posted by Jon Kerr
Yep. My name is right above yours. I should be arriving with PW.
It will be nice to meet other fellow Schuie drivers.
Sanabria is offline   Reply With Quote
Old 04-14-2006, 04:33 PM   #14256
STLNLST's Avatar
Ooohhhhh lookie....my name is on there Jon gonna try for some revenge this year?
Old 04-14-2006, 04:37 PM   #14257
Jon Kerr's Avatar
Yeah. Didn't have too good of a showing last year in mod. I jumped up before I made the A in 19 turn. Looking at the competition, I'll be very happy with a top 20 this year. Always trying for the show though.
Old 04-14-2006, 05:14 PM   #14258
IslandBwoy's Avatar
Guess whos back byatchessssss! :-). Question: Which do you guys prefer to do first? Soften rollbar or increase roll center?
JEDI
IslandBwoy is offline   Reply With Quote
Old 04-14-2006, 05:46 PM   #14259
Jon Kerr's Avatar
Softening the roll bar is going to make it roll more and raising roll center will make it roll less.
Old 04-14-2006, 06:36 PM   #14260
justin lessard's Avatar
Send a message via AIM to justin lessard
by raising roll-center,you will be lowering the camber link right?
justin lessard is offline   Reply With Quote
Old 04-14-2006, 08:04 PM   #14261
mini-dub's Avatar
Trader Rating: 16 (100%+)
Right now this is as I understand it: A camber link that is parallel to the arm (raising the inner ballstud) will make the roll center lower. Making the link angled down towards the inside of the car will raise the roll center.
Raising the hinge pin above the chassis actually lowers the RC and vise versa, although most people refer to raising the hinge pin as raising the rear roll center. I've always found raising the hinge pin will make that end of the car flatter though.
Check this out though http://home.tiscali.be/be067749/58/c2/index.htm
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 04-14-2006, 09:22 PM   #14262
Jon Kerr's Avatar
You're dead on Weylin. Raising the roll center will keep that end flatter and you'll get less grip on that end. If you need more steering from the front end, try lowering the front roll center. If the rear is just too stuck, raise the rear roll center. And vise versa. But there should be a good balance between the two. You don't want to be too extreme on one end and not the other.
Old 04-15-2006, 12:52 AM   #14263
IslandBwoy's Avatar
I was speaking of rasing the roll center via either lowering the camber link or spacing the blocks up. In comparison to using softer sway bars, my understanding was that either will allow the car to roll a little more. Is this correct? Thererfore i was asking which i should do first when testing. Which gives the least drastic result?
Old 04-15-2006, 07:48 AM   #14264
Jon Kerr's Avatar
No. Raising the roll center by lowering the camber link or raising the lower pivot blocks will make the car roll less. Lowering the roll center will make the car roll more.
As far as compared to sway bars, I don't mess with sway bars too much. Outdoors, I just run the silver bars front and rear. Every time I try something other than that, it just doesn't feel right.
As for which is a more drastic change, I'd have to say adjusting roll center is a little more sensitive of an adjustment depending on how big of a change you make to it.
Old 04-15-2006, 11:48 AM   #14265
bhambrent's Avatar
I'm thinking about getting a mi2ec, but no LHS carrys any parts were I live.
What a good online hooby shope to get parts for mi2ec? And what hopups and extra parts are must have?
thx guys,
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
