Old 04-12-2006, 03:50 PM   #14236
nemisis's Avatar
try this one
File Type: txt mi2ec_setupsheet[1][1].txt (618 Bytes, 91 views)
nemisis is offline   Reply With Quote
Old 04-12-2006, 04:24 PM   #14237
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Ah, foam tires. I didn't catch that on your first post. I don't' have any experience with that. Maybe one of our rug rats we have on here can point you in the right direction.
Jon Kerr is offline   Reply With Quote
Old 04-12-2006, 05:16 PM   #14238
Skiddins's Avatar
Originally Posted by nemisis
i was wondering if anyoen can help me i am i took my ec for its debut run tonite and in having teething problems i cant seem to get the back end to stick.
it is havin a tendncey to step out a little an i was wondering if any one can help me solve this problem i am currently running the foam version of the car.
thanks
I notice you haven't given your droop settings.
Set the front droop to at least 1mm less than the rear, and set the rear to give almost maximum travel.
You also might want to get the extra stiffer roll bars and fit the black one to the front.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 04-12-2006, 05:58 PM   #14239
King-G's Avatar
Send a message via ICQ to King-G
Adding lots of rear droop (maxing out extension of shocks) will not give you added rear grip, If anything it will cause exessive weight transfer forward to the front tires on corner entry, causing oversteer.
Adding rear droop would only help the problem if you had very little to begin with and the car wasnt able to roll at all.
King-G is offline   Reply With Quote
Old 04-12-2006, 07:20 PM   #14240
PW
PW's Avatar
Send a message via AIM to PW
thanks
The first thing I notice is the tires. The proper foams for carpet are not rated by shore (only nitro foams). I would recommend Jaco Double pink/Orange fronts and Double pink rears (58mm or smaller).
As for the setup:
Front oil and spring are to soft; use a 33lb xray spring with 70wt oil.
Rear oil is to stiff; stay with the same spring, but use 40wt oil.
Droop; 1.5mm front & 2mm rear...More rear droop will give more steering.
Refer to the setup in the manual for foam tires
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 04-12-2006, 07:24 PM   #14241
Hey Nemisis.
First off take the spool out and place a reg diff in the front. espcially with the added grip fromt he carpet. those 35 shore tires you are using are more meant for Nitro racing on Asphalt. Pick up a set of Jaco foam d/pink rear and d/pink/orange fronts. ( don't forget to Glue the edges with CA) You could bring you oil weight in the back down. The spring not sure what the weight or what kind your using.
here a great set up for carpet by PW
http://www.gearchart.com/setup/setup...l_foam_kit.pdf
cyrrus is offline   Reply With Quote
Old 04-12-2006, 08:09 PM   #14242
hey whats a good foam for aphsalt im running stock and it about 28 degrees celcius here any idea?
i got some 40 shoar but u guys said they aint for electric
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 04-12-2006, 08:40 PM   #14243
Send a message via AIM to rcguy2477
Here is what I am currently running for foam stock using the carpet chassis:
40weight shock oil all around
25lb springs front
17.5lb springs rear
shocks 3 out from center on both front and back
.5mm spacer under rear hinge pin mounts
.5mm kickup in the front with stock spacers
1mm spacer under ball stud on the rear blocks
magenta and cyan foams(for temp colder weather)
I've only raced once so far outside, so I haven't had much time to get it to where I like. The rear was a little loose, so I changed it to a .5mm spacer under the hinge pin mounts. I may also go to a shock oil with less viscosity(35, maybe 30). I will be running outdoor again this weekend and will let you know of any changes I make.
1989 Mazda Rx7
greddy t04b, megasquirt ecu, PlX wideband, 12x28x3 fmic, 50mm hks clone wg, ssqv bov, Safc, ss oil lines, walbro fuel pump, tubo intake manifolds, ssac exhaust manifold, 3" dp, 550cc primary/720cc secondary injectors, etc.
rcguy2477 is offline   Reply With Quote
Old 04-12-2006, 11:40 PM   #14244
Those will get the job done. I'm not to sure what to use as for foams on Asphalt. as most of us run rubber on Asphalt and foams for carpet. maybe some out out there would be able to help you out. The shore 40 are more of temp thing(I could be wrong) so these might just work for you instead of going to a set of Jaco's.
Old 04-13-2006, 06:12 AM   #14245
Super Moderator
Nemisis, If your track is medium bite copy the setup exactally from the book for carpet. I don't remember if it tells you 33Lb springs for the front, but that is where you want to be. If your track has a lot of bite then you want to try PW's Snowbirds setup. It will get you very close to where you need to be. If you still have questions shoot me a PM and I will try to help you out.
Bob
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 04-13-2006, 10:23 AM   #14246
SA_Racer's Avatar
we run 35front and rear on medium bite asphalt, 40 is n bit hard so rear end comes loose and the front end tends to push on power
SA_Racer is offline   Reply With Quote
Old 04-13-2006, 10:26 AM   #14247
STLNLST's Avatar
Trader Rating: 21 (100%+)
The sun is out right now so maybe we can actually get some racing in this weekend. I guess I better finish putting my car together then....LOL
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 04-13-2006, 10:29 AM   #14248
HarshGuy's Avatar
The sun was shipped in just for you my friend.
http://www.arroyoc.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 04-13-2006, 10:51 AM   #14249
STLNLST's Avatar
I hope there will be a mod class. If not you know I have some killer 19 turns. There should be a good turnout if the weather's cool.
Old 04-13-2006, 11:03 AM   #14250
HarshGuy's Avatar
We don't want cool, we want warm to hot
...yea hopefully a good turnout, actually I'm on my way to snap some pics of the layout, check rcracing.com in about an hour.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
