Old 04-08-2006, 06:16 PM   #14191
justin lessard's Avatar
Send a message via AIM to justin lessard
i have had a total brain shutdown, what is the formula for final drive,for asphalt ,like 6.99 or 7.3?
justin lessard is offline   Reply With Quote
Old 04-08-2006, 06:34 PM   #14192
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
1.8. (Spur/Pinon)*1.8=FDR
Jon Kerr is offline   Reply With Quote
Old 04-08-2006, 10:22 PM   #14193
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
What are you guys doing for less rear toe in? Anyway to get less than 2 degrees?
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 04-08-2006, 10:59 PM   #14194
Jon Kerr's Avatar
You could get the plastic pivot blocks from the Mi2 and mount them with the indicator ridge facing out. This will give you 1.5.
Old 04-09-2006, 02:28 AM   #14195
SA_Racer's Avatar
what gears do you guys prefer to run in a MI2 for outdoor asphalt/tarmac 64P or 48p, also which puley do you prefer 17T or 20T.
thanks
SA_Racer is offline   Reply With Quote
Old 04-09-2006, 04:52 AM   #14196
nemisis's Avatar
can any one help me i have just started building my shock on the mi2 ec and i am building it to the us foam spec and i only have 35 and 45 wt oil it does say to use 40 and 70 wat should i do
nemisis is offline   Reply With Quote
Old 04-09-2006, 05:25 AM   #14197
|JayFlores|'s Avatar
thanks
48p 20t
well thats what i use.
Losi - Always racing towards the Future!
LRP[]Sanwa[]MuchMore[]Orion[]ProtoForm[]HUDY[]SOREX
|JayFlores| is offline   Reply With Quote
Old 04-09-2006, 04:41 PM   #14198
nemisis's Avatar
i now have my mi2 ec running can anybody give me any set up tips before i actually race it
thanks
Old 04-09-2006, 05:35 PM   #14199
King-G's Avatar
Send a message via ICQ to King-G
Car was super consistent again at a local club meeting. I used the meet as practice towards the state titles in a months time, using the T.O27 control tire / insert combo, and using just 1 set for the day.
Qual 3rd, raced to 2nd, 2nd and 3rd in the finals. Beat my previous P.B by around 8-9 seconds in the process.
Definately the best T.C schumacher has ever released, uber consistent and by far the easiest to drive car ive had.
I ended up changing link position on the towers to the upper hole front and rear, smoother transitioning L/R, less twitchy, with slower breakaway.
King-G is offline   Reply With Quote
Old 04-09-2006, 05:44 PM   #14200
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Hi Gavin,
I was wondering if you have tried lowering the transmission housing on the front yet? (taking out the riser plate and placing 2mm spacers below the top deck).
Thanks,
Leonard.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 04-09-2006, 09:15 PM   #14201
King-G's Avatar
I havent as yet, this is something Teemu has been doing of late, and is said to gain entry to mid corner steering, something I havent felt the E.C to be lacking at all.
Will get around to trying it at somepoint, but at the moment I havent felt the need to start tweaking with the E.C, its darn good out of the box.
Old 04-09-2006, 09:31 PM   #14202
Jon Kerr's Avatar
When you got your kit, it should have come with the correct oils. If the setup you wan to run calls for 40 and 70 weight, that's what you need to run. There really isn't any substitute. Sorry.
Old 04-09-2006, 09:36 PM   #14203
Jon Kerr's Avatar
I finally got to run some outdoor today. Donny and were both running brand new Rubber spec cars. My first time with one. (I've been running the foam spec car at SoCal.) I was very happy with it right out of the box. We both made a couple changes to deal with track conditions and have a few other things we'd like to try next time. Not a big turnout for Modified but Donny did win and I took second after a really great race with a couple other guys.
Old 04-09-2006, 11:00 PM   #14204
cornerspeed's Avatar
Yea, Jon looked good out there running with his new car. I had a pretty bad push on entry to the middle of the corner. Mostly a tighter 180 degree or slower 90 degree turns. High speed it's not bad. I basically ran PW's lasted set-up with the exceptions of I ran the front bulkhead lowered. It just has a little in-balance at that thrack the has been there for me for a long time. What always seems to fix it, is anti-squat. But, I'm told a lot that that isn't a good adjustment to make, so I have been trying other things with not much success. The car is really good, but I need to figure this out so it can be great. 1st. I've ran for about 6 weeks. Not so bad I guess.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 04-09-2006, 11:02 PM   #14205
Oh, I had MOTOR. New horsepower from Curtis at DC. It was singing all the way around the track.
Donny Vinkemulder
TLR Driver
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
