Old 04-05-2006, 06:09 AM   #14176
AdrianM's Avatar
Jon probably has a bit too much weight on the batt side. We usually put 3/4oz directly under the front belt in front of the motor mount, 3/4 oz across the chassis between the motor and the speedo and 1/2oz in the front bumper right above where it bolts to the chassis. If you have really light electronics you can put another 1/4oz in front or behind the servo output arm.
Adrian Martinez
Old 04-05-2006, 10:00 AM   #14177
Skiddins's Avatar
I have a 10g weight behind the motor, 5g under the front belt beside the receiver, 5g under the servo horn and another 5g just behind that (between the 'horn' weight and the receiver).
Sorry, don't know the imperial conversions.
I was a bit paranoid that I may have biased the weights a bit too much towards the front, I will be running asphalt on Sunday so I'll guess I'll see.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 04-05-2006, 02:24 PM   #14178
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
what is the rear camber mod for the ec?
roadrashracing is offline   Reply With Quote
Old 04-05-2006, 02:38 PM   #14179
PW
PW's Avatar
Send a message via AIM to PW
"This mod is for the foam spec only"
On carpet with foam tires we moved the link to the outer hole on the hub and made a new camber bracket (EC rubber spec) to move the inner link further out. There is no need to make this mod for the EC Rubber Car because its already there
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 04-05-2006, 02:42 PM   #14180
Moderator
Thanks for clearing that up.
Old 04-05-2006, 04:40 PM   #14181
Super Moderator
Trader Rating: 17 (100%+)
Hey PDub, might be some more competition at the Express race in Jackson....check out their thread in the racing forum.
Still sure ya can't make it
Remember....it's the "Worlds Warmup"
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 04-05-2006, 08:33 PM   #14182
Jon Williams's Avatar
Adrian, actually the weight in the rear is intentional at this point. It's biased a more towards the rear for additional initial weight transfer.
If I don't like the feel, I'll be centralizing more weight near the spine and slightly more between the motor and speed control as we discussed.
It's all good...
Jon Williams is offline   Reply With Quote
Old 04-05-2006, 11:14 PM   #14183
Some pics of my car.
Schumacher Corner-1.jpg   Schumacher Corner-2.jpg   Schumacher Corner-3.jpg   Schumacher Corner-4.jpg
AL-HEX is offline   Reply With Quote
Old 04-06-2006, 01:13 AM   #14184
King-G's Avatar
Send a message via ICQ to King-G
OMG who are you AL-Hex?
lol
King-G is offline   Reply With Quote
Old 04-06-2006, 01:25 AM   #14185
Chris Putnam..
Leigh taylor is No.1 schuey driver as he is beating us
both in the championship !
Old 04-06-2006, 06:48 PM   #14186
AdrianM's Avatar
Adrian Martinez
Old 04-07-2006, 12:06 AM   #14187
Cole Trickle's Avatar
Originally Posted by Cole Trickle
Anyone using the Schumacher H1032 Alloy Camber Gauge - 1-10th?
Whats the maximum degree, and what's the resolution, that is, can it for instance be adjusted in 0,5 deg steps?
The pics on the net aint very detailed...
No one use this, nor know it?
Thanks.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 04-07-2006, 06:06 AM   #14188
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
I use the gauge, it is packed up in my boxes right now, I can only guess how far it goes, but I am sure it past + - 5 degrees. I have to say it is one of the nicest camber gauges I have seen or used.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 04-07-2006, 09:41 AM   #14189
I second that. The schuie gauge is very nice, am the best part is it matches our car
Jay Dub is offline   Reply With Quote
Old 04-08-2006, 05:17 AM   #14190
HarshGuy's Avatar
Not as nice as the ARC Eclipse Magnetizer
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
