Old 04-04-2006, 09:01 AM   #14161
STLNLST's Avatar
Trader Rating: 19 (100%+)
With all this rain it looks like the norcal racers are safe from me putting the smack down on the 15th unless it all of a sudden clears up... I feel that this is my year
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 04-04-2006, 09:06 AM   #14162
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Didnt you say that for carpet season, oh and last season outside lol
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 04-04-2006, 02:36 PM   #14163
STLNLST's Avatar
Never said that for carpet.....but I will go on record now and state that for the Reedy race I WILL NOT BE THE LOWEST FINISHING SCHUIE DRIVER in the mod class. This year on asphalt is where I become one with my car
Time to make PW proud of me again
Old 04-04-2006, 03:28 PM   #14164
Originally Posted by AdrianM
Most of the UK tracks have less grip than most US tracks. I hear you guys can run Sorex 28's in the summer. We would wear 28's down to the belt in 3 minutes outdoors. Less grip and Tire Tweak would let you run the softer tires in the heat.
we have a lot less grip then you lot.
the most common tyre through out the season is cs22 before rp.
now rp 24 outdoors are also used,i dunno anyone who uses the sorex range at nationals.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 04-04-2006, 04:39 PM   #14165
Jon Williams's Avatar
Made a few minor changes to the car...
--Disclaimer-- lol...I'm a perfectionist, so the things I changed on the car are not necessary by any means.
1) Really like the Schuie body mounts and their adjustability, but wanted to cushion the body a little more. Used small body mount foams. I simply used some CA to attach them onto the shock tower and made pressure on the angled portion until they stuck.
2) Used heim style/XRAY joints on shock shafts instead of the ball cups. Spaced them out with a Schuie 2mm spacers on all four corners. The ball cups on the car are super good, but if you're like me you rebuild your shocks often and don't want to chew up the ball cups this provides an easy way to take them on and off.
3) If you're running a ROAR event and need to weigh 1525gms (I was nearly three oz under weight), weights: used brand-X lead weights at 3 corners and a modified lead weight near the servo for balance. Underneath the bumper mount and between the small screw posts (ala Teemu) I have a strip of 12 grams. (hard to see in pic lol)
Schumacher Corner-dsc00979.jpg   Schumacher Corner-dsc00980.jpg   Schumacher Corner-dsc00981.jpg   Schumacher Corner-dsc00982.jpg
Jon Williams is offline   Reply With Quote
Old 04-04-2006, 05:03 PM   #14166
justin lessard's Avatar
Send a message via AIM to justin lessard
have you run it yet?,and what did you think of it?
justin lessard is offline   Reply With Quote
Old 04-04-2006, 06:17 PM   #14167
Yeah, I got to play with it a little this past weekend. The track was a little dirty and I only got about 4 packs in it, but the car felt good right from the start.
I'll get to race with it this coming weekend.
Old 04-04-2006, 06:20 PM   #14168
how did u get that car so clean?
i have to dissasemble my car and completely rebuild it to get it that clean any tips?? what do u use?
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 04-04-2006, 06:41 PM   #14169
Well, I have an extremely powerful compressor that is cranked up pretty high. Between that, q-tips with some lighter fluid or motor spray I can get the car to clean up nicely.
As for bearings in the hubs if I don't have time to dissassemble the car before running, I'll take the tires off and simply spray downwards *away* from the chassis with motor spray thoroughly and then relube with either Niftech micro bearing oil or WD40 (I'm oldschool). I'll repeat this process on all four hubs.
As for the bearings in the bulkheads, etc. you're kinda stuck there because you simply cannot flush them out with motor spray and relube. If the drivetrain is really that bad, it's time to disassemble.
Old 04-04-2006, 07:07 PM   #14170
Moderator
Trader Rating: 76 (100%+)
I was wondering if there is an ec convertion kit for the mi2 or how much it would be to convert?
roadrashracing is offline   Reply With Quote
Old 04-04-2006, 07:08 PM   #14171
Super Moderator
Marcos.J's Avatar
Trader Rating: 166 (100%+)
no there isnt one
Old 04-04-2006, 07:14 PM   #14172
Moderator
Ok
Old 04-05-2006, 03:31 AM   #14173
Cole Trickle's Avatar
Anyone using the Schumacher H1032 Alloy Camber Gauge - 1-10th?
Whats the maximum degree, and what's the resolution, that is, can it for instance be adjusted in 0,5 deg steps?
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 04-05-2006, 05:39 AM   #14174
Skiddins's Avatar
How well balanced is the car from left to right with those weights?
I have all my lead on the side of the radio gear in various positions to try to help balance out the batteries a bit.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 04-05-2006, 06:04 AM   #14175
Super Moderator
Trader Rating: 17 (100%+)
Skiddins if I know Jon, he has probably balanced that car 30 times to get it perfect.
Tekno | JConcepts | ProTek RC | RaceReadyProducts | BOOMrc
Bob Barry is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
