Old 04-02-2006, 10:39 AM   #14131
ottoman's Avatar
R/C Tech Charter Subscriber
Originally Posted by roadrashracing
I have a few more questions: What is the easy way for removing front and rear diffs and changing spur gears. I just wanted to know the easy way so I don't take the hole car a part if I don't have to the first time I do it. Thanks
There is no "easy" way.... if thats what your looking for you should get a T2, Cyclone or Tamiya. That said... after you do it a bunch of times its really not that hard
ottoman is offline   Reply With Quote
Old 04-02-2006, 01:40 PM   #14132
heavy's Avatar
Trader Rating: 20 (100%+)
Originally Posted by aus jd 2703
hey guys do you re-use rims?
ive soaked them in acetone to get rid of the glue but unsure if to use the rims again. no cracks or anything but they have had hard hits. their flexible pro-lines so???
are carbon wishbone's a 'musthave' upgrade?
oh is 2 degrees to much camber??
We always reuse rims. We only use Schumacher Revlite rims and have reused them many times and have never had a problem with them. You can buy them in Brisbane in packs of 4 or if you like you can get them with premounted Sorex 36/c or 32/b save you gluing.
C/F wishbones are nice but I wouldn't rate them as a "musthave" particluarly if dollars are tight.
At Meakin where you race 1.5 degrees is perfect.
Honorary Life Member Logan RCCC -Mi6 and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6
Boondall. SuperShot, XX, XXT, SVR,Schumacher Storm
heavy is offline   Reply With Quote
Old 04-02-2006, 03:38 PM   #14133
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
what is the camber mod, anyone have pics that the can post
Owning a lot of RC vehicles doesn't always mean a lot of knowledge.
roadrashracing is offline   Reply With Quote
Old 04-02-2006, 06:07 PM   #14134
justin lessard's Avatar
Send a message via AIM to justin lessard
whats the best tire,insert,rim combo for asphalt ,and are the powers international tires any good?
justin lessard is offline   Reply With Quote
Old 04-02-2006, 08:51 PM   #14135
bomberman's Avatar
speed mind dish, sorex med.b inserts, and sorex 36 or 40
bomberman is offline   Reply With Quote
Old 04-02-2006, 09:28 PM   #14136
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
All depends on the track itself. Some tires work great one place, and are like running on ice on another track. RP30's and CS27's are both a pretty good tire that should work in most situations. We run the RP30 premounts on pretty much all the outdoor races here and they work great. But we've tried them at SoCal and they're horrible. Way too much grip on the high grip track. Literally traction rolling there with those tires. Even the RP36 had too much bite for that track. We run Sorex 36R's or 32R's there with either Yokomo 039F or 039M inserts. Some run the Hara Black inserts too.
Jon Kerr is offline   Reply With Quote
Old 04-02-2006, 09:49 PM   #14137
AdrianM's Avatar
Have you tried RP40GL's at Socal?
Adrian Martinez
Old 04-03-2006, 04:30 AM   #14138
adrian,what tire are you and paul running?
Old 04-03-2006, 06:42 AM   #14139
Jon Kerr's Avatar
We did once. But we didn't have much of a setup for the car yet (we were still running the Mi2 at the time) so it might be worth checking out again soon.
Old 04-03-2006, 07:37 AM   #14140
PW
PW's Avatar
Send a message via AIM to PW
Florida pretty much races CS27's everywhere as our Florida State Series use them as the handout tire.
I do however like to run the RP30 & RP36 when we are using open tires; they have more steering than CS
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 04-03-2006, 08:43 AM   #14141
Jon Williams's Avatar
Right there with ya, PW. IMO the RPs definitely have more steering than the CS, and I never really noticed any significant wear differences between the two.
Jon Williams is offline   Reply With Quote
Old 04-03-2006, 11:26 AM   #14142
PeterCr's Avatar
I'm having some problems with very high tire-wear in te front with the Mi2EC using CS-27 on tarmac (in cold weather).
The car (setup) is very good and very fast but with very high tire wear in the front. I'm using the Euro's setup of Teemu with some changes. (one-way, fron rollcenter lowered and less camber)
Who has a solution to this or tips?
PeterCr is offline   Reply With Quote
Old 04-03-2006, 11:36 AM   #14143
PW
PW's Avatar
The lower you go with the front hinge-pin, the higher your tire wear will be.....Most of us are running riser plate plus 1mm in the front with the camber link in the upper hole.
Paul Wynn
Old 04-03-2006, 11:55 AM   #14144
i tried removing the front diff riser and adding a 2mm spacer under the front two holes on the top deck ,it did'nt really give my car more steering like adrian said it would ,but it did make it smoother in the S's,and my front tires did'nt wear grooves in the inner part of the tire as bad as it did before.
Old 04-03-2006, 12:09 PM   #14145
AdrianM's Avatar
This actually came from Teemu...
Adrian Martinez
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
