Old 03-28-2006, 01:48 PM   #14086
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally Posted by AdrianM
The pins are a know issues. If any one has broken CVD pins on their EC in the USA call Schumacher USA and we will send you a new CVD rebuild kit that will eliminate the problem.
If you have a broken pin in CVD's that have the set screw lock tighted so it won't come out we will send you a replacement set of CVD's.
If you have this problem outside of the US contact your distributor.
Can't beat that.
Jon Kerr is offline   Reply With Quote
Old 03-28-2006, 02:21 PM   #14087
heavy's Avatar
Trader Rating: 20 (100%+)
Can you tell me what the "new CVD rebuild kit" contains or better yet what teh part number is.
I am not in the USA I am a retailer in Australia and our distributor is Schumacher UK direct - there is no information from them about a CVD rebuild kit
Honorary Life Member Logan RCCC -Mi6EVO and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6EVO
Boondall. SuperShot, XX, SVR,Schumacher Storm BigWig
heavy is offline   Reply With Quote
Old 03-28-2006, 03:27 PM   #14088
AdrianM's Avatar
Schu UK is getting new pins for the CVD's that should be in next week. Schu USA sells TiR stuff so in the meantime thats what were are supplying to US customers.
Adrian Martinez
Old 03-28-2006, 03:30 PM   #14089
heavy's Avatar
OK thanks
Old 03-28-2006, 04:22 PM   #14090
Super Moderator
I have a new favorite part to break....seems that the rear hubs don't like me. My EC rejected 3 of them this weekend at the Region 2 Champs. Also added to the list is two rear arms, 2 castor blocks, and 1 front arm. Can you tell I have had a long weekend
Tekno | JConcepts | ProTek RC | RaceReadyProducts | BOOMrc
Bob Barry is offline   Reply With Quote
Old 03-28-2006, 04:37 PM   #14091
mini-dub's Avatar
Trader Rating: 16 (100%+)
The rear hubs are pretty weak. If you have time drill out some of the HPI Pro4 rear hubs so they fit our hinge pins (1/8") and put those on your car. The spacing is the same but the ball stud is like .5 or .75mm higher than the stock hub. I believe ours were lowered so we could run a lower position if we wanted and just use more shims to get it higher. The HPI hubs will never break though, I've been running mine since.... Vegas? Or paved nats? Either way I've deemed them indestructible .
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 03-28-2006, 04:44 PM   #14092
Super Moderator
Now ya tell me
Old 03-28-2006, 04:51 PM   #14093
Jon Kerr's Avatar
Damn Bob! Quit hittin' stuff!
Old 03-28-2006, 04:58 PM   #14094
Jon Williams's Avatar
Asphalt ride finally built...
I know a few people were curious how the plastic parts (drivetrain, ball cups, etc.) would look dyed black.
Schumacher Corner-dsc00940.jpg   Schumacher Corner-dsc00941.jpg   Schumacher Corner-dsc00942.jpg
Jon Williams is offline   Reply With Quote
Old 03-28-2006, 05:06 PM   #14095
Jon Kerr's Avatar
You beat me to it. I was going to do that with my rubber tire car when I get it. At least now I know it'll look dialed.
Old 03-28-2006, 05:22 PM   #14096
Thanks, dude. I actually gotta give props to Seaball/Chris Goetz. I got to check out his quasi-Schuie-car at Cleveland this year and it looked great in black.
I did however decide to keep the purple anodizing for a little contrast against the black.
I had no warping issues with the Schumacher plastic whatsoever and I used regular Rit black dye in the bottle and added a good amount to the water. I then put the parts in for about 20-30 mins at a simmering boil (if that makes any sense).
If the parts are still purple after 30 mins, just leave them in the solution longer. Once you're finished, just get them out with a stainless steel strainer and put them in the sink under cold water. It'll take a while to get all the excess dye out while rinsing so be patient.
Old 03-28-2006, 06:19 PM   #14097
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Will 3600 fit in a mission or just 3300
20 SMOKE is offline   Reply With Quote
Old 03-28-2006, 06:23 PM   #14098
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Weylin is right.. those HPI hubs are dialled... Fernando helped me out at the snowbirds with them, and I have not broken one since...
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 03-28-2006, 06:35 PM   #14099
Jon Kerr's Avatar
I've been dying parts for a while. Mainly Novak cases The Orange is just... ugly. I've even done some spur gears without any problems.
Old 03-28-2006, 06:36 PM   #14100
Jon Kerr's Avatar
I don't think they ever made a chassis for the mission to fit the larger cells. You may be able to file the slots down enough though to get them to fit.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
