Old 03-25-2006, 09:01 AM   #14056
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by aus jd 2703
what would u guys run in stock on a fast flowing track wih a 1 tight section? its medium traction aphsalt?
ive got told a spool and a one way buy different people cant figure it out.
Everyone is pretty much running the spool but I know that I'm one of the last people that still likes his oneway. When I'm running stock or 19T I like it over the spool depending on the track layout. It's something that you just have to play with. If you need a oneway set up you can try www.gearchart.com
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 03-25-2006, 03:11 PM   #14057
nemisis's Avatar
finally orderd me mi2 ec now well pleased should be a good drive
nemisis is offline   Reply With Quote
Old 03-26-2006, 03:10 AM   #14058
Skiddins's Avatar
A warm welcome to the latest member of the EC club
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-26-2006, 08:56 AM   #14059
justin lessard's Avatar
Send a message via AIM to justin lessard
are there any plans on making some different toe blocks,or hubs to alter the rear toe-in?
justin lessard is offline   Reply With Quote
Old 03-26-2006, 01:44 PM   #14060
Skiddins's Avatar
Why do you fell the need to change them?
Any more than 2 deg and you lose a lot of straight line speed, any less and you'll get problems with the back end.
Any handling problems should be easily dialed out using the roll centre's and cambers etc.
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 03-26-2006, 03:00 PM   #14061
because i'm running on a track where cars are always lose and if giving the car 1.5 degree more toe will save me 0.000000001 seconds per lap it will be worth it. (i'm just mental like that)
Old 03-26-2006, 07:33 PM   #14062
Jon Williams's Avatar
Hey, guys...just checking in.
Asphalt season will be starting up in the next few weeks, so you should hear more from us Northerners soon.
Got my asphalt EC built and ready to go. Just waiting for a free, relatively warm day to go and play.
Jon Williams is offline   Reply With Quote
Old 03-26-2006, 08:23 PM   #14063
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Hey Jon opening day at Glenn Burnie is April 8th. You can come race with me, punkboy and fastasu2. Good way to break in that car.
ST Racing Concepts (STRC)
Old 03-26-2006, 10:28 PM   #14064
PeterCr's Avatar
I drove my Mi2EC for the second time on asphalt and must say that it is really fast. I started out with the spool but since this track is mega-large european track (1:8 IC track with 90 mtr straight) the one-way suited the car better and kept the car rolling better through the long fast corners.
On a smaller track the spool would probably be my choice. (first time out last week was on a small track with spool)
Only thing I noticed was a bit of lack in initial steering. After setting some anti-dive in front and changing the rollcenter in the front the car was dailed. (thanks to Jon for the tips)
If anyone is interested in a one-way setup for a large fast track drop me an email.
PeterCr is offline   Reply With Quote
Old 03-27-2006, 08:09 AM   #14065
nemisis's Avatar
can anyone hive me some good advice on the ec that may be different from the origanl mi2
Old 03-27-2006, 08:53 AM   #14066
PW
PW's Avatar
Send a message via AIM to PW
Here are a couple of things that aren't clear in the manual:
1. Be sure to only use 1 diff spacer front and rear (not 4).
2. The L & R on the suspension blocks should face the chassis with the pins in the high position.
3. The diff might be slightly tight. I always take apart the prebuilt diff (not the thrust) and sand the rings, rebuild with fresh grease, back off a 1/4 turn from tight and then break-in on the stand.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 03-27-2006, 09:01 AM   #14067
AdrianM's Avatar
can anyone hive me some good advice on the ec that may be different from the original Mi2
Physically the EC has:
Higher roll centers
Less front and rear hub offset
Wider lower hinge pin spacing
Raised diffs for more drive shaft plunge
Different inner camber link locations
Different shock mounting locations
New Shocks
New Rear hubs
New Wheel Hexes
New lighter Diff housings
New lighter Motor mount
New Lay shaft mounts
New Top deck
New Drive train
lots more...
Performance differences:
The EC has more steering
The EC carries more corner speed
The EC is more stable
The EC easier to drive faster
The EC turns faster lap times
The new drive train holds up to any motor you could ever imagine bolting in.
Adrian Martinez
Old 03-27-2006, 10:00 AM   #14068
Skiddins's Avatar
When I built mine I found it was better with no diff spacers at all. That left about 0.15mm of play, the spacers are 0.20mm thick.
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 03-27-2006, 10:02 AM   #14069
Sanabria's Avatar
I never owned the original MI2, but I'm very happy with the EC. It is smooth and fast.
Sanabria is offline   Reply With Quote
Old 03-27-2006, 10:38 AM   #14070
I second Paul's comments on the diff and the diff spacers.
I too break in my diffs on a car stand and also use super high-grit sand paper to polish the diff rings. The rear diff is quite smooth on my asphalt EC.
By experimentation I found that one diff shim was just right on the car. With four, it's incredibly tight.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
