Old 03-21-2006, 04:14 PM   #13981
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Originally Posted by seaball
thanks robk. both cars were good all weekend.
Now just think if you had an X-ray car, Jaco tires and some other sticks how much faster you would have been..... Nice job man.....even with one good hand you still did that. Now lets see that setup for the stock EC car.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 03-21-2006, 04:34 PM   #13982
Trader Rating: 17 (100%+)
STLNLST hard at work......
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 03-21-2006, 04:38 PM   #13983
STLNLST's Avatar
Trader Rating: 19 (100%+)
That's what happens when spektrums go wild....LOL
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 03-21-2006, 04:50 PM   #13984
HarshGuy's Avatar
Dude, what's funny is I was sitting in the bleacher, couldn't really see that part of the track cause I was sitting, I remember seeing PW coming close to STLNLST and thinking "watch STLNLST panic and take out his team leader" ...looked somewhere else on the track and heard
C-R-A-C-K P-O-W S-M-A-S-H
...my 1st thouht was "oh crap, STLNLST's gonna be gettin a NIIICCCCEEE email"
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 03-21-2006, 04:55 PM   #13985
I wish we could have gotten a picture of Chris' (Crimson Eagle) face when STLNLST's car hit. He was standing right there! When I looked up he was even whiter than normal (if that is possible LMAO!).
I think his comment was "I almost shat myself" complete with British accent.
Totally funny!!!!!
Old 03-21-2006, 05:17 PM   #13986
IslandBwoy's Avatar
LMAO
IslandBwoy is offline   Reply With Quote
Old 03-21-2006, 05:23 PM   #13987
BATT_MAN's Avatar
Originally Posted by Skiddins
Interesting, I was running rubber on carpet today and had the problem where the front had too much grip and the back kept swinging out at all but dead slow speeds, it never grip rolled etc but I couldn't get the smooth lines I wanted as I was having to concentrate on steering inputs too much.
I added rear droop to try to make sure that the wheels were always in contact with the ground which did improve things, I tightend the rear diff to try to induce some understeer (it was too loose anyway due to a recent rebuild), then tried a stiffer rear roll bar and stiffer front springs to reduce the steering.
These all helped a bit but what else would you guys suggest?
Ideally I want more rear grip but reducing the front grip might be the better way to go.
What do you think?
Skiddins
Skiddins,
My first question is at what part of the turn are you loosing grip, mid-corner or exit... Then we can figure out more precisely what is happening...
HOWEVER,
From what you are describing it seems that the the rear end of your car is roling excessively. That is why you have added a stiffer rear roll bar, and increased the droop....
The first thing I would try before playing with the suspension is to increase the rear down force. If that does not help then I would start working with the suspension.
When the problems are with excessive rear roll you can also increase the rear spring rate... and try higher viscosity shock oil.
NEXT....
Readjusting your roll centers to transfer less wight through the springs and more through the RC. To do that you RAISE the RC. Try raising the FRONT RC to decrease the weight transfer at the front (reduce front traction). To do this with Mi2EC you have to get creative as there are not enough holes on the shock tower to lower the camber link (you lower the camber link towards the center of the car to RAISE the RC). YOu can raise it 0.50 - 1.0mm at the C-hub and see if that helps to reduce the weight transfer.
The key factor is to maintain the car balanced.
BATT_MAN is offline   Reply With Quote
Old 03-22-2006, 12:24 AM   #13988
hey guys just looking at tuning options whats the upper hole for the rear hinge pin in the carriers do?? you have two hole for the hinge pin and the manual doesnt explain what the upper of the 2 does? do you guys ever use it?? what characteristics (leave the spelling alone i know its tempting) does it ad or change??
thanks all
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 03-22-2006, 10:13 AM   #13989
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
for those of you interested in the setup on my stock ec car this weekend at the nationals, see below.
it wasn't perfect, but it had the cornerspeed to get the lap times. i am going to work on the ec car more over the next few weeks and i'll let you know what i learn.
- chris -
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 03-22-2006, 10:24 AM   #13990
Jon Kerr's Avatar
Chris, YGPM.
Jon Kerr is offline   Reply With Quote
Old 03-22-2006, 11:07 AM   #13991
Chris,
How did you come about getting the width measurement?
later
jim
Fantom, BL Racing, Retired
jimnew is offline   Reply With Quote
Old 03-22-2006, 11:15 AM   #13992
PW
PW's Avatar
Send a message via AIM to PW
I'm assuming the width should read: Front/189mm Rear/190mm
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 03-22-2006, 11:17 AM   #13993
I figured that, but with Seaball you never know
BTW how was your car at the Nats?
Later
jim
Old 03-22-2006, 11:22 AM   #13994
Skiddins's Avatar
Originally Posted by BATT_MAN
Skiddins,
HOWEVER,
NEXT....
It was mainly mid-corner.
In hindsight the rear roll bar should have come off if anything, certainly not stiffer, I was tired and there wasn't really enough time between rounds for major changes, front roll centre would have been my next step to reduce the front grip.
How does the change in handling compare between just moving the top link and/just adjusting the roll centre with the spacers?
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-22-2006, 11:52 AM   #13995
seaball's Avatar
yeah 189/190. also the rear toe is whatever the stock kit produces. i thought that was 2*?
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
