Old 03-15-2006, 11:33 AM   #13906
Hey Bob thanks for the info will try it tonight at Pratice.
just a quick question,
With a bumpy track should should I go softer on the springs and higher on the oil weight. or softer in both. the rear end seems fine, the front seems to be bumping around a bit.
cyrrus is offline   Reply With Quote
Old 03-15-2006, 12:13 PM   #13907
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Softer on the springs and heavier on the oil will really slow down the reaction a lot. I'd try running the same oil first with a softer spring. This way the dampening will stay the same but the rebound will be less and that's what causes the bounce on a bumpy track. If it's still not enough, go to the next weight up on the oil.
Jon Kerr is offline   Reply With Quote
Old 03-15-2006, 01:40 PM   #13908
IslandBwoy's Avatar
TURBO DoG! PMYH
IslandBwoy is offline   Reply With Quote
Old 03-15-2006, 01:44 PM   #13909
Sanabria's Avatar
Originally Posted by pucho
Yeah! and a thick cloud of polen that's pissing me off!!! thath's what my eyes look like, and this is how my nose feels
LOL your car was green when it came off the track...is your nose green too?
Sanabria is offline   Reply With Quote
Old 03-15-2006, 07:15 PM   #13910
IslandBwoy's Avatar
Hey TP,
Do you want to run 12 this weekend? I was going to run it but I think im going to do stock instead. Let me know. I got new bearings and such to rebuild the rear end.
R.
Old 03-15-2006, 07:24 PM   #13911
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
I need a setup for the mission on high bite track don't know what the car has waiting for the mail, would like something to start with
20 SMOKE is offline   Reply With Quote
Old 03-15-2006, 07:28 PM   #13912
AdrianM's Avatar
I plan on running 1/12th and 19T Sedan.
Adrian Martinez
Old 03-15-2006, 07:37 PM   #13913
AdrianM's Avatar
I plan on running 1/12th and 19T Sedan at the Fast Lap State Race.
Adrian Martinez
Old 03-16-2006, 12:40 AM   #13914
pucho's Avatar
Send a message via AIM to pucho
Yah You really don't want to see what's coming out of there.
pucho is offline   Reply With Quote
Old 03-16-2006, 03:34 AM   #13915
hey guys,
i went for a test and i need more grip in the rear. as i power out of a high speed corner(low grip) the rear end slides out any suggestions?
i was thingking a front sway bar just to even it up any ideas?
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 03-16-2006, 05:44 AM   #13916
IslandBwoy's Avatar
More droop/up travel in the front. That will fix that right up.
But consider how much droop you have in the rear as well. Maybe your transfering too much weight forward and its not coming back quick enough.
Old 03-16-2006, 07:22 AM   #13917
IslandBwoy's Avatar
Has there been any plans made for BMI to come out with an EC chasis?
Old 03-16-2006, 02:58 PM   #13918
King-G's Avatar
Send a message via ICQ to King-G
Probably not such a need at this point, as the E.C is pretty sorted
King-G is offline   Reply With Quote
Old 03-16-2006, 03:20 PM   #13919
Jon Kerr's Avatar
I know Jason's looked into it. But he's busy with other stuff right now. Plus, he'll only make a chassis if there's something that can be improved. So a few things would need to be tried and tested before anything would be done.
Old 03-16-2006, 04:52 PM   #13920
AdrianM's Avatar
Jason won't make a chassis unless he can find a genuine improvement. Last time I talked to him he said he couldn't think of anything to change on the Rubber or Foam car.
Like Jon said he is concentrating on cars that need help
Adrian Martinez
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
