Old 03-03-2006, 07:12 PM   #13786
IslandBwoy's Avatar
Hey,
Where do you guys gear your C2's versus your Reedy Quads? Do you prefer either on a larger track vs. The other?
JEDI
IslandBwoy is offline   Reply With Quote
Old 03-03-2006, 08:38 PM   #13787
DENNIS STORTI's Avatar
Trader Rating: 42 (94%+)
Send a message via AIM to DENNIS STORTI
wow i think u guys dont even compare to me then if we go from 2002 on its been TC3
,XXXS
,XRAY(PIVOT BALL)
,BARACUDA,
XRAY(C-HUB WHEN IT WAS AN OPTION NOT A KIT),
XRAY(FOC)
,YOKOMO
,YOKOMO(RAYSPEED)
,YOKOMO WORLDS,
TAMIYA EVO,
TAMIYA SOMETHING WITH BELTS
FKO4
FK05
T2
KUST NEED A JRXS ,TC4,CORALLY,SHUIE,CYCLONE,
DENNIS STORTI is offline   Reply With Quote
Old 03-03-2006, 09:19 PM   #13788
AdrianM's Avatar
I have had:
Roadrunner Express (1996)
Schumacher SST98 (1997)
Associated TC3 Team (1999)
Schumacher SST Axis (Early 2000)
Schumacher SST Axis 2 (Late 2000 - This when I started working For Schumacher)
Schumacher Mission (2002)
Schumacher Mi2 (2004)
Schumacher Mi2EC (2006)
Adrian Martinez
Old 03-03-2006, 09:23 PM   #13789
i didnt want to go back that far lol
added to the list now lol
street weapon
iwc sw
rally weapon (on carpet)
tc3 original
express
hpi pro
pro 2
pro3 and i know im forgetting at least one or two
Old 03-03-2006, 11:05 PM   #13790
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
I will throw that down too....
SST 99
SST Rally
Axis
Axis 2
Axis 2 Carbon
Rally Weapon
Pro 2 Rally
Pro 3
Mission
Mission Carbon
Rc Lab 7 Even
Pro 3 Again > HPI Challenge race :> won a trip to Japan with this car...
Sport 2
Mi2 x4
Xray t1r
Tamiya Ta04r
Pro 4 > Hpi Challenge race
Mi2 EC
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 03-03-2006, 11:41 PM   #13791
Proud to say I have never run anything but schumacher cars from their first touring car till now.
Jay Dub is offline   Reply With Quote
Old 03-04-2006, 12:40 AM   #13792
cornerspeed's Avatar
Here's my list:
HPI RS4(original w/gearbox)
then converted to a Pro in '96 or 97 I believe
SST 98
SST 99 w/National Title
Axis
Axis II
Mision
MI2
MI2 EC
MI2 EC Foam spec
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 03-04-2006, 01:24 AM   #13793
IslandBwoy's Avatar
Do any of you guys have a GTX? Im just trying to program mines and everything runs well but after the programming is done:
if i give it about 30 percent throttle its all good. But once i pass that the motor will just run even after i let the throttle go !?!?!?!? Anyone had this issue? I've already reset everything on my transmitter and started over a few times. I dont know what the hell this could be a bout.
Old 03-04-2006, 08:04 AM   #13794
STLNLST's Avatar
Trader Rating: 17 (100%+)
I run the GTX and I haven't experienced that problem so far. The only thing that I could suggest is reset all of the trims on the radio and then recheck them again just to be sure that you didn't miss anything, then follow the steps of setting up the speedo. If you are still having problems them try switching out the speedo to eliminate it as a problem. If everything works then it's the speedo but if you have the same problem then it may be something in the radio.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 03-04-2006, 10:36 PM   #13795
Jon Kerr's Avatar
BUMP
Jon Kerr is offline   Reply With Quote
Old 03-05-2006, 04:40 PM   #13796
Send a message via AIM to Roberto Falcon
Is it nessacery to run the rear shock tower spacer?
Awesomatix USA - Speed Passion - Superior Hobbies
Roberto Falcon is offline   Reply With Quote
Old 03-05-2006, 05:37 PM   #13797
Default Mi2 onTechnical Track?
I need some setup help for a very technical track on carpet using foams.
I have the older Mi2 w/the kit shocks using Xray springs (I never got the the new shocks and springs). I am running stock and 19T w/3300 batteries. I do have the older Teemu chassis but I thought I would need more flex and movement for this track so I have the standard chassis on
The track is 120 x 60 ft but the setup is all turns. Everything is a shortshoot to then next turn. There is no straight that is more than 8 to 10 ft before you have to turn left or right.
I want to be on power except at half throttle around all the turns but I cannot seem to get the on power steering. I am pushing.
Any setups or advice on things to try
The shop is speedzonerc.com in Rocky Hill, CT and since the shop keeper has shuie kits and parts on the shelf I want to make this track work for me.
LeadFoot is offline   Reply With Quote
Old 03-05-2006, 06:31 PM   #13798
Anyone know whats the part number for the cvd's for the EC and spare axle pins... ? , I can't find them in the website.
Old 03-05-2006, 06:40 PM   #13799
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
axle pin is U1633 and the axle is U3020
Old 03-05-2006, 06:44 PM   #13800
heavy's Avatar
Trader Rating: 20 (100%+)
U3026 pins and screw - spares for CVD 4 pins and 1 grub screw
U3020 drive shafts
U1633 SPEED PACK - Needle Rollers (pk) various pins including cvd and axle pins
Honorary Life Member Logan RCCC -Mi6 and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6
Boondall. SuperShot, XX, XXT, SVR,Schumacher Storm
heavy is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
