Old 02-15-2002, 02:19 PM   #1366
Ian S's Avatar
Smilin Joe, i had that same problem, i had to put my HUGE acoms receiver on the top deck to make it all fit. Cause the receivers on the top deck it means i can put my Zero V Extreme with the buttons facing out, much easier for programing.
On another note, has anyone else had problems with the front left diff mounts, where they screw into the chassis is not countersunk enough so the screws stick out slightly, all the rest of the holes are ok.
Ian S is offline   Reply With Quote
Old 02-15-2002, 02:46 PM   #1367
Send a message via ICQ to MattW
I've posted this before, but this is how i have my car layed out.
You shouldn't need to get at the tensioner nut, just run it as loose as it will go.
MattW is offline   Reply With Quote
Old 02-15-2002, 03:52 PM   #1368
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Ok I know everyone says to run the belt as loose as you can, and thats how I have mine, but its rubbing on the bottom on the chassis. Am I missing something?
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 02-15-2002, 04:34 PM   #1369
ian - The only screw I had issues with was the front shock mount. It feels like the screw is too long.
CS
Smilin Joe is offline   Reply With Quote
Old 02-15-2002, 07:05 PM   #1370
CS
Old 02-16-2002, 02:52 AM   #1371
David, Where on the chassis is it rubbing??
Old 02-16-2002, 12:55 PM   #1372
STLNLST's Avatar
Trader Rating: 19 (100%+)
Racer X- Nice article on the mission in the March issue of Xtreme. Too bad the guys down there messed it up. In the begining of your article you clearly state what gear you were using and the side bar that says specifics state your body as a lexan buggy, speedo as Novak C2, motor as Tamiya Acto-Power stock motor, and tire's as front-proline M3 4rib and rear- proline M3 step pins. Would you still have all of that steering with those tire's on the car...LOL Hopefully when you review the next car they will proof read before they print. Enjoy the time off because it's back to work at the begining of March. Nice paint job on the car. Next time let's add some on my flavor to it
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 02-16-2002, 10:54 PM   #1373
Anybody racing the Mission on asphalt now? We're starting to take it to the tar here and I want to see if I'm on the right track. I'm basically running a variation of Ron Atomic's set-up with the most noticable change being the shock position ( #3 hole).
Stika525 is offline   Reply With Quote
Old 02-16-2002, 11:43 PM   #1374
AdrianM's Avatar
Sticka-Call us at Schu USA on monday. Rons setup is a good start if you use way softer springs (blues)
Adrian Martinez
Old 02-16-2002, 11:59 PM   #1375
I am putting mine together now....
Our track is small...with one sweeping turn and a lot of switch backs. What gearing should I go with? what pulley?
_neas_ is offline   Reply With Quote
Old 02-17-2002, 01:23 AM   #1376
neas: How small is small? Less than 100'x40', I would try the 17t pulley first. If it seems a little slow, I'd switch to the 20t instead of trying to gear up the motor. The speed should really noticable if it's slow.
Adrian: Will do. BTW, it was a pleasure to put a face to the name when we met at the Snowbird. Did you notice I ask about the Mission and NOT the Axis 2?
Old 02-17-2002, 05:06 AM   #1377
BagofSkill's Avatar
Default Mission transponder mount, 2nd attampt
I think I've got this figured out now, props to Oasis2002. This is a template for my transponder mount for the Mission. It fits on the front body posts. For me that's the best position as the car is 18 grams underwieght so I put 20 grams behind the motor for balance and because timing gear isn't included in the wieght I have the transponder on the very front. This has helped me at least 3 times so far. I recomend that you print the image onto something sticky like masking tape (if that'll go through your printer) and then stick that onto your material and cut it out along the lines. I think most materials would work but recomend sheet Carbon Fibre or plastic. Before you go too far check that the dimensions remain accurate once printed.
BagofSkill is offline   Reply With Quote
Old 02-17-2002, 07:09 AM   #1378
Racer X's Avatar
STL: Thanks for the kind words, I think that some of the specs were crossed with the off road car in the same issue. Next time, I'll put a Prince sign on the roof...that good for you? (lol)
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 02-17-2002, 08:45 AM   #1379
STLNLST's Avatar
Racer X- The Prince sign is a start but you need some brighter colors in there Did you see my last body? The bright pink with greenish yellow flames and checker boards in the front. If I don't win a race I might as well get some ohhhhs and ahhhhhs from the paint job....LOL
Old 02-17-2002, 03:00 PM   #1380
I can see some wear on the bottom chassis, and on the top plate around the diffs, does the gray belt help fix that?
I ran Rons setup yesterday but without the new top plate and sway bar and I had a massive traction roll, so I layed the shocks in all the way and it did help alittle but it still wanted to pop up on two wheels in the corners. I was using 33r's with HPI red inserts which just had hella corner speed and my lap times were fast, when it was on its wheels. Any idea's on ways to keep it on all fours? lol
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
