Old 02-28-2006, 11:48 AM   #13726
Super Moderator
Trader Rating: 17 (100%+)
Interesting, I am going to work on setting my fans up. I have two that I want to work on there and I am just brainstorming some possible ways.
Tekno | BLOK | JConcepts | RaceReadyProducts | BOOMrc
Bob Barry is offline   Reply With Quote
Old 02-28-2006, 12:48 PM   #13727
Jon Williams's Avatar
C'mon, Schreff. Post something--or get back to work...
Jon Williams is offline   Reply With Quote
Old 02-28-2006, 01:14 PM   #13728
Originally Posted by STLNLST
No matter what class we run I OWN SCOTTY!!!!
I've said it before and I'll say it again.....you should be the LAST one talking about someone OWNING someone.
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 02-28-2006, 01:16 PM   #13729
schreff's Avatar
Send a message via AIM to schreff
Work, what's that?
Here's my setup from this past weekend at Horsham. In no way is it my final setup. I am still working on the car as there are a ton of things to try yet.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 02-28-2006, 01:24 PM   #13730
John Tag's Avatar
Trader Rating: 41 (100%+)
Begger....
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 02-28-2006, 01:50 PM   #13731
Super Moderator
Hey Schreff, what did running the T2 blocks give you?
Old 02-28-2006, 01:57 PM   #13732
schreff's Avatar
T2 steering blocks fix a couple issues...
#1 - They change ackerman for the better.
#2 - The steering throw is better and the servo saver doesn't end up hitting the turnbuckle.
#3 - There is less offset in the bearings in the hubs.
To put T2 steering blocks on the car, you need T2 caster block bushings, and you need to put an XRay rod end on the front camber link that attaches to the caster block. You will then use a 3x12mm BH screw to attach it. No more ball end. You also need to shim the steering block a little inside the caster block. I did a little trimming myself to use a 2mm shim. That way I can raise or lower the steering block as I see fit. At this time, the 2mm spacer is on top of the steering block. Also, as in my setup sheet, there is an additional 2mm spacer on top of the caster block, which is under the camber link. Just like how XRay does theirs. I might takes those out or go to 1mm has the car did have a little too much roll.
It's getting there though. The car was smoooooth.
Lata,
Schreff
-Jason Schreffler-
Old 02-28-2006, 02:01 PM   #13733
Super Moderator
Sounds like I will be getting some Xray parts LOL
Old 02-28-2006, 03:57 PM   #13734
Trader Rating: 238 (99%+)
Schreff,
Did you use the three hole or two hole steering blocks?
Do you think horsham has them in stock?
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA, Race Ready Products, Garcia Graphix and Integy***
Fred Perkins is offline   Reply With Quote
Old 02-28-2006, 04:13 PM   #13735
Jon Kerr's Avatar
Lata,
Schreff
Can you post up a pic of this mod? Is this something more for the rug you think?
Jon Kerr is offline   Reply With Quote
Old 02-28-2006, 04:51 PM   #13736
schreff's Avatar
Jon, if you want a pic, Williams' photos above have T2 blocks on the car. You can see most of what you need there. I will try to take pics with the wheels off the front to show the differences.
As far as it only helping on carpet, I'm not sure. I'm not an asphalt guy. Heck, I haven't run on rubber tires in over 3 years.
That would be better addressed by Pdub.
-Jason Schreffler-
Old 02-28-2006, 05:16 PM   #13737
Jon Kerr's Avatar
Originally Posted by seaball
pm answered.
who is going to stockton in two?
I wish. Good luck up there guys.
Old 02-28-2006, 05:20 PM   #13738
Twin-Kyle's Avatar
Might have to wait in line like the rest of the T2 clan!!!
Twin-Kyle is offline   Reply With Quote
Old 02-28-2006, 07:35 PM   #13739
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
You can also use HPI pro4 or Cyclone ones as well.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 02-28-2006, 08:04 PM   #13740
Jon Kerr's Avatar
I've got some Cyclone one's from when I put the rear hubs on the old car with the BMI "Vegas" chassis. I'll take a look at them and see how they'll work. Might as well, the car's in about 20 pieces waiting for a new chassis.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
