Old 02-27-2006, 03:37 PM   #13711
HarshGuy's Avatar
Originally Posted by STLNLST
Just remember this............you wore the mullet not me
...hmmmm ...mullet challenge "nats version"?
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 02-27-2006, 03:47 PM   #13712
STLNLST's Avatar
Trader Rating: 19 (100%+)
HE'S NOT RUNNING THE GROWN MAN CLASS
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 02-27-2006, 07:56 PM   #13713
AdrianM's Avatar
Originally Posted by Scott B
Thats a good goal for the Nats Clint, Mine is to have a faster Quailfing time in 19t then you have in MOD.
Thats pretty common. Its easier to put down 19T HP vs. Mod HP. The question is what is YOUR best time in Mod?
Adrian Martinez
Old 02-28-2006, 01:05 AM   #13714
Originally Posted by MattW
Is that a seperate one way unit?? sounds like it might be the old one way, but with 2 of the same outdrives. The old unit had the bearing in the outdrive, the new one has them in the hub, and no you can't swap the parts.
i have 2 oneway units. one is just sliping and one was locking the wrong way so on power it would just be freespining.
right i have just took the one that was locking the wrong way apart and took the bearings out. they are like in a metal case/race that just slides out so i just swaped it arround and its now fine. on the metal bearing case/race it says on it germany "germany HF 0612" then a arrow.
can u get the bearings and case sepirate from the compleat one way unit so i could replace the one that is sliping??
thanks and sorry if i am confusing this
cheers
bob
bob33 is offline   Reply With Quote
Old 02-28-2006, 03:07 AM   #13715
SA_Racer's Avatar
Originally Posted by SA_Racer
Guys, Iím just curious, I havenít had me MI2 for long and donít have the cash for an EC right now, but would like to convert the drive train to the one that is used on the EC.
My question is this, will the layshaft pulley system from the EC fit in my std MI2? from what I can tell the rear belt is the same so If the width between the layshaft mounts is the same on the cars and the bearings are the same, the EC layshaft and front belt should work, but the only way I can be sure is if someone here who knows both cars can comment, I am also prepared to do some dremel work if necessary
seems nobody knows the answer please guys help me out
SA_Racer is offline   Reply With Quote
Old 02-28-2006, 05:04 AM   #13716
Send a message via ICQ to MattW
Bob, hmm, not totaly sure i know what you mean, but i'll try!!
I only every tried to take th bearings out of the origional one way - and couldn't get them out. No idea about the new ones. However, on either unit, if the actual bearing comes out that easiy then i'm not sure i would want to rely on it not to be slipping during a run.
You can probably buy the one way bearings seperately from an industrial bearing supplier, i haven't ever tried. They are not available seperately from Schumacher - only in the outdrive for the old unit, and in the hub for the new unit.
SA, I'm going to say no. Technically that isn't true, but it's a lot of work to get it to fit (milling machine etc!!) and the front belt won't be quite the correct length - slightly too long.
MattW is offline   Reply With Quote
Old 02-28-2006, 05:10 AM   #13717
thanks matt. well i took it out and spun it round. it was hard to get out tho but i have poped it back in the right way (took abit off efot aswell) also put a smidge of glue on it and i cant make it slip evan holding it in a vice and using a wrench in the outdrive trying to make it slip so my guess is it will be ok in a run now?
thanks for the help tho.
cheers
bob.
Old 02-28-2006, 06:34 AM   #13718
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Like I said, it can't be done without serious modification and fabrication. Drop seaball a PM. I know he did it and maybe able to tell you what needs to be done.
Jon Kerr is offline   Reply With Quote
Old 02-28-2006, 08:46 AM   #13719
SA_Racer's Avatar
Thanks jon, ill give him a shout
Old 02-28-2006, 09:35 AM   #13720
Jon Kerr's Avatar
Any time
Old 02-28-2006, 09:57 AM   #13721
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
pm answered.
who is going to stockton in two?
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 02-28-2006, 10:15 AM   #13722
Jon Williams's Avatar
Got the ride together...
Schumacher Corner-dsc00905.jpg   Schumacher Corner-dsc00907.jpg   Schumacher Corner-dsc00908.jpg   Schumacher Corner-dsc00906.jpg
Jon Williams is offline   Reply With Quote
Old 02-28-2006, 10:18 AM   #13723
Super Moderator
nice, how did you mount the fan like that? Kind of hard to see in the pics
Tekno | BLOK | JConcepts | RaceReadyProducts | BOOMrc
Bob Barry is offline   Reply With Quote
Old 02-28-2006, 11:21 AM   #13724
STLNLST's Avatar
No matter what class we run I OWN SCOTTY!!!!
Old 02-28-2006, 11:42 AM   #13725
Bob, I mounted the fan using a piece of kydex that I cut out myself. It's a small strip which first mounts to the top deck using one of the top deck holes (make sure you tighten it securely so you don't mess with your tweak).
I then screwed the fan into the mount with a 4-40 screw and nut via one of the fan's mounting holes.
After that, I soldered the leads of the fan straight to the motor. Since the fans are only 5V you may burn one up every few weeks getting 7.2+V bursts, but the extra power is worth it and keeps the motor incredibly cool.
Also, so that you don't burn up the tiny leads from soldering and resoldering, I coiled some extra speaker-type wire underneath the fan.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
