Old 02-19-2006, 06:41 AM   #13591
Default How you checking that your diff is too tight?
aus jd 2703
How you checking that your diff is too tight? Are you holding the spur? Just trying diagnose why you think it is too loose perhaps you are not checking properly
LeadFoot is offline   Reply With Quote
Old 02-19-2006, 07:23 AM   #13592
Rob Phillips's Avatar
Originally Posted by Racer Z
Who has the best price on a new Schumacher foam spec?
Dam, you need to at least run carpet to justify buying another new kit. What's up with the T2? The Mi2 EC looks sweet, but having no parts locally has kept me away from Shue in the past, well at least since about '88.
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 02-19-2006, 11:25 AM   #13593
bender's Avatar
Aus jd-
It sounds as though you are thinking it's loose because of the way it feels, rather than by actually testing it.
To test the diffs in the car, you need to hold the spur gear as well as one rear wheel (or front if you'retesting the front diff) - then try turning the opposite wheel. It should be very hard to turn.
If the diffs are out of the car, then you need to stick a screwdriver or hex driver into the slots on both outdrives, then try turning the pulley.
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 02-19-2006, 12:18 PM   #13594
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
You can order anything you need from www.racing-cars.com and should be able to get it within a couple days. Also, your LHS should be able to get anything you need from them.
Jon Kerr is offline   Reply With Quote
Old 02-19-2006, 07:32 PM   #13595
dbmartin's Avatar
Any suggestions on getting the drivetrain to be more free on the mi2ec. Just got finished building the kit and it is very tight feeling. I noticed now there are 2 washers on each side of the diff/spool, should I remove one of these and if so which side? And for rubber asphalt racing, is it best to run the risers as indicated in the kit?
Thanks for the info.
dbmartin is offline   Reply With Quote
Old 02-19-2006, 07:36 PM   #13596
Jon Kerr's Avatar
Only run one washer on either side of both the spool in front and the diff in the rear. The risers under the bulkheads should work well outdoors for most applications.
Old 02-19-2006, 09:15 PM   #13597
P-DUB's Avatar
You should of gave me a call Dave...Like Jon said; only one spacer per diff is needed. Also keep an eye on the layshaft bearings; sometimes they don't sit flush in the alloy layshaft mounts. Shoot me an e-mail at work and I will send you my setup paul@schumacherusa.net
Larry Pryor
P-DUB is offline   Reply With Quote
Old 02-19-2006, 11:40 PM   #13598
Racer Z's Avatar
Default T2 to SHUIE
Thanks Jon for the reply. I will check it out. Rob...I just want to try something different thats all. I still got top dollars for my T2 anodized blue.
Don,t worry Rob I won't be any slower... so you will still have something to shoot for.
Racer Z is offline   Reply With Quote
Old 02-19-2006, 11:46 PM   #13599
do you guys use locktite on the diff screws and the locking screws??
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 02-20-2006, 01:02 AM   #13600
no its not needed.
bob33 is offline   Reply With Quote
Old 02-20-2006, 06:30 AM   #13601
STLNLST's Avatar
Trader Rating: 19 (100%+)
I used a small dab
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 02-20-2006, 06:35 AM   #13602
AdrianM's Avatar
How did Mod go this weekend Clint?
Adrian Martinez
Old 02-20-2006, 08:13 AM   #13603
He made it into the A!
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 02-20-2006, 11:50 AM   #13604
STLNLST's Avatar
It was fun running with all that power at your finger tips. I was over shooting some of my lines because of the power but I had fun and motor We don't run again until the 4th so look for that to turn some heads when even more So cal guys come up.
Old 02-20-2006, 11:58 AM   #13605
Suspended
McSmooth's Avatar
Cool
Just make the "Edwin Siren" sound, then you'll start laughing so hard that you won't care about your diff anymore.
McSmooth is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
