Old 02-17-2006, 05:59 AM   #13576
IslandBwoy's Avatar
To get the full effect read KingG and Kid's post in the voice of the Crocodile Hunter
LMAO
ON A SIDE NOTE:
Have any of you guys had your 3800's beyond the 50 run mark? There is a guy on one ofthe threads claiming that his have fallen off badly and dont take no more than 2000+ Mah anymore.
Just want to know before i make such an investment.
IslandBwoy is offline   Reply With Quote
Old 02-17-2006, 12:36 PM   #13577
mutley001's Avatar
Sorry for changing the subject here guys but want to get your opinion on something.
Been running my MI2EC indoors on carpet, using sorex 24 tyres, in Stock 27t on a really tight track with high grip. I've been running Teemu's setup from the manual just raising the links on the suspension mountings and using a diff instead of a spool. Its been working quite well but I need to pick up 7 tenths of a second a lap to be in with a chance of a win. I've been thinking about switching to Chris Ashtons setup but I don't have a one-way to try. what would you recommend?
Any advice very welcome.
Paul
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 02-17-2006, 01:21 PM   #13578
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I would definitely recommend a one-way on carpet with rubber tires. Should give you much more turn in and overall cornerspeed.
Jon Kerr is offline   Reply With Quote
Old 02-17-2006, 01:33 PM   #13579
AdrianM's Avatar
If you dont have a one way the spool will certainly be faster than the diff. Diffs kill your turn in steering and makes the car push exiting.
Adrian Martinez
Old 02-17-2006, 05:22 PM   #13580
stuey's Avatar
Paul
hey paul
do what i do drive it like you stole it works for me.
stuey is offline   Reply With Quote
Old 02-17-2006, 10:18 PM   #13581
STLNLST's Avatar
Trader Rating: 19 (100%+)
after the great start in 19 turn with the EC I'm going to run mod for the first time with the car. Everyone knows I hate carpet so the results with the car speak for themselves. If I can pull a top 3 finish in mod tomorrow I'm going to Disneyland Goog luck to the rest of the Schuie gang where ever you're racing.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 02-18-2006, 05:39 AM   #13582
HarshGuy's Avatar
You need to issue a mod mullet challenge.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 02-18-2006, 11:25 AM   #13583
mutley001's Avatar
ok spool it is until i can get a one way. Great advice Stuey
Cheers guys
Paul
ARC R11 2017
ARC R10 2013
Team EAM
Old 02-18-2006, 12:54 PM   #13584
Jimmy Morris's Avatar
I just finished my MI2 EC. Here's some pics.
www.superiorhobbies.com
Jimmy Morris is offline   Reply With Quote
Old 02-18-2006, 04:12 PM   #13585
Are you running a Hummer body on that car ?
Jay Dub is offline   Reply With Quote
Old 02-18-2006, 04:40 PM   #13586
haha yeah. There just super high cause I'm too lazy right now to mount a body. lol
Old 02-18-2006, 10:09 PM   #13587
Racer Z's Avatar
Default Looking to buy a new schumacher for carpet season
Who has the best price on a new Schumacher foam spec?
Racer Z is offline   Reply With Quote
Old 02-19-2006, 02:36 AM   #13588
hey guys just curious what is the advantage of running a front one way?? and it what conditions??
andis there a centre oneway option for the mi2??
whats a really good bearing company money no worry??
im just considering my option but so far im still having trouble with the front diff i might start using thread lock on the diff screw and the locking screw what do you guys normaly do?? just want it to stay set!!
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 02-19-2006, 03:13 AM   #13589
bender's Avatar
aus jd
That car had about 4 months of racing Mod and in that time I never had any problem with the diffs - they are the most reliable part of the car!
Are you sure sure that they're still loosening off?
As the diff lube starts to come off, the diff will have a looser feel to it, but the screw should still be set tight. If any diff was to loosen, it should be the rear diff, as it has the most load on it.
The diffs on that car often felt very free and loose, but they didn't slip on the track.
As for the one-way, the primary advantage is better turn-in when compared to a diff, however you do lose the ability to use brakes - which can make it a bit of a problem on tracks with hairpins
There is no centre one-way option, and the normal one-way will cost you around AU$100 - ask HeavyD for a price.
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 02-19-2006, 03:49 AM   #13590
yeh i re built the diffs and broke them in as ingave it throttle held one wheel the did it to the other then did the other diff and the front diff got a little tighter and the rear went really loose so i took them out and re set the tensions and thats when the set screw broke and then after i fixed that lol the diff screw snapped maybe im trying to set them to tight what do you guys reckon??? help im getting frustrated and confused as this is my first competition car.
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
