Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 02-15-2006, 04:06 AM
  #13546
The Teacher's Avatar
Trader Rating: 62 (100%+)
Kevin K, nice mod on the steering levers... ...just what I need for the brick 2x4's at my track.
The Teacher is offline
Old 02-15-2006, 06:00 AM
  #13547
Default Steering Cranks
The steering cranks have been a long time pet peeve of mine on the Mi2.
If you search way back in the threads almost 1 year ago you will see there were past discussions with people arguing "its a problem" and others saying "no its not" with the "no its not" crowd seeming to take offense at others who were having a problem.
MattW first gave me the suggestion and was one of the first to come on to verify there was a problem and offer a solution. I have his epoxy solution as well as my own.
I have about 10 spares but have not required any since coming up with a similar solution as Kevin K except I used some spare graphite from an old off road car.
While you can say drive and stay off the walls, breaks can happen in a crash as well. I have seen two Mi2s in a local 19T race taken out by one car crashing into both of them going a around a turn too hot.
The steering cranks are a problem and I am glad that others who do have a problem have found a solution but also upset that Schumacher still has not done anything to address the issue.
Before the flames start, I have owned an Axis, Axis 2, Mi2 and hopefully by the end of the year an EC but that does not mean I can't have some Constructive criticism
LeadFoot is offline
Old 02-15-2006, 06:36 AM
  #13548
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally Posted by exint2
Droop !!!
Building the Mi2EC as we speak and Teemu's droop measuring is slightly confusing.....
Can anyone give me a conversion of his figures to a standard droop guage or using the Associated measuring system?
Thanks !
There really isn't any conversion but if you set it up Teemu's way first, then check what the measurement is on your gauge, that'll tell you where to set it your way every time. Here's how I described Teemu's method a few pages back
Originally Posted by Jon Kerr
Make sure your camber is set perfectly before you set droop as the angle of the axle can change your reading. Then take the wheels off and set the car on a flat setup board. Take your calipers and set them to the droop you need, i.e. 24mm. Use the back of the calipers where the rod extends to measure to the top of the axle and adjust until it's just touching the calipers. I hope that describes it right. If not, let me know and I'll take a pic and post it.
Jon Kerr is offline
Old 02-15-2006, 07:34 AM
  #13549
Euge's Avatar
Nice mod, Kevin. I'll definitely do that for my bellcranks.
2x4's + carpet + foam tires + an early turn in= instant death to parts
Those dots suck too. (not to minimize the difficulty of driving around dots and not launching your car.)
Here's a pic of Kevin's car at the Novak race at Trackside. You can imagine what turning in early on a turn like that will do.
Euge is offline
Old 02-15-2006, 07:38 AM
  #13550
Euge's Avatar
actually, now that I look at that pic again, it was probably the most forgiving of all the turns on that layout. most of the turns had a sandbag on top of the turn so that the wall wouldn't move.
Euge is offline
Old 02-15-2006, 07:57 AM
  #13551
IslandBwoy's Avatar
Listen to you guys complaining about your tracks. At leatsyou guys have indoor tracks to speak of . NOthing is worst than hosting one of the biggest races (snowbirds) and getting your a$$ handed to you every year from guys that have indoor tracks to speak of.
IslandBwoy is offline
Old 02-15-2006, 08:16 AM
  #13552
Euge's Avatar
I hear you. We are lucky to have great indoor tracks nearby.
However, FL sounds good right about now...
Click for Weather for Florida
Click for Weather for Illinois
Euge is offline
Old 02-15-2006, 08:35 AM
  #13553
Jon Kerr's Avatar
Don't get me wrong, I'm not complaining about SoCal. I've struggled there but it is nice having somewhere indoor to race on a regular basis. Even if it is 100 miles away. We're lucky to have that.
Jon Kerr is offline
Old 02-15-2006, 09:02 AM
  #13554
IslandBwoy's Avatar
True. Im going to tell you though. It sucks looking forward to race day and then it freak'n rains.
Euge: Of course its beautiful today. there are no races. Say lets race a couple times and i bet you it'll freak'n snow.
Old 02-15-2006, 09:28 AM
  #13555
Euge's Avatar
Any of you guys ever race in the rain? I saw some video from a race in Europe where they did that. That would be kind of fun.... except for all the additional prep work and potential shorts...
Euge is offline
Old 02-15-2006, 10:56 AM
  #13556
PW
PW's Avatar
Hey Jon...How about shrinking that pic...
Here are some more foam tire setups:
Teemu is on vacation for 2 weeks so it will be a little while before I have his setup.
I did make a mod to my front A-arm: filled the stock shock mounting holes and redrilled in the center
File Type: pdf
File Type: pdf
PW is offline
Old 02-15-2006, 11:33 AM
  #13557
Sanabria's Avatar
Paul, thanks for the chat and info on the EC, your car was dialed!!
I'll be talking to Tim very shortly.
Sanabria is offline
Old 02-15-2006, 12:16 PM
  #13558
Jon Kerr's Avatar
Sorry. Just linked it to SoCal's site. That should be better.
Are those the same arms you showed me in Vegas?
Jon Kerr is offline
Old 02-15-2006, 12:40 PM
  #13559
PW
PW's Avatar
Yeah Joel...Great to see ya racing again!
Jon...Much better!!!!! Yes, same arms that have been cracked and glued several times over
PW is offline
Old 02-16-2006, 09:55 AM
  #13560
STLNLST's Avatar
Trader Rating: 32 (100%+)
TTT
STLNLST is offline
