Old 02-13-2002, 07:50 AM   #1336
BagofSkill's Avatar
yeah, your mount does look good. Lets face it, Carbon is the ONLY material to use! Mine is carbon too. Yours is similar to the official Axis 2 part, 'cept that it was S1. No match!
BagofSkill is offline   Reply With Quote
Old 02-13-2002, 07:55 AM   #1337
I wondered about the A2 mount and if it would fit BUT this is my first Touring Car (so don't have one from A2) and no one on here has ever said anything about using it so............
wilson10 is offline   Reply With Quote
Old 02-13-2002, 09:48 AM   #1338
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
A2 mount is too short, and the holes are not wide enough. That was the first thing I tried. But for balance, I think most drivers are putting the transponder behind the motor.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 02-13-2002, 11:33 AM   #1339
Dark,
I know I have considered it several times but I would get it from SpeedtechRC if I were to buy it online. I just like to support the local guys and I like to get the kits from my LHS so if any of the parts are out of spec I can get new ones fer free.
IKE
FoamDonuts is offline   Reply With Quote
Old 02-13-2002, 04:10 PM   #1340
Tractionroll's Avatar
Ayone have a setup for a tight carpet track on foams they want to share?
Tractionroll is offline   Reply With Quote
Old 02-13-2002, 04:21 PM   #1341
FoamD- what happened to the LHS that would allow you to run foam tires, stocked mission parts AND has Mission in stock???? Just order it and be HAPPY!!!!!!!!!!
Old 02-13-2002, 05:14 PM   #1342
Hey Guys!!!!!!!!!!!!!!!!!!!!
I just ordered my Mission today! Maybe PW or Adrian can shed some light on the reasoning behind this screw shipment being bad????When my LHS ordered it today he was talking to PW and I told him that i wanted to order the screw kit upgrade and PW said that there was something wrong with them??????Whats up and when will you guys get another order of them in?
IKE
Old 02-13-2002, 06:43 PM   #1343
PW
PW's Avatar
Send a message via AIM to PW
Hey FoamD....The head of the screws in the screw kits were very thick and they did not sit flush with the chassis. We are trying to get the screws hurried, but that is the only screw they have right now.
PW
PW is offline   Reply With Quote
Old 02-13-2002, 06:54 PM   #1344
How much is this screw kit and what does it come with?? THanks!
Old 02-13-2002, 06:58 PM   #1345
PW, as if you didnt already figure it out mine is the one that SB ordered today along with his 6 sets of TakeOffs. I will just wait for the new screw kits to come in and I will order them when I get my threaded shocks and the carpet upper deck. Thanx again
IKE
P.S.Is it a 85degree countersink bit for the chassis?
Old 02-13-2002, 07:29 PM   #1346
What is the carpet upperdeck? How does it differ from the regular top deck?
Les at MDI said that the original upgraded screw sets came in with some problem, they sat about a mm higher then the countersink hole on the chassis.
I am just going to put mine together with the stock screws...everyone seems so intent on the standard hex screws why doesn't Schumacher just put that into the kit in the North American market?
_neas_ is offline   Reply With Quote
Old 02-13-2002, 08:50 PM   #1347
hehehhe, I was asking myself the same question today about the carpet top plate. I couldnt see any visual difference between the carpet one and the stock one when I looked at Ron Atomics pics of his car. I just wish that Kelly Lunsford would get his screw maker up and running so I can have hexhead screws for my car. I think that some of the guys on here have gone out and bought the screws in mass amounts in stainless steel with the hexheads on them, that may be what I end up doing.
IKE
Old 02-13-2002, 08:51 PM   #1348
Send a message via ICQ to SirSpeedy Send a message via AIM to SirSpeedy Send a message via Yahoo to SirSpeedy
The carpet upper deck simply has less material removed in the center area....the area from behind the steering posts to the front of the motor mount.
This gives the part more torsional strength.
Tim Davis
SirSpeedy is offline   Reply With Quote
Old 02-13-2002, 09:40 PM   #1349
Default Screws
My LHS is lacking...in things like bulk screws etc. Do you guys think I could get good quality ones at a large home improvement or hardware store? Lowe's here in town has endless rows of bulk screws and things....
Old 02-13-2002, 10:17 PM   #1350
PW,
I heard that you guys were dumping in the PRO MOD main with 7 turns!!!!BATTERY WARS ARE COMING!!!!THE BATTERY WARS ARE COMING!!!!!! anywho how many runs were you getting out the tires at 2.28" ?
IKE
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
