Old 09-12-2001, 10:53 AM   #121
AE_Racer's Avatar
Send a message via AIM to AE_Racer
does anybody want an Atlas YM34 V3 for their Axis 2(or just to buy)? I knew I shouldn't have bought that thing....uuugggghh
AE_Racer is offline   Reply With Quote
Old 09-12-2001, 11:41 AM   #122
ovalnator's Avatar
Trader Rating: 43 (100%+)
Send a message via AIM to ovalnator
Whats wrong w/ it??? Got any pics??
[email protected]
ovalnator is offline   Reply With Quote
Old 09-12-2001, 04:06 PM   #123
Any of you guys know anything about the new P2K2 motor coming out from trinity? Curiosity is killing me...wanting to know what improvements they made...from the pics it looks like standup brushes...
markg is offline   Reply With Quote
Old 09-12-2001, 04:27 PM   #124
AE_Racer's Avatar
theres a pic(thanks RCCA!), Steve from RCCA said it was the same armature less a few laminations to move it into a slightly high RPM range.
cant wait to find out...
Old 09-12-2001, 10:02 PM   #125
AdrianM's Avatar
The following are the parts that will carry over to the SST Mission:
Lower suspension arms
Lower pivot balls
Hub Carriers
Bearings and crush spacers
Hexes
Drive shafts
Blades
Ball studs/cups
Turnbuckles
Everthing else is diffrent. It was time to do a major redo of the SST series. We have a great suspension system but we wanted to update the drive train to incorporate the things we have learned over the last 5 years. As a result many of the parts attached to the drive train had to change.
Everyone at Schumacher UK and USA are beyond excited about this car. There are so many things that are so right about this car.
The new diffs are easier to assemble and adjust, they will diff less if you lift a wheel and they will have less rotating mass. Tungsten balls are included in both kits...
The car will feature a new belt material that has less drag as standard equipment...
New wheel base and suspension sweep adjustments will give races new tools to enhance chassis dynamics...
The twin track drive train will be more efficient than shaft or single belt drivetrains...
And much much more...
Adrian Martinez
Old 09-13-2001, 05:21 AM   #126
AE_Racer's Avatar
hey Adrian, thanks for the info...who can I contact to reserve a Mission? This sounds like a good b-day present(Oct 19) And you say late October as in, like 25th or before that? Thanks for the info..
Old 09-13-2001, 12:36 PM   #127
Smile
AdrianM:
Can you advise which is the better matched Pana's 3000SMH? Trinity or Reedy?
Thanks.
MIKA is offline   Reply With Quote
Old 09-13-2001, 02:26 PM   #128
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Thanks for the update Adrian...
I dont want ot bead a dead horse.. but what about the shocks will the axis threaded be good... just trying to figure out what to sell my second spare 2 with?
also.. u know what the scoop is with all the new 19t spec motors coming out ?
Hey when are the cross cars gonna be in ?.. and do the rolling chassis come with tires ?
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 09-13-2001, 07:28 PM   #129
AdrianM's Avatar
Spooky-It will take ~4 weeks to get our Cross shipment. We will have the CF01 FireForce F-1 Car, Bodys (F-1 and Prototype), all the Ti links and hopups as well as the rare hop ups like the T-Bar conversion and others.
If you want a CF01 or a Mission have you local hobby shop call Schumacher USA at 813-889-9691. Do it soon, the first batch of both cars are going fast!
The Threaded shocks will work with the SST Mission.
Reedy and Trinity have 19T spec mods coming out. I have Reedy 1st gen prototypes but I think the production motors will be better. Trinity just released the Chameleon 2. It has better magnets and a comm lock.
Mika-You can't go wrong with either brand. Look for voltages over 1.125v, IR's less than 20. If you run stock or 19T run time is unimportant. For mod get cells over 350sec.
Adrian Martinez
Old 09-13-2001, 08:28 PM   #130
kitracer's Avatar
looking for a new touring car and the SST mission sound great.
Just wonder any option parts that I need to buy like
One way for front and mid, U drive, Graphite componments etc..
( please don't do a XXX-S or Pro 3 where u need to buy so much options parts)
Valua for money is very important, like the TC3 team kit and Yokomo SP.
The belt looks like a ABC two belt system. Can't wait to see the actual car.
kitracer is offline   Reply With Quote
Old 09-13-2001, 08:32 PM   #131
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Kitracer......there will be two versions of the car a standard kit and a PRO kit. The prokit will have the graphite and stuff in it. They will both come with alum motor mounts and carbide diff balls aswell as swaybars as standard equiptment. You wont need to get too many hopups if any when you get the car. This thing is going to be DIALED out of the box.
Kevin K is offline   Reply With Quote
Old 09-14-2001, 03:36 AM   #132
Post
Thanks Adrian.
Old 09-14-2001, 05:10 AM   #133
Thanks for the info, AE_Racer...I've tried a number of motors, and just keep coming back to my good ole trusty P2k for overall performance...some the other motors are really fast at first, but die fast or require a lot of maintenance to keep them fast, probably due to excessive heat, which kills magnets and brushes...seems the P2k is a lot more resilient and robust...hopefully the new version will maintain that...
Thanks for the update on the Mission...can't wait to get mine. Adrians comments about the success of the suspension, and improvements in efficiency of the drive train, all point to a model that will keep Schumacher at the top of the heap...
Later Dudes...
Old 09-14-2001, 05:34 AM   #134
HarshGuy's Avatar
What option parts to you "need" to buy for a XXX-S?
HarshGuy is offline   Reply With Quote
Old 09-14-2001, 07:14 AM   #135
AE_Racer's Avatar
Later Dudes...
Yea, other than a X-Star, Midnight 2, and some of the older Paradox's, and 1 Rage(chunked it as soon as I ran it once), all i've ever run is P2Ks..I've had regs, Pros, one Fantom, and now running an Axiom..Never had one fail on me
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
