Old 02-04-2006, 05:50 PM   #13336
Conrad's Avatar
The wider the track width the more stable and settled the car is, where as when its narrow its alot more nimble and is supposed to generate more grip hence the thinner hexes on the EC (or so it was mentioned on here before the car came out). I done some checking myself between the Mi2 and EC and i had the EC track widths coming out almost identical front and rear. It was my old Mi2 that was wider at the front than the back, only by about 1mm, something that could easily be corrected with spacers. My measurements also has the EC track widths wider than the Mi2 by about 1mm front and back.
Swith Racing [www.swithracing.co.uk]
Conrad is offline   Reply With Quote
Old 02-04-2006, 05:59 PM   #13337
AdrianM's Avatar
We run the EC with no spacers in the front and the 1mm spacers in the rear.
Adrian Martinez
Old 02-04-2006, 08:39 PM   #13338
STLNLST's Avatar
Trader Rating: 17 (100%+)
Ran the car again and tested a few things. Wound up back at last weeks set up. Had some very bad luck in the first round and broke in the 2nd which put me in the B-main (only because the the bad luck) The car is awesome. In the Bmain I turned it into a motor clinic down the straight for the fans. The DC power is no joke. I already know what to do for next weekend and Mo and I will be ready to lay it down once again. This is a good car. We already know we can run with the Corally guys now. We just have to dig a little deeper.
How did everyone else do???
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 02-04-2006, 09:53 PM   #13339
Jack Smash's Avatar
Trader Rating: 28 (100%+)
Originally Posted by STLNLST
Ran the car again and tested a few things. Wound up back at last weeks set up. Had some very bad luck in the first round and broke in the 2nd which put me in the B-main (only because the the bad luck) The car is awesome. In the Bmain I turned it into a motor clinic down the straight for the fans. The DC power is no joke. I already know what to do for next weekend and Mo and I will be ready to lay it down once again. This is a good car. We already know Mo can run with the Corally guys now. I just have to dig a little deeper.
I completely agree Clint.
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
Old 02-04-2006, 10:00 PM   #13340
HarshGuy's Avatar
I have to take credit for some of the scheuy finishes 1 - I TM'd STLNLST's car backwards in Qual-1, but only after DJV was doing his baby heuy impression, and 2 - I didn't think Mo was lapping me so I shut the door on him in the A main
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 02-04-2006, 10:04 PM   #13341
P-DUB's Avatar
I see how it is Harsh!!!! Can't beat 'em....So take 'em out
Larry Pryor
P-DUB is offline   Reply With Quote
Old 02-05-2006, 01:05 AM   #13342
cornerspeed's Avatar
Jon Kerr and I tested the track width also tonight at SoCal. No spacers in front and spacers in rear. Picked up a little more corner entry steering and took away a little from the middle on out. Just enough to balance the car out perfectly. Then I went to the 1.5mm bars front and rear from the 1.2mm and picked up some more cornerspeed, .2 to .3 seconds a lap faster. I believe Jon did not like it as much though.
Thanks Jon for the motor, needed a little more then what I had for 19T. Can't wait to get my DC 19T.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 02-05-2006, 01:20 AM   #13343
Jon Kerr's Avatar
Donny- No Prob.
SoCal was fun tonight. 19 turn has been stacked with fast drivers there for a while. (Top 10 within 8 seconds on the track.) I also didn't run as well as I wanted in qualifying and ended up in the B. But I did win it again and had a really great race with a T2 and a Cyclone. We're learning a lot up there and we've got a few things to try next time. I love the corner speed and consistency this car gives.
Jon Kerr is offline   Reply With Quote
Old 02-05-2006, 04:02 AM   #13344
Wirre's Avatar
Thanks Adrian. I'll give it a try asap.
Kyosho Ultima RB-5 SP
Kyosho Ultima RT-5
Kyosho Lazer ZX-5 FS
Orion Vortex Motors and ESC
Wirre is offline   Reply With Quote
Old 02-05-2006, 04:56 AM   #13345
Originally Posted by duckman996
The tires you are running will effect how much bite you will want from your diffs ... are you running rubber or foam?
rubber on carpet do the rear need more bite front less or otherway round? and how much cos at the mo I`ev set em so if i press the rear down and hit full power they just slip at the rear but only just so under full load held back, the fronts give a bit more, but having cleaned them up we got rid of the gritty feel and rough feel to them they was clean but rough when turned.
Wildie is offline   Reply With Quote
Old 02-05-2006, 05:01 AM   #13346
Wirre's Avatar
Are you using a one-way in the front? And what tires are you using?
Kyosho Ultima RT-5
Old 02-05-2006, 05:03 AM   #13347
sorex tryes and standard front
Old 02-05-2006, 11:42 AM   #13348
Hey Clint, MO, RacerX- I am thinking of going up there to Stockton next Saturday if I can find someone to share a ride with up there. If I make it up there, can any of you help me out with the foam tire thing. My truer sucks for 1/10th scale tires and I don't know what I am doing anyways. Should I start with PW's set-up from the kit or MO's set-up?
Donny Vinkemulder
TLR Driver
Old 02-05-2006, 12:15 PM   #13349
Racer X's Avatar
Cornerspeed:
There are plenty of tire truers at the track so that won't be a problem. I think you may want to start with MO's setup since you have always liked that edgy kind of setup (car is VERY reactive). Anything else you may need, we can hook you up with. Hope to see you there...
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 02-05-2006, 01:45 PM   #13350
Super Moderator
Well ran yesterday with Fred at Horsham. Fred ran 19 and I ran stock. He used Fernando's setup and made slight changes...I used PW's setup. we ran on the layout that they will have at Snowbirds (hated it ). Freds car looked pretty good but it didn't rotate as well as he wanted it too...maybe driving style? My car was a mess. It was awesome in practice and not bad in the first round but as the bite started to get insane, my car started going backward. I really only had 1 complete run out of my qualifiers and the main and that was the first qual, which I still had to pull over to make an adjustment two times. So anyone going to Snowbirds...don't run the PW Kit setup LOL.
Good Luck to everyone going down....keep us updated.
Bob
Tekno | JConcepts | RRP | LutzRC | BOOM RC
Bob Barry is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
