Old 01-30-2006, 01:14 PM   #13201
Send a message via ICQ to MattW
Anyone got much experience with or opinions on DIP?? I keep hearing it crop up, but don't think we can get it in the UK.
MattW is offline   Reply With Quote
Old 01-30-2006, 01:57 PM   #13202
Super Moderator
Trader Rating: 17 (100%+)
Hey PW, I was looking at that setup and am surprised...My first thought was that the car is going to have a ton of chassis roll. would you agree? Also does that seem to help vs a car that runs relatively flat?
Guys I run Paragon on everything. If I need more traction with rubber tires outside then I use Trinity's Red Dot. I will end up trying some other stuff later this spring. I just make sure I wipe the tires down with motor spray and a rag before putting anything on them.
Bob
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 01-30-2006, 01:59 PM   #13203
Send a message via ICQ to piorc
Default which springs?
Hey guys, which springs do u recommend to buy to run on my trf shocks on my mi2?
piorc is offline   Reply With Quote
Old 01-30-2006, 02:01 PM   #13204
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
for asphalt Schumacher whites are a good starting point
Old 01-30-2006, 02:05 PM   #13205
IslandBwoy's Avatar
Before White/WHite there was blue and silver (associated). I still use that combination and have had no need to vary from that.
IslandBwoy is offline   Reply With Quote
Old 01-30-2006, 02:06 PM   #13206
Super Moderator
I even ran blue blue and silver silver. it all felt pretty good.
Old 01-30-2006, 02:12 PM   #13207
IslandBwoy's Avatar
Does DIP = Bengay? I heard you guys talking about using that the other day. That stuff surely smells like it. Maybe we can lend that stuff to the RDX fan boys after we tear them a new one with the EC...
Old 01-30-2006, 02:23 PM   #13208
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
No DIP doesnt equal to bengay lol.. Rashad when you see lil'b again ask him for his sauce he made its awesome.. I think its better than DIP
Roberto Falcon is offline   Reply With Quote
Old 01-30-2006, 03:53 PM   #13209
kt racing's Avatar
Send a message via AIM to kt racing
PW,
YGPM
KT
kt racing is offline   Reply With Quote
Old 01-30-2006, 06:45 PM   #13210
AdrianM's Avatar
Tire Tweak is pretty hard to beat. However its important you use it the right way.
I like to clean new tires with buggy grip and a blue paper shop towel until no more gunk shows on the towel when you wipe them.
Put Tire Tweak on 25 min before you race. Wipe it off really well 5 min before you race.
Some guys like to clean the tires with Buggy grip after wiping off the tweak.
Hybrid DIP is a little more agressive than Tweak. If you want more steering try DIP. Sometimes its faster...sometimes its not.
Adrian Martinez
Old 01-30-2006, 07:40 PM   #13211
P-DUB's Avatar
Bob
Chassis roll is your friend in very high-bite conditions....Keeps the car smooth and easy to drive But what makes you think there would be a lot of chassis roll? Hinge-pin location?
As for Paragon on rubber tire outdoor....Gives tons of steering, but here in Florida you will roast the tires in 3 minutes DIP or Tweak is the way to go
Larry Pryor
P-DUB is offline   Reply With Quote
Old 01-30-2006, 08:38 PM   #13212
Jon Kerr's Avatar
I've never really liked Paragon outdoors. Makes the car feel like the tires are dirty the whole run. It's been the only thing to use at SoCal for years but apparently there's a shortage of it so people are finally trying different things. Since I still have a lot of it left, I'm still using it there Depending on what track I'm on, I like Tweak, DIP is good, some tracks I simply clean the tires with Buggy Grip after the run and thats it. I'll even run them dry at some places only cleaning with motor spray. If the track is dusty, sauce can be the worst thing for the tires. All it does is pick up more dirt and make the car skate around.
Jon Kerr is offline   Reply With Quote
Old 01-30-2006, 08:50 PM   #13213
Oasis's Avatar
Trader Rating: 36 (100%+)
TQ Blue works well on parking lot tracks and does not make your car smell on the ride home.
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 01-30-2006, 09:09 PM   #13214
IslandBwoy's Avatar
Thats the problem right there for me. I rather something that is consistant. During the first stickum error the stuff seemed to work while testing but I could never get through 5 minutes with it. It seemed to wear off somewhere is the final minute and a half.
You are so right about that. Locally you can spend 2-3 laps trying to get dust off your tires if you get 'derailed', but i've never tried not using anything under dusty conditions. I'll keep that in mind next time and try to just prep the tire well in advance to see what happens
Old 01-31-2006, 05:35 AM   #13215
Super Moderator
PW - well the High hinge pin location combined with the lighter weight oil. I would think the car would roll when going hard into a corner. I have never been able to run well in really high bite situations...probably because I am trying to run too flat.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
