Old 01-29-2006, 10:21 PM   #13186
cornerspeed's Avatar
Originally Posted by Bob Barry
Hey Jon, I notice that you change roll center by using the riser plates and shimming up the entire bulkhead. I am coming from the AE camp where the main roll center adjustments were with the inboard camber links. I actually ran my car with the rear link up because I wanted it to rotate more. It did rotate but the car ran flatter because of less chassis roll. Wouldn't it be better to change roll center this way in stead of shimming the entire bulhead?
He is not shimming up the bulkhead, rather the arm mounts. So he is using the suspension arm riser plate plus 1mm of shimming to adjust roll center on the rear as an example. The upper camber link upper and lower holes are for a finer tuning.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 01-29-2006, 10:46 PM   #13187
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Like Donny said, I wasn't raising the bulkhead, just the suspension arms. And if my thinking is correct, raising the inner rear camber links position will actually lower the roll center. Raising the outer rear link position will raise the roll center. (If I'm thinking backward because it's late and I'm tired, please correct me someone. )
Jon Kerr is offline   Reply With Quote
Old 01-30-2006, 12:41 AM   #13188
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally Posted by heavy
When I pulled it out and replaced the pin I again tightened it up (so tight I stripped the hex in the grub screw ) even with it that tight the pin can still slide in and out. The conclusion is that the grub screw thread is not cut right through the cylinder and no matter how tight I make it it is just tightening up in the thread not on the pin.
Heavy,
Several things you can try.....
1. Find a flat bladed screwdriver to fit diagonally across the hex. It will probably need to be tapped in to ensure a tight fit. Then (if possible) heat up the outside of the cylinder (maybe use a soldering iron to create some expansion), then try to unscrew the grub screw.
2. Drill out the grub screw and insert an "ezy-out". Heat up cylinder and try and unscrew. If you don't have this tool or the grub screw is too small then try the next option.
3. Drill out the grub screw totally (without destroying the thread in the cylinder), then with a small screwdriver, try and "cave in" the grub screw towards the centre. The screw should just fall out with a few turns.
Hope this helps.....
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 01-30-2006, 04:04 AM   #13189
heavy's Avatar
Trader Rating: 20 (100%+)
Thanks mate. I actually got the grub screw out - drilled it out and preserved the thread and then cut the thread right in and now everything is perfect.
I still want to know the part number of the new cylinder.
I could have used driveshafts from the Mi2 if I'd really been stuck but everything is go now.
Honorary Life Member Logan RCCC -Mi6 and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6
Boondall. SuperShot, XX, XXT, SVR,Schumacher Storm
heavy is offline   Reply With Quote
Old 01-30-2006, 05:39 AM   #13190
IslandBwoy's Avatar
Did any of you guys have missing parts in your kits? For the life of me I can find my c/f spacer for the motor mount. Are those parts in stock @ShumacherUSA?
IslandBwoy is offline   Reply With Quote
Old 01-30-2006, 06:14 AM   #13191
The Teacher's Avatar
Trader Rating: 47 (100%+)
Does anybody have a good starting setup for carpet foam tires??? If so can you post it or PM me??? Thanks in advance....
The Teacher is offline   Reply With Quote
Old 01-30-2006, 06:50 AM   #13192
AdrianM's Avatar
If you are missing something call us and we will get you want you need. Most EC parts are in stock now.
The PW foam setup in the instruction manual is the starting setup for foam tires. It's so good most people make changes to it and end up going back to the kit setup.
Adrian Martinez
Old 01-30-2006, 07:20 AM   #13193
AdrianM's Avatar
hi guys - i need some help with an issue.
During building I pulled the driveshafts apart and retightened and threadlocked teh grub screws as per recommendations on this thread. One of mine still dropped it's pin on the second run.
I need to buy a new cylinder as I can't get the grub screw out. On the old driveshafts it was possible to buy the cylinder (U2694) but they won't fit the new U3020 driveshafts. Anyone know a part number for the new cylinder or do I have to buy a full set of drive shafts.
We have a rebuild kit from Titanium Racing and it fits perfectly.
Adrian Martinez
Old 01-30-2006, 08:01 AM   #13194
Racer X's Avatar
Teacher,
Like Adrain said, use the PW setup in the back of the manual, it is a killer setup to start with (and finish with). Paul did a great job coming up with this one. Hope that helps...
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 01-30-2006, 09:13 AM   #13195
Thanks guys!
Old 01-30-2006, 09:20 AM   #13196
STLNLST's Avatar
Trader Rating: 19 (100%+)
I'll have the set up I ran this weekend posted shortly on www.gearchart.com
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-30-2006, 11:19 AM   #13197
PW
PW's Avatar
Send a message via AIM to PW
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 01-30-2006, 11:27 AM   #13198
IslandBwoy's Avatar
Thanks Adrian, I'll give you guys a call.
Speaking of Paragon, I find that that stuff is the most consistent stuff on my car. I've tried stickum (Doesn’t last until the end of the race), I've tried the carpet stuff in the little white bottle, forgot the name but (might as well add water to my tires), while paragon always works.
What do you guys use for asphalt racing?
Old 01-30-2006, 11:31 AM   #13199
Send a message via AIM to Roberto Falcon
I think Stickum works with VHT only, but if you have a track that is sprayed with grade soda then SXT or tweak is the way to go . But tq being repaved and whatever you should buy a bottle of sxt or tweak because thats going to be used more that now the track is going to be sprayed with soda.
Roberto Falcon is offline   Reply With Quote
Old 01-30-2006, 12:54 PM   #13200
Shop Owner
FTTim's Avatar
Trader Rating: 27 (100%+)
Send a message via AIM to FTTim
Don't Forget about DIP
Specialized R/C | EPIC Motorsports | Team Trinity
"The man who smiles when things go wrong has thought of someone to blame it on."
"Id rather die on my feet than live on my knees"
FTTim is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
