Old 02-12-2002, 10:43 AM   #1306
Regional Moderator
Darkseid's Avatar
Those are some nice pics of the winning Mission.
TLR 22...Tamiya F104...
Old 02-12-2002, 12:56 PM   #1307
Send a message via ICQ to MattW
I've just got my Titanium CVD's, very light is something of an understatement. They weigh about the same or a little less than the kit plastic items.
I know it's not a very good quality pic, but should give some idea.
MattW is offline   Reply With Quote
Old 02-12-2002, 01:11 PM   #1308
David Joor's Avatar
R/C Tech Charter Subscriber
Can someone please give me a link to a schumacher mission setup sheet so I can make one for Ron? I can't for the life of me find it on the racing-cars site. My email is info@kinetixrc.com
Avid Racing Concepts LLC.
http://www.avidrc.com
AE | Reedy | KO | Tekin | Powermaster | Avid | Upgrade | BCE | Paint by Smiley
David Joor is offline   Reply With Quote
Old 02-12-2002, 01:19 PM   #1309
Talking LINK
See if this link works
http://195.92.181.9:8090/upload/MissionBlankSETUP.pdf
wilson10 is offline   Reply With Quote
Old 02-12-2002, 01:26 PM   #1310
David Joor's Avatar
Thank you, I forgot my firewall won't let me goto ports other then 80 at work. I will get it at home, thank you.
Old 02-12-2002, 03:56 PM   #1311
Oasis2001's Avatar
Send a message via ICQ to Oasis2001
MattW-Tell us how you get on with them. Also the wear rate! I find unis wear is non existanmt in the rear but quite a bit in the front. Wonder how titanium will change this?
Oasis2001 is offline   Reply With Quote
Old 02-12-2002, 04:43 PM   #1312
Adrian or PW,
When are we going to see the setup that PW used for MOD Sedan on foams? My LHS still cant get through to put in my order for my Mission and hop-ups.
IKE
FoamDonuts is offline   Reply With Quote
Old 02-12-2002, 05:44 PM   #1313
PW
PW's Avatar
Send a message via AIM to PW
Snowbirds setup for Foam tires:
Front:
Tower/1
oil/80wt
piston/2 hole stock
spring/35 lb
suspension mount/1
hubs/inline
swaybar/thick (#u2245)
castor/1 thin kwik clip in back
arm mount/1
arm sweep/2 deg
ride height/5mm
tires/Jaco plaid
Rear:
tower/1
oil/80wt
piston/2 hole stock
spring/35 lb
suspension mount/1
hubs/inline
swaybar/stock
inboard toe/2 deg
arm mount/1
ride height/5mm
tires/Jaco purple
PW
PW is offline   Reply With Quote
Old 02-12-2002, 06:31 PM   #1314
Tractionroll's Avatar
What extras do I need for the Mission. Any hop up's needed ??
Tractionroll is offline   Reply With Quote
Old 02-12-2002, 07:06 PM   #1315
Racer X's Avatar
Congrats to all the Schumacher drivers at the Snowbirds, especially in 19T and to Ron Atomic.
TractionRoll: Everything you need really comes with the car. You may need some springs (red and yellow), threaded shock bodies (if you don't like the spacer thingies), and a one way (if they are the hot ticket at the local track). Other than that, you will need to keep coming here and make space for all the trophies (lol).
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 02-12-2002, 07:40 PM   #1316
Got my carbon Mission today...have to wait till friday though before I start. I got some hopups coming that I want to build into the kit. Looks good!
BTW, did anyones tires, foam, bumper and wheels come 'loose' in the box? Its all there...but just wondering.
Sean
_neas_ is offline   Reply With Quote
Old 02-12-2002, 08:46 PM   #1317
PW,
what was your starting diameter with the tires?
IKE
Old 02-12-2002, 08:54 PM   #1318
Look back a few pages and I posted some product numbers that Adrian from Schumacher told me to get. Also, if you really want to get into it you can call Les and MDIRacing.com and get the Boca Bearing kit for the Mission....$50
-Sean
Old 02-12-2002, 09:33 PM   #1319
Send a message via ICQ to JesseT
Where is the upper deck from? I mean the one that can be seen on Ron's car.
JesseT is offline   Reply With Quote
Old 02-12-2002, 09:45 PM   #1320
Send a message via ICQ to SirSpeedy Send a message via AIM to SirSpeedy Send a message via Yahoo to SirSpeedy
Ron was running the new carpet upper deck from Schumacher.
It was really designed for foam tires, but the bite was so high, any stiffening of the chassis was a plus.
Tim Davis
SirSpeedy is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
