Old 01-29-2006, 12:07 PM   #13171
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Thanks for your advice Adrian and Paul. Much appreciated. And just to clarify, with regard to the roll centre changes, what is meant to happen if you raise or lower the roll centres (front and rear)?
Thanks again.
Leonard.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 01-29-2006, 12:10 PM   #13172
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Jon Kerr
All I can say is WOW! This was the best car I've ever had at SoCal and I only had 8 runs total last night! The 19 turn class was like the typical SoCal Nationals 17 guys in 19 turn. Tosolini TQ'd and the top 12 were within 10 seconds of his time. I was 10th after some inconsistency due to nerves Unfortunately they cut off the A at 9 dues to the tight track I did run away with the B running the car in cruise control.
Donny- I did try the roll center adjustment you suggested and it did work, but too much. Made the car flow through the corners but made it too free. It was even more nervous like that. I went back to where I was when I talked to you and played with the wheelbase position a little. I also took that one last brace between the steering posts out of the top deck. That helped too. It was a little frustrating because the car was SO good but I was about .2-.3 off Toso's lap times and didn't know where to get it from the car. It had to have been all driver
Way to go Jon. We had 26 guys in 19 turn last night. I'm happy for now. Gotta see what set up changes are needed once the bite comes up. I still think for 19 turn and stock we have a pretty good set up but it needed some changes for mod. Time to make sure Schumacher USA has plenty in stock because these babies are gonna sell like hot cakes. Keep up the good work and I guess I'll see you at the Reedy.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-29-2006, 12:19 PM   #13173
STLNLST's Avatar
Thanks again.
Leonard.
I'm no Jon Kerr so this may be corrected later or added to but for me raising the roll center makes the car react quicker (switching directions, through tght "S" sections) and not as much lean..........while lowering it made the car sort of have a hair bit of lean (IMO) and also seemed to give me a little traction. again.....wait for a Jon Kerr explaination. He is the the man with helping someone understand set up
Old 01-29-2006, 12:42 PM   #13174
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Thanks again.
Leonard.
It's like STLNLST said lowering the roll center allows that end to roll more which will usually give more grip to that end. Raising it will allow less roll and make it more reactive (less roll,stiffer). Jon's turn to correct us both.
Rod
ClemsonTigers
USVTA # 224
Team C Racing USA / TC 10 2015
ERC
RKeasler is offline   Reply With Quote
Old 01-29-2006, 01:29 PM   #13175
Just another thought/question, when we are talking about the change in roll centres, and reference to the setup sheets, does that mean we just add spacers accordingingly (ie. if roll centre is 3mm, we put the 3mm alloy spacer in. Or do you have to include the piece of carbon firbe plate as well?)I only ask as this car is different to my old car (JRXS).
Thanks again for all of your help and advice.
Leonard.
Old 01-29-2006, 01:43 PM   #13176
Trader Rating: 17 (100%+)
Originally Posted by STLNLST
OH MY GOSH..........
This car is awesome. It looked really good sitting on my work bench for the couple of weeks while our carpet track took time off but it was worth the wait. Missed TQ on a bobble on the last lap. I took out all the RDX hot shots except the one that TQ'ed The car is easier to drive and if you need to push it some it's still controllable Corner speed (non pun intended) up the yin yang. The car rotated well and had nice snap out of the corners. Mo did most of the major testing but I just wanted to get use to the way the car felt. Only changed one thing from what we started with and the car was AWESOME!!!! The Schuie's were out in force today as all of the norcal regulars came out. Racer X will have the new set up sheet on www.gearchart.com tomorrow or Monday as the current one doesn't show all of the shock loactions. It sure was nice to be back in the lime light again. Too bad I screwed up the start of the main so my finishing position didn't show how killer the car was. I did have quite a few straightaway vic's today. The DC motor and battery combo was excellent.
BN RACING qualified 1 & 2 today .......................we all know Schuie guys don't look good in mullets
The car looked good! So good that even STLNLST could drive it into the A. (Complimentary product support plug) Good JOB!
I wish I could have done better but I made all the wrong set up decisions....its all good though. Lady Luck smiled upon me and I did NOT have to wear the MULLET! Thank GOD! I'll get ya next week booiiiiiiiii!
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 01-29-2006, 02:37 PM   #13177
Jon Kerr's Avatar
Leonard.
Thanks guys.
Clint and Rod are right. The lower the roll center, usually the more bite you'll get on that end, to a point. For instance, yesterday, I raised the roll centers on the car front and rear to see if the car would flow faster through the corner. It did but at the expense of not having enough bite to place the car where I wanted it. It made adjusting my line really difficult if I needed to react quickly. And when we're talking about a 3mm roll center, it's usually the 2mm riser plate, plus a 1mm shim under the pivot block.
Oh and Shookie, thanks. That's exactly what I'm hoping for.
Jon Kerr is offline   Reply With Quote
Old 01-29-2006, 03:04 PM   #13178
Racer X's Avatar
Normally, I don't like running a new car for the first few times as I shake the bugs out (usually installed by me) and learn how different changes effect the car, but WOW! Schuie hit this one out of the park! It was the easiest kit I have built...no fitting, no grinding, no problems...and it has got to be the nicest looking car at the track. But this car is not all show and no go. PWs setup was GREAT! Changes to the setup did exactly what was expected (and were usually changed back to PWs setup). The car didn't miss a beat all day...the driver, however, coming back from a long vacation from carpet (and never running foams before) had accumulated some rust. The car was running much better than the driver (the driver was afraid to push dispite the cars insistance to go faster). Give me anouther week or two, some new batteries and a motor (still running batts and motors from the Reedy) and maybe I'll be able to at least finish on the same lap as STLNLST.
Great driving STL...and as predicted, no mullet to be found around anything Schumacher. See ya next week...
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 01-29-2006, 03:07 PM   #13179
cornerspeed's Avatar
Yea Jon, maybe having the shocks laided down some may have helped. Don't know if you did that or tried a softer rate. Did you try the equal springs all the way round?
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 01-29-2006, 03:17 PM   #13180
Jon Kerr's Avatar
No, those adjustments are next. I also want to try a one-way there once. This car is so much more stable than the old car, the one-way may react better with it. I'm really trying to do the setup testing one change at a time. It'll take longer to get them all tried, but we'll know exactly what each change will do the fewer variables we have. Moving the front arms all the way back (I had them 1mm from full back) really made a huge difference. It's much more aggressive than it was when I started eventhough it felt very aggressive then too and it carried the extra steering through the whole corner.
Old 01-29-2006, 07:58 PM   #13181
heavy's Avatar
Trader Rating: 20 (100%+)
hi guys - i need some help with an issue.
During building I pulled the driveshafts apart and retightened and threadlocked teh grub screws as per recommendations on this thread. One of mine still dropped it's pin on the second run.
When I pulled it out and replaced the pin I again tightened it up (so tight I stripped the hex in the grub screw ) even with it that tight the pin can still slide in and out. The conclusion is that the grub screw thread is not cut right through the cylinder and no matter how tight I make it it is just tightening up in the thread not on the pin.
I need to buy a new cylinder as I can't get the grub screw out. On the old driveshafts it was possible to buy the cylinder (U2694) but they won't fit the new U3020 driveshafts. Anyone know a part number for the new cylinder or do I have to buy a full set of drive shafts.
Honorary Life Member Logan RCCC -Mi6EVO and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6EVO
Boondall. SuperShot, XX, SVR,Schumacher Storm BigWig
heavy is offline   Reply With Quote
Old 01-29-2006, 08:14 PM   #13182
Send a message via AIM to Roberto Falcon
I think the only way you can solve that problem is file a flat spot on the pin . What do you guys suggest?
Roberto Falcon is offline   Reply With Quote
Old 01-29-2006, 08:22 PM   #13183
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Try threading the set screw into the cylinder and look for it through the pin hole, if you dont see it, threads arent cut deep enough or there is a burr. Use a tap to clean out the threads if this is the case. If you still cant get it to work, use a large piece of heatshrink over the cvd bell to hold the pin in until you can get a replacement.
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
Old 01-29-2006, 08:25 PM   #13184
Super Moderator
Hey Jon, I notice that you change roll center by using the riser plates and shimming up the entire bulkhead. I am coming from the AE camp where the main roll center adjustments were with the inboard camber links. I actually ran my car with the rear link up because I wanted it to rotate more. It did rotate but the car ran flatter because of less chassis roll. Wouldn't it be better to change roll center this way in stead of shimming the entire bulhead?
Tekno | JConcepts | ProTek RC | RaceReadyProducts | BOOMrc
Bob Barry is offline   Reply With Quote
Old 01-29-2006, 10:15 PM   #13185
Stlnst- I am glad your new car works now we can go to the range and I dont have to worry about you shooting anyone when you start thinking about cornerspeed!!!!! BN Racing in the HOUSE!!!!!
LSR SPEEDWAY
R1 WURKS
Schelle Racing
MIP Racing
BN Racing
bigdog is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
