Old 01-28-2006, 10:49 PM   #13156
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Originally Posted by TimPotter
I have been running the Foam Spec car on asphalt, and it just keeps on getting better every time I run it.
So what is the ticket on the blacktop, Foam spec or Regular version? Talk to me order time is nigh!!!
Rod
ClemsonTigers
Team C Racing
TA10
RKeasler is offline   Reply With Quote
Old 01-28-2006, 11:06 PM   #13157
AdrianM's Avatar
Rod
The the standard EC is best for 99% of all asphalt tracks.
If you are traction rolling on asphalt then maybe the Foam Spec would work.
Adrian Martinez
Old 01-29-2006, 12:01 AM   #13158
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
I just wanted to know if I am making a misktake. I have built the Ec as per instructions using the Teemu setup out of the book. And after several runs at 2 different tracks (both asphalt outdoor and indoor), the car seems to be extremely stable and easy to drive, to the point where it is 'pushing' through the corners (especially entry and mid corner). However, since I did not understand how to measure droop the Teemu way I just used 3mm frt and 4mm rr droop (using ride height).
I have since learnt to measure droop the Teemu way (thanks to Jon Kerr!), but have not had a chance to run it. Also, I have noticed that the Teemu setup on the net (Schumacher website) is different to that of the instruction book. Which one are you guys using? Or are you using Paul W's latest setup?
Any help would be greatly appreciated.
Leonard.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 01-29-2006, 12:52 AM   #13159
Trader Rating: 17 (100%+)
Send a message via AIM to Roberto Falcon
Hey Adrian which kit did you and PW ran at speedline for the state race?
Roberto Falcon is offline   Reply With Quote
Old 01-29-2006, 03:38 AM   #13160
HarshGuy's Avatar
Originally Posted by STLNLST
with all the posting you've done on this thread and what you saw today....I'm sure PW wouldn't mind taking your order for two EC's....
Na, I'm done messing with new cars for carpet anyhow. ....but I'll trade you a car with an all new patented tweekfree multiflex technology chassis system
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 01-29-2006, 05:24 AM   #13161
HarshGuy's Avatar
Whao ...I think STLNLST's whole ordeal here was just a marketing ploy!! Look what I found at amazon.com click here
Old 01-29-2006, 07:21 AM   #13162
AdrianM's Avatar
We ran the standard Rubber EC car.
Adrian Martinez
Old 01-29-2006, 08:11 AM   #13163
mo
mo's Avatar
That's just wrong Harsh.
My car was pretty good yesterday too. I started out with what PW ran except with different pistons and oil. Then made a few changes throughout the day. By the maind it was right on pace. I'll have the setup posted in a bit.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 01-29-2006, 08:16 AM   #13164
AdrianM's Avatar
Leonard.
We are running the Kit set up.
Make sure you hit every point of the setup exactly. If you fudged one setting it could make the car not work as expected.
Make sure all shock have equal rebound, all suspension arms are completely free and that you car is tweaked.
The only time that I had a push last weekend was when I forgot to sauce my tires properly before a qualifier.
If you have every detail of the setup exactly and you want more turn in move the rear arms forward 1mm. This will make the car rotate more on corner entry.
Adrian Martinez
Old 01-29-2006, 08:26 AM   #13165
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
All I am going to say is Jon Kerr's car looked ubber dialed last night....
Very aggressive...
Very impressed...
Keep this up and peeps will be beating down that door Adrian...LOL
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 01-29-2006, 08:55 AM   #13166
mo
mo's Avatar
http://www.gearchart.com/setup/setup...mo-carpet1.pdf
OK, my setup is posted on www.gearchart.com ^^^^
Old 01-29-2006, 09:03 AM   #13167
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
I would agree with Adrian on this one. My local outdoor track has more traction then 99% of any other track. I went with the foam spec car becuase of this.
Rod
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 01-29-2006, 09:48 AM   #13168
Jon Kerr's Avatar
All I can say is WOW! This was the best car I've ever had at SoCal and I only had 8 runs total last night! The 19 turn class was like the typical SoCal Nationals 17 guys in 19 turn. Tosolini TQ'd and the top 12 were within 10 seconds of his time. I was 10th after some inconsistency due to nerves Unfortunately they cut off the A at 9 dues to the tight track I did run away with the B running the car in cruise control.
Donny- I did try the roll center adjustment you suggested and it did work, but too much. Made the car flow through the corners but made it too free. It was even more nervous like that. I went back to where I was when I talked to you and played with the wheelbase position a little. I also took that one last brace between the steering posts out of the top deck. That helped too. It was a little frustrating because the car was SO good but I was about .2-.3 off Toso's lap times and didn't know where to get it from the car. It had to have been all driver
Jon Kerr is offline   Reply With Quote
Old 01-29-2006, 10:23 AM   #13169
P-DUB's Avatar
Mi2EC Rubber Spec http://www.rctech.net/forum/attachme...hmentid=114895 Dialed outdoor
DirtyDog3375....Several changes I made from Teemu's setup to get a more reactive car; 5wt lighter oil front & rear (25wt/30wt), raised the front camber link to the upper hole, shorten the wheelbase 1mm using the rear arm. Lowered front & rear hinge-pins .5mm. Please make each change one at a time
Great report Jon!!!!
Larry Pryor
P-DUB is offline   Reply With Quote
Old 01-29-2006, 11:18 AM   #13170
IslandBwoy's Avatar
IslandBwoy is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
