Old 01-27-2006, 01:31 PM   #13096
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
Jon Kerr nice looking car and paint job. What body is that you have on?
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 01-27-2006, 01:36 PM   #13097
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Roberto- It's actually the carpet car. I've removed three of the center braces to add flex until I can get my hands on a rubber spec top deck. I preferred a stiffer car on with the Mi2. So that's where I'm starting. I'll probably be removing one or both of the remaining braces in the deck to fine tune the chassis flex. Plus, where I'll be racing this car mainly, SoCal, a stiffer chassis seems to be the ticket. I'll do some testing with it and post up what I find.
wyd- Thanks. Lynn does a good job. It's just a Mazda 6.
Jon Kerr is offline   Reply With Quote
Old 01-27-2006, 01:39 PM   #13098
Super Moderator
I think the wider stance of the carpet car will be better anyway. Awesome looking paint job. Hey Brian I might need your guy to hit me up a lid...think he can handle that?
Tekno | BLOK | JConcepts | RaceReadyProducts | BOOMrc
Bob Barry is offline   Reply With Quote
Old 01-27-2006, 01:56 PM   #13099
heavy's Avatar
Trader Rating: 20 (100%+)
Originally Posted by AdrianM
I could only fit two in the rear one on each side and one in the front..which I put on the left. Make sure you have a noticeable amount of side to side play. If you have none you may be side laoding your bearings and that slows you down.
Adrian - I think he is talking Mi2. I am teh same as you with teh EC but with the old car I ran 3.
Honorary Life Member Logan RCCC -Mi6 and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6
Boondall. SuperShot, XX, XXT, SVR,Schumacher Storm
heavy is offline   Reply With Quote
Old 01-27-2006, 01:59 PM   #13100
wyd
Tech Legend
wyd's Avatar
Man Jon that paint job really made that body look like a whole different car. He did do a very nice job. Thanks for the info.
Old 01-27-2006, 02:06 PM   #13101
Jon Kerr's Avatar
I think you mean SHE did a very nice job.
Old 01-27-2006, 02:10 PM   #13102
AdrianM's Avatar
Lynn is painting my sedan and 1/12th Snowbird's bodies. I gave her an idea of what I wanted. I can't wait to see what she comes up with!
Adrian Martinez
Old 01-27-2006, 02:14 PM   #13103
Jon Kerr's Avatar
A year and a half ago I was looking for a painter. She had me call her @ 10:30 our time to describe what I wanted for the Reedy race the next weekend. I said white pink and blue and she came up with this scheme, painted it, and shipped it in 2 days in time for Reedy. She's awesome.
Old 01-27-2006, 02:20 PM   #13104
Jon Kerr's Avatar
Old 01-27-2006, 02:21 PM   #13105
Oasis's Avatar
Trader Rating: 36 (100%+)
Jon It would be rubber,stock and the track is bumpy.
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 01-27-2006, 02:35 PM   #13106
Jon Kerr's Avatar
Run the Schuie white springs all around, 30wt. front, 35wt. rear. If the track is really bumpy, try a lighter oil (25wt. front 30wt. rear) so the shocks don't pack so hard and bounce the car around. You may want to try not running swaybars if too if the lighter oil doesn't work.
Old 01-27-2006, 03:02 PM   #13107
Send a message via AIM to Roberto Falcon
So what do you think its best then Jon the carpet or the asphault car?
Roberto Falcon is offline   Reply With Quote
Old 01-27-2006, 03:14 PM   #13108
Jon Kerr's Avatar
Still working on that. I think it's going to have a lot to do with the track you run on. SoCal is different than any other track out there. It's very high bite so the stiffer car seems to let the suspension do it's job better. Too much flex and the car can feel too stuck.
Old 01-27-2006, 03:52 PM   #13109
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Can anyone help me out with a conversion for droop??? I do not measure droop the way teemu does and I want to know what the droop is converted to the "normal" way of measuring droop (ie. using ride height).
Teemu droop = 24 and 25mm at axle
"Normal droop" = ? and ?
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 01-27-2006, 03:58 PM   #13110
Jon Kerr's Avatar
The best way to figure that is to use Teemu's method once. Set it like he does, then check to see what that droop setting gives you with your method.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
