Old 01-26-2006, 07:29 AM   #13066
IslandBwoy's Avatar
how do you guy have the servo saver set im getting a digital servo with metal drive train and high torque120oz ?
With the metal gear servos it will probably take an act of the devil to damage the gears on those. Therefore it will be ok not to run a servo saver at all. Most of us dont.
also the aluminium hing pin holders how do u put them on ive been looking and ithink that theback one have the shaft close to the diff but the front one have the shaft on the out side does this make sense? i just want to know does r go with th other r and l with l or do u mix and match??
When is all said and done I think you will end up with one of each on both sides. Just be sure that the L/R face down on the chasis and that the curved end of the block faces outwards.
is 2mm spacer under neath a good idea?
This depends on track conditions. 2mm under the blocks will raise your roll center therefore 'free'-ing up the car a bit. If there is enough traction on the track you can do this to obtain considerably more cornerspeed. However if the track is low bite or the traction has not come up yet (early in the day) the car may be too loose with this setting and make it harder to drive in and out of corners.
also in the actual block the hinge pin sit towards the top or bottom of the mount which is it i thought bottom so the is more meet holding it but i dont know please help?
With the L/R facing down on the chasis, and the rounded ends facing out, the hinge pins should sit towards to the top of the blocks.
Hopes this helps.
IslandBwoy is offline   Reply With Quote
Old 01-26-2006, 09:02 AM   #13067
HarshGuy's Avatar
Originally Posted by STLNLST
Man....I better come with it since the whole RC community is against me
Like I've always said. When I'm invloved look at the turn out. I generate revenue remember the dress challenge in 12th scale????
Yea that was a funny one to! We still need to get a T2 in there somwhere!
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 01-26-2006, 09:06 AM   #13068
Trader Rating: 16 (100%+)
It appears that the locals that own them are ....... scared????
You better bring it STLNLST....you KNOW how good my car is! All I have to do is not mess up
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 01-26-2006, 12:10 PM   #13069
takeadive012806 is offline   Reply With Quote
Old 01-26-2006, 12:52 PM   #13070
STLNLST's Avatar
Trader Rating: 17 (100%+)
Originally Posted by racerfreedxxxs
off topic but do you guys know anywhere online i can get some black, grey schumacher springs? and will they fit tc3 shocks ok? using them on a dirt oval application, trying to find a softer spring rate then what i have available.
thanks,
Try ordering them from Schumacher USA or Speedtech.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-26-2006, 12:54 PM   #13071
PW
PW's Avatar
Send a message via AIM to PW
Had a few guys asking for my EC setup for rubber tire/asphalt
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 01-26-2006, 12:54 PM   #13072
STLNLST's Avatar
Originally Posted by aus jd 2703
hey guys a few questions before i put my mi2 back together.
will 800grit sand paper for the diff ring be ok i couldnt buy 600??
also the aluminium hing pin holders how do u put them on ive been looking and ithink that theback one have the shaft close to the diff but the front one have the shaft on the out side does this make sense? i just want to know does r go with th other r and l with l or do u mix and match?? is 2mm spacer under neath a good idea? also in the actual block the hinge pin sit towards the top or bottom of the mount which is it i thought bottom so the is more meet holding it but i dont know please help?
800 grit will be finer than the 600 so it will probably take you a little longer to get the job done compared to the 600. It may give a smoother finish once you're done though.
Old 01-26-2006, 06:31 PM   #13073
IslandBwoy's Avatar
@takeadive012806
Hilarious!
Old 01-26-2006, 07:28 PM   #13074
Trader Rating: 237 (99%+)
Still waiting for that editable setup sheet....
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA, Garcia Graphix and Integy***
Fred Perkins is offline   Reply With Quote
Old 01-26-2006, 08:16 PM   #13075
P-DUB's Avatar
Here you go http://www.racing-cars.com/usa/image...setupsheet.pdf
You wont be able to save it as a standard file, but you can print to paper or print to adobe distiller and save it that way
Larry Pryor
P-DUB is offline   Reply With Quote
Old 01-26-2006, 10:42 PM   #13076
so 800 grit will do the diff rings as in the wont be to smooth?
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 01-26-2006, 10:50 PM   #13077
Send a message via AIM to Roberto Falcon
800 is a fine grit so ill leave a smooth finish .. I would just sand the diff rings with that.
Awesomatix USA - Speed Passion - Superior Hobbies
Roberto Falcon is offline   Reply With Quote
Old 01-26-2006, 11:10 PM   #13078
no offence to island bwoy but is what he said about the hinge pin mounts true?? do you mount them one l and r on each side with the letter facing the chassis.
i just want conformation.
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 01-26-2006, 11:13 PM   #13079
Island Bwoy is correct when using the alum. arm mounts you mount them with the letters facing the chassis
Old 01-27-2006, 02:55 AM   #13080
hey how do you guys shim your front diff 3 or 4 shims?? also if 3 which side o u put the 2 shims on??
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
