Old 01-20-2006, 06:40 AM   #12946
IslandBwoy's Avatar
Donít forget that you may be experiencing what seems to be low rear grip due to high front traction/steering. Maybe you should take out the spaces from under the rear of the front pivot blocks as well since that is going to make the front much more reactive than if it was to lay flat. Check out PW's last setup. Itís a 'flat' setup which is a much more stable setup in low grip situations. I dont know what the droop settings are by default in the EC setup (since i havent built mines yet :-() but maybe try some more up travel in the front less in the back.
JEDI
PS. if you could fill out a setup sheet and post it, that could help us make some recommendations as well.
IslandBwoy is offline   Reply With Quote
Old 01-20-2006, 08:35 AM   #12947
i writ up a set up of what i ended up with. if u could help ill b gratefull.
i would start off with this set up. but say the rear is a bit lose what would i change to help?
and the same with the front if its understeering what would i change to help?
cheers
bob
bob33 is offline   Reply With Quote
Old 01-20-2006, 08:58 AM   #12948
Bob,
It would help to know if the back end is loose on the way in or the way out of the corners.
Jason
jasonb is offline   Reply With Quote
Old 01-20-2006, 09:02 AM   #12949
well its just lose most of the time under power, then let off power a bit into corner and it all gets a bit twitche then have to b realy gental putin power bk on or your sliding (that sounds worst that what it is but u get the pitcher hard to explain) think if i get rid of some front grip it would b beter.
oh yeah im runing traction control on the handset
Old 01-20-2006, 09:03 AM   #12950
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Try moving your rear camber link up to the top.
Jon Kerr is offline   Reply With Quote
Old 01-20-2006, 09:04 AM   #12951
thanks jon
Old 01-20-2006, 09:08 AM   #12952
Racer X's Avatar
Stlnlst,
I've always been around, but I've just been trying to fly below the radar. Work issues are finally clearing up giving me more time to do my job which is also giving me more time to play with my toys... Is it possible for a nobody to make a comeback?
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 01-20-2006, 09:15 AM   #12953
IslandBwoy's Avatar
Yeah what john said. Everything else looks pretty standard. However i noticed you dont run aditive either!?!?! Is that because of the surface? I'm not familiar with the surface so.... Did you check for outside influences? Tweak, faulty tires (check the glue), Diff (is it slipping?)...etc...
Old 01-20-2006, 09:23 AM   #12954
John_S's Avatar
have u tryed loosening your diff off 1/8th of a turn or put a diff in the front. A spool tends to give a lot of on power steering
John_S is offline   Reply With Quote
Old 01-20-2006, 09:44 AM   #12955
thanks u lot, i dnt run aditiv because i am not alowd . will the diff fit straigh in out of a std mi2?? if it does i will try that if needed!. the rear diff seems fine and not to tight. proble b easyer if i get used to driving it like this
cheers
bob
Old 01-20-2006, 10:58 AM   #12956
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Racer X
Stlnlst,
Not if you're running those world class batteries.....LOL
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-20-2006, 11:35 AM   #12957
Bob,
a front diff would certainly make the car easier to drive on power, Mi2 diff will fit you might have to adjust the spacing on the pulley though to get the front belt to run straight.
Jason
Old 01-20-2006, 11:58 AM   #12958
thanks jason: ill see how it goes in fisrst round of Q-ing and see if i need to put a front diff in.
and im going to take the .5mm shims out the rear "front" pivot blocks see if that helps.
Old 01-20-2006, 12:40 PM   #12959
HarshGuy's Avatar
...now that's some team love!!
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 01-20-2006, 03:35 PM   #12960
STLNLST's Avatar
What do you know about team love.......you're switching cars every three months
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
