Schumacher Corner
Originally Posted by Kevin K
Anyone looking to replace the gold adjusters that come with the new shocks can use the Purple ones that are on the HPI Pro-4 and Cyclone shocks they are a perfect match. I just got a set and they work great and match the rest of the purple on the car.
Trader Rating: 32 (100%+)
Originally Posted by Jon Kerr
Got a part number for those? I looked on Speedtech and Stormer and couldn't find them.
http://www2.towerhobbies.com/cgi-bin...?&I=LXGPA9&P=0
The HPI number is 30004.
For anyone that has any old Schumacher Threaded shocks, you can use the collars from those, the origional short ones are ok.
Thanks P Dbl U, got it in 26 hours - new record. However it was sent was expensive but worth it!!! Over 150 entries in Toronto and two Schumachers, both mine again, haha!
Just to let you guys know; Schumacher will have gold collars with o-rings in the next week or so
Here ya go......its a Tower number.....so Im not sure what the HPI part number is.
Yeah, but they're still gold
I already ordered mine. Purple in color too
The EC foam towers look great on the original Mi-2. The shock mounts are over a hole lower than the Schu carpet towers so the shock length had to be adjusted using TRFs.
My question:
How many millimeters higher are the camber link holes on the rear tower of the EC Foam Spec than the Mi-2 Carpet Towers? Im specifically wondering how many mm of spacers I should start with on the rear hub using the lower hole of the new towers if I want to start with something close to what works right now(upper inside). I would prefer to remove .5mm at a time than add, which is all we have been able to do for a while now. I put the towers back to back but am still not sure?
My question:
Gee M, I personally wouldnt run either EC rubber or carpet towers on an Mi2, not only are the hole heights different, but their distance to the centreline is greater, to match the Hinge pin spacing on the New E.C.
Notice the camberlink ballstud is located directly above the lower hingepin.
It would be similar to running the outer camberlink holes on the Mi2 towers, which to me always felt funky.
my car will be here friday!!! many thanks to you paul and adrian for sending it
out so quickly........there will be two more e/c's at the track on the 28th... looking forward to racing again after the "soccer season"
it's going to be a fun day of racing on the 28th. I will suggest one thing though.......come with some motor in the 19 turn class
